Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Paper Jam I am running a 11x17 28lb paper, full color, but it keeps on giving me jams. I am getting the paper jams. I switched to the bypass and it also gives me jams, this only happens after the second sheet gets printed with magenta. Please help. Its a Canon 1120.
  • 168 Answers
This is probably the sensor inside the transfer sheet or the reflection plate under the cleaning blade assy being dirty. also there is a reflection plate on the bottom of the transfer sheet near the gear assy
Posted on Dec 10, 2008
Paper continues to jam
check the paper actuate of the sensor if it o.k check the sensor if its clean
Jun 24, 2014 | Gestetner C7425DN Paper Feed Roller...
My cannon MP160 pixma keeps telling me there is a paper jam when there is no paper in it, it will copy and give me color tests printed out but if i try to print a doc. It says E# paper jam
Hello thanks for using fixya
Actually you are facing E3 error, E3 error is mostly because of paper jam. their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon service provider.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Feb 07, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I have a paper jam on a CLC 1120 and there is no paper jam I've check the machine 10 times
You didn't state where the jam is indicated. If it's indicating a paper pickup jam there are levers toward the back of the cassette that could get hung up.If it's a fuser jam the outlet lever on the fuser unit.If it's indicated in the transfer drum area a bad transfer sheet can give a false jam indication sensing paper on the drum.
May 25, 2010 | Canon CLC 1120 Color Copier
My HP Color Laserjet 3600n had a paper jam. The
Your best method of troubleshooting is the manual sensor test as this is a generic paper jam error.
on your sensor tests:
0 = off
1 = on
A = TOP OF PAGE SENSOR
B = PAPER LOOP SENSOR
C = N/A
D = FUSER PAPER SENSOR
E = DELIVERY-TRAY PAPER-FULL SENSOR
F = FUSER PRESSURE-RELEASE SENSOR
G = MEDIA SENSOR
H = N/A
I = MP TRAY SENSOR
J = CASSETTE SENSOR
K = DOOR OPEN DETECTION SWITCH
L = DEVELOPING ESTRANGEMENT SENSOR - CLR
M = DEVELOPING ESTRANGEMENT SENSOR - BLK
N = MP TRAY MEDIA POSITION SENSOR
A-F are paper path sensors - you can toggle them and watch if they change from 0 to 1. If they do, the problem is not in that area.
G can have states from 0-7 each one representing a different type of paper - shouldn't have anything to do with jamming.
hope this helps. probably a tiny piece of paper or toner somewhere. could also be a torsion spring out of position on a flag.
May 10, 2010 | HP Color LaserJet 3500 Printer
Keep getting an error that says paper jam. can
Dell P703w Printer
May 02, 2010 | Dell P703w Printer
MPC4000 jamming when copying double-sided color paper. Is there a fix?
1st question is does it jam on regular plain white paper dbl sided ? if yes it depends on where it jams and what the service jam code is, if no then how thick of color paper is it ( is it within the copier specs ? ). If the paper is within the specs you should set either the paper tray or bypass tray for the correct paper weight in user tools, because it does two things : 1 it slows down the copier speed and 2nd it increases the heat level.
Apr 14, 2010 | Ricoh 4506 Copier
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
Error code on Ricoh FT5733 copier
Open ALL paper jam locations on the machine. The jam code only means the paper jam is somewhere BEYOND the paper drawer. Check ALL jam locations including duplexer, bypass, and ALL paper drawers.
Nov 12, 2008 | Office Equipment & Supplies
Computers & Internet Logo
293 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
