Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Hotpoint dishwasher fdw20
Water not heating up fitted new heater element that did not work watching the cycle the only one that works nominally is the pre wash other cycle don't they run for about one hour no heat then empty drying light flashes about one minute before the end of cycle. can you help please.         dave.
  • moossette Nov 02, 2008
    I have an FDW 20, seems to go through full cycle but water does not get hot. Is element easy to access and change ?
SOURCE: dishwasher error codes please help
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Posted on Jul 21, 2007
SOURCE: HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Posted on Mar 23, 2008
IFIXALL
  • 868 Answers
SOURCE: FDW60 Fast and Delicate Lights Flash
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
Posted on May 23, 2008
  • 1462 Answers
SOURCE: hotpoint aquarius dwf30 dishwasher
you can plumb into hot but there are some snags
first hot water pressure is often a lot lower than cold so the machine may take a long time to fill
second if the water is too hot it will destroy the resin of the water softener and you will see brown marks on the crockery.
third it a bit uneconomical as you will use a lot of hot water
Posted on Jun 25, 2008
  • 1314 Answers
SOURCE: fdw20 hotpoint
run the water at the sink till its hot before starting the washer some lines will run cold for about a gallon before the hot water gets to the outlet depending on how far away the hotwater tank is
Posted on Feb 15, 2009
Hotpoint dishwash not heating the water but it not the eliment
Check and see if during the heating cycle there is voltage to the element. If not, you will need to replace the control board/module. from serial number 41011 part no is c00143209, to serial no 41011 part no is c00143207
Apr 21, 2014 | Hotpoint Dishwashers
Dishwasher repair
If this is the first and forth LEDs then i was told by a Hotpoint engineer that this means 'heater cut out due to overheat' and that probably the heater is just covered in limescale. If that is the case then running a descaler through the dishwaer on the highest setting should fix the problem and clean the inside of your machine to boot !
I guess this would happen if your machine is a few years old and you live in a hard water area.
Nov 12, 2013 | Dishwashers
Lights flashing hotpoint fdw20 dishwasher
Heater elemnt is gone cheep fix , you will need to order this lower element
Nov 26, 2011 | Hotpoint 24 in. FDW60 Free-standing...
My Hotpoint FDW20 dishwasher does not heat up and is washing cold. Could you, please, suggest a solution to the problem. Can you also forward me a circuit diagram for the machine along with a manual with...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 17, 2010 | Hotpoint Dishwashers
I have a Hotpoint Aquarius FDW 60 dishwasher. Crockery was with greasy smear on it. Since then the drying does not appear to be working. Seems the drying element has malfunctioned, can we replace this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
A bad heating element causes many problems in dishwashers…
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | Hotpoint Dishwashers
Hi,my hotpoint df 41 trips the mains every time it starts the heat water cycle.I assume the element is faulty.I have looked underneath and all seems dry and clean.Can i buy and fit a new element myself?
Yes, you need to remove the element taking note of the connections and wire colors. Also note the seals used on the element. Remember that sometimes a "cold" element does not show the fault and only once heated does the "short circuit" show. Take the element with you to the dealer as many different elements (shapes and sizes as well as electrical connections on elements are available).
Jun 01, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Whirlpool Dishwasher ADG7540/1
an ntc is very reliable. have you checked continuity thro the heater? other common fault is a dry joint devoloped on the control card - take it out and check for dry joints
Oct 02, 2008 | Hotpoint 24 in. HDA3400G Built-in...
BF162 DISHWASHER HOTPOINT
I think if you push the heated wash and heated dry button several times until all the buttoms light up this will fix your problem.
 A clean light that flashed repeatedly 7 times then off. Reset as above with the heated wash and heated dry buttons. You may then noticed a reduced flow from the pump so dissasemble the lower arm and water inlet assy.You may find it mostly plugged with foregin matter and some othe junk. Upon removal of that stuff and reassembly,It may work as new!
Feb 09, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishwasher element and thermostat
Check with multi-meter for power on heating element's tags. If it does get power, you should replace the heating element. In case of no power- you should replace the thermostat. Good luck !
May 31, 2007 | Hotpoint 23 in. BF41 Built-in Dishwasher
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
98 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
