Question about Husqvarna Freesia 425
BOTTOM THREAD KNOTTING UP
MY BOTTOM THREAD KNOTS UP REALLY BAD. HOW DO I ADJUST THIS? THANKS!
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 14, 2010
How to set the tension
The carrier and bobbin are removed. Place the thread in the carrier with the thread dispensing counterclockwise. Place the thread between the metal pieces (tension). let the carrier hang from your finger and bob it slightly. It should extend one inch. If it doesn't then you can adjust it by turning the small screw slightly until it does what I said. Now, replace this assembly. The top tension you can start at three. The sewing should be an even pull between the upper and lower thread. If the thread knot is in the center of the material it is right. If the knot is under the material then raise the upper tension. If the knot is on the upper material then you should lower the upper tension. The key is to start with the bobbin tension correct and adjust the upper tension until the knot is in the center of the fabric
Oct 26, 2014 | Sewing Machines
How adjust bottom tension on this as it keeps knotting up?
If your top thread is knotting up in bobbin area, your top thread is mis-threaded, possibly out of take-up lever or tension disks need cleaning/adjusting.
Sep 28, 2014 | Singer Sewing Machines
Feeder not moving
knotted up thread under the material indicates that the needle thread tension is incorrect ( needs tightening)
once you have that correct the material, will feed normally
use scrap when adjusting and the correct tension is when the top and bottom threads meet at the join ( middle -center )of the materials being sewn
Aug 09, 2014 | Elna 2007 Mechanical Sewing Machine
Bottom thread tangles and knots
usually a top-thread tension issue, try tightening up the top thread's tension, there is usually a disk or knob somewhere to adjust it.
Dec 10, 2013 | Sewing Machines
Bobbin thread keeps knotting
1. Do you mean that there are knots in the bobbin thread?
2. Is the bottom thread in your stitching looping and knotting.
If yes to 1. you need to rewind your bobbin fresh, and keep slight tension on the thread reel that you are winding it from. Put the handle of your scissors into the top of the reel to apply a gentle pressure while winding. Keep your eye on the bobbin as it winds and give it a nudge with a finger tip to ensure it winds the bobbin evenly top, middle and bottom.
If yes to 2, then you need to check your bobbin threading, is the thread even under tension. Is the bobbin tension set correctly. Break out your manual and revisit this to ensure it is set correctly.
Feb 27, 2011 | Brother XL-5340 Mechanical Sewing Machine
I own a Bernina 1260 and am having a problem adjusting my bottom thread (it has loops in it). I have tried adjusting the tension but I still cannot get a perfect bottom stitch.
Hello
You would pull out several long lengths of matching thread from my spool of thread and knot the threads together at one end (to hold them together). Grab the knotted end of threads with your left hand and place the threads(held taunt together) under the presserfoot of your sewing machine.
Select a narrow zigzag stitch that will zigzag over the threads, and holding both the knotted end(Left hand) and the other ends with right hand( holding tauntly), zigzag down the length of the threads.
You can use this for matching button loops, cording for belt loops, or whenever you need matching cord. The thickness of the cord will depend on how many strands of thread you want to use. You insert the loop of cord into the seam, so that when the garment is turned RIGHT SIDE OUT, the loop will be sticking out of the seam and you can put the button through the loop.
THANK YOU FOR VISITING FIXYA
Feb 02, 2011 | Bernina Sewing Machines
Our old simnger machine knots up the threads from the bobbin side-below. What is the solution
Rethread the upper threading and adjust the tension. The knotting up in the under side of the fabric is due to incorrect upper tension.
Thanks,
Pat
May 24, 2010 | Sewing Machines
I can't find the tension adjusting spring on my brother 2600i
1Sew a test seam. Ads by Google
'; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+9911500640+9665908481+7416705818+8962074949+8941458308+1258424658+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); 2Observe the seam on the top and the bottom surface using a magnifying device if need be.
  • 3Find the position of the knots.
  • 4Tighten the tension and "pull the knots up" if the knots appear on the bottom side of the sewn seam.
  • 5Loosen the tension and "drop the knots down" if the knots are on the top surface.
  • 6Sew a test on the fabric you will be using. Tensions often have to be adjusted when changing fabric types and weights.
  • 7Continue adjusting the tension and inspecting the seam until your seam is balanced.
  • Apr 03, 2010 | Brother XL-2600I
    Singer 301a sewing machine does not sew for more than 2 secs...top thread just knots into a huge ball on bottom of fabric...everything is threaded correctly and all tension set well...next step is trash...
    Recheck the top thread and bobbin tension for equal balance of thread when sewing. The knotting of thread problem is usually because the tensions are too tight or too loose and/or thread may not be properly threaded. Another reason is when the bobbin thread is wind imbalanced it will cause the thread to knot-up when sewing. This problem is notorious when the bobbin is winded within the bobbin case on some machines. The bobbin thread need to be wind smoothly in the bobbin to avoid this problem.
    Jan 24, 2010 | Singer Sewing Machines
    I can not get the bobben to thread right and when I sew it knots up on the bottom side of the stitech
    the knots on the bottom are caused by the top thread not being in the tension disc or something in the discs( thread , fuss etc)
    Oct 24, 2009 | Sewing Machines
    Sewing Machines Logo
    380 people viewed this question
    Top Husqvarna Sewing Machines Experts
    Douglas Plant
    Douglas Plant
    Tally Girl
    Tally Girl
    Derek Massey
    Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
