Question about KitchenAid KESC307 Electric Kitchen Range
Kitchen aid glass cook top
A plastic bag melted on the glass top burner! How can I get this off?
  • 833 Answers
What I'd do is gently take a sharp razor scraper in a holder and scrape off as much as you can.  Then, I'd take a bit of WD 40 and work at it with a paper towel.  You can also try the low abrasive cleansers.  Thoroughly rinse before returning to service.
Posted on Nov 20, 2008
How do I remove melted plastic from top stove burner, kitchen aid oven/stove, branch new
Clean the stove so all food residue is removed. Take a single blade razor blade and very slowly scrape the edges of the melted plastic. Blade should be held at a low angle, and only a small amount should be cut away at a time. It will take time, but the plastic will come off.
Once clean, use the manufacturer approved cleaner to clearn the area.
You may want to try to turn the burner on for about 10 seconds on high, and then off to help soften the plastic. Be careful to not burn yourself.
Mar 08, 2015 | Kitchen Ranges
Own a KitchenAid gas range superba, how do i clean the burner, one of my front burners the gas flow is very low, the stove has the glass/ceramic top with no wells & no way to get to the burners...only...
You'll need certified stove technician to service you kitchen Aid range. You have low gas flow on one of the burner. The manual gas control valve behind the knob needs to removed and cleaned. If you have one cleaned then have technician clear all four of these manual gas valves. While he cleaning the valve have do a complete check up of you Kitchen Aid range. Dangerous for the home owners to do this procedure because flowing natural gas or propane. In a lot the states you'll need to be certified by the state to work with natural gas, gas stove, ovens, gas home heating units, etc. It differentially a no,no here.
It is not the burners, it is gas flow valves for the burners. Most of the burner are made of aluminum and I wouldn't use any harsh cleaners of them. Check with Kitchen Aid and ask them what is recommend for cleaning the burners. Also the top of the range isn't ceramic but porcelain, it glass that has been melt to the top hood of the range. Don't use scratch pads, steel wool or any thing that will mare the Periclean surface of your stove.
If you can get the aluminum burner out to clean them then do so. GB you Allison and I wish you many year cooking on your Kitchen Aid range. stewbison
walk softly up on this earth and she will good to you...
Aug 21, 2011 | KitchenAid Kitchen Ranges
Butter knife chipped burner - Amana black glass cook top
if it didnt crack or chip os not a hole it can be safe to use
Nov 08, 2017 | Amana AER5844VAS Stainless Steel Electric...
I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
Kitchen aid KECC507GBL3 electric 36in cooktop. Burner switch is out - cannot get glass top off. Have removed all screws from plate mountings on the sides. Is there a trick to this?
If it’s a range, there is usually a couple of screws that hold the front of the top down, remove the screws, lift the front of the top and pull it out from the back hinges. Install the new top, make sure there are no loose wiring.
If it’s a cook top then make sure that the power to the cook top has been turned off, open the cabinet and look up. There should be a couple of brackets that secure the cook top. Remove the brackets, carefully lift the top and set it on the counter top (put a towel on the counter top first). replace the glass top (make sure there is no loose or exposed wiring), set the cook top back in the counter, secure it with brackets as was before, and double check your work.
Thanks for contacting fixya.com
Jan 14, 2010 | KitchenAid Cooktops
My left two cook top burners will not turn on.
check fuses and pull out burner elements see if they are damaged if fuse blows when turned on make sure wiring to elements is not exposed I would also check the switches for elements, turn on one at a time
Dec 18, 2009 | Kitchen Ranges
I have plastic melted on my glass top (son let plastic bag touch hot burner). i can NOT get it off. any suggestions?
Getting the plastic hot again may allow you to remove the bulk of it. I'd use something wooden to scrape with. I'm assuming that the glass top you're talking about is an electric stove. You have this listed under the "Timers" category and not many of them have glass tops. Dabbing a small amout of acetone onto the plastic without touching the glass any more than you have to should help you disolve the plastic so you can finish scraping it away.
Dec 02, 2009 | Hardware & Accessories
I have a Kenmore stove and was cooking several things on stovetop burner and accidentally put a plastic bag of tortillas on top of hot burner and the plastic melted all over the burner. I soaked the burner...
We are factory authorized Kenmore service & parts suppliers. We have all the parts you might need.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with your model number and we will get the correct burner element out to you asap.
We look forward tow roking with you and getting you cooking again soon.
Nov 09, 2009 | Washing Machines
Replacing glass top stove HELP!!!
You can buy replacement tops for your range. Check with your manufacturer for local parts distributors or service locations and they should be able to find you one. There is also online part stores that sell them like http://www.partadvantage.com/store anywhere from 150-400$
Feb 04, 2008 | GE Profile JTP18 Electric Single Oven
Kitchen aid cook top gas. iginator consstantly firing with knoob off
strutz, you probabley got one of the valve switches wet when cleaning. It could of shorted out or it might be just wet. Pull the control knobs off the burners and take a hair dryer and go over the valves slowly. See if it stops the clicking. If not you will probabley have to change out one of the switches. Im not coming up with anything with the RGA365 model number. Try the above posted first...Catriver..post back.
Mar 12, 2007 | Sco RGA365 Gas Cook Top Kitchen Hood
KitchenAid KESC307 Electric Kitchen Range Logo
121 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
