Question about Coleman Powermate Powermate 5000W Generator
Powermate coleman 5000 gen. with subaru engine
I bought it brand new about a year and 1/2 ago. about six months ago i put gas in it. it would not crank. switch is set to on. choked it, opened up ,still would not crank. took cover off breather and romoved filter and sprayed a little starter fluid. it started and ran only when i continued to spray starter fluid. then it would die when i quit, today i removed the carb and bowl and cleaned it with gas and put it all back together. now i cranked it with full choke and it would crank for a second, then i open the choke, it would die, would not stay running on choke either. but after taking off carb. i could crank it , but before that it wouldnt crank at all. any info would really be helpful. thanks, troy - houston texas home of ike
  • 3 more comments
  • tb2830 Sep 17, 2008
    now i did add more gas and cleaned out the carb bowl. also dunked carb in gas and sprayed in with starter fluid. i was wandering about the mixture screws. could that be a problem also?
    i dont kow what happened to the manual. the warranty is of course out
    just the carb. im not sure which screw is which. one screw is kinda flat with a screwdriver slot and one is raise like a knob. i noticed the flat one has an arrow and it is matched up to the arrow on the carb body. the raised one looks like it only turns so far the it looks like it has a stopping point
    i bought it at lowes
    sure
    Genius:
  • 2,035 Answers
Please click on this link and get the get the owner's manual :
http://www.powermate.com/pdfs/2007/11/12/manual_pc0435003.pdf
.You need a service manual to guide to trouble shoot the problem ,please use this get one service manual:
http://cgi.ebay.com/small-a-c-generator-repair-service-manual-New-sealed_W0QQitemZ300201679371QQihZ020QQcategoryZ46412QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
Good luck...
Posted on Sep 17, 2008
    Brigadier General:
  • 6,966 Answers
If I may add....
Offhand and assuming you are leaning to a complete DIY (do-it-yourself), perhaps leave the air adjustment and the idle screws as they are. Without knowing the proper settings, it is possible to compound the problem. The air adjustment would affect the air/fuel mixture making it either lean or rich and in most likelihood further adjustments would not correct the issue. Same goes for the idle adjustment. It has been preset to run the engine at a specific RPM that is to maintain the frequency (Hz/cps) of the gen's output.
The issue seems just one, no fuel getting into the combustion chamber from the carbs. Pls try:
  • Verify that the carbs is getting fuel (fresh not the old/stale). Often they have a bleed screw at the bottom for draining the contents of the bowl;
  • use a carb/injector cleaner, though the correct procedure would be to overhaul the carb itself;
  • choke the throat opening (after removing the air filter and the base plate. Use your palm and cover the throat opening while starting/cranking. If your palm gets wet with fuel, then fuel is now entering, if not, then any of the jets are clogged. Spray again with cleaner to melt the gummed ups old gas residue;
  • continuously do the palm choking until fresh clean gas is drawn.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Master:
  • 726 Answers
The is mixture screws on the carb u have to have the fuel and air ratio perfect the best thing to do is screw the fuel in so its not getting to much but make sure not to little and the air out so it breathes then try to start it if it goes it will run ruff wait till it warms up and then adjust again
also i want you to check if the fuel lines are not blocked from sitting to long and the filter is free of dirt and not blocked
now here is a carby same as yours nearly but same set up look at the left of the carb see the first screw on a diagonal now the one behind that is what you want to adjust in and try bit by bit then if no good out and try again repeat if no go give me a yell back http://www.chads-minitruck-parts.com/subaru%20carb.JPG
  • 4,472 Answers
Yes that could definitely be a problem. Do you still have the manual for it? Also is the unit still under warranty?
Thanks,
Lee
  • 2 more comments
  • Lee A.
    Lee A. Sep 17, 2008
    The warranty is 3 years on the engine and 2 years on the warranty. Where did you purchase the unit as you may be able to have it serviced for quite cheap under warranty. If you still need assistance let me know.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 17, 2008
    How is the warranty out? If you only bought it a year and a half ago and it has a 3 year warranty? If you reconsider your rating I hope you will accept and rate accordingly as you should find my information at least helpful. I can assist you in either having to bring it to where you purchased it, if they don't handle warranty claims. Then you I can assist you in contact the nearest authorized service center.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 17, 2008
    Though the engine is a separate warranty though the engine manufacturer it also has a 2 year warranty on the unit through coleman.For warranty service: Call toll free 800-445-1805.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 17, 2008
    Then you will most likely want to call that toll free number and inquire about warranty service as you should not be having these problems with this new of a unit. Being that the unit is still under warranty this is your best option. Please reconsider the rating and accept and rate my solution accordingly.
    Thanks again,
    Lee
  • 3,037 Answers
The dirt in the gas settled onto the bottom, try mixing it up or putting some fresh gas in and taking the old out and let me know how that works
  • Benjamin Patri
    Benjamin Patri Sep 17, 2008
    yes, how much open are the screws and did you empty the tank of gas or just the carb?
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Where can I buy a wheel kit for a Coleman Powermate 5000 Genterator ?
Do an online search. I bought mine that way years ago.
No, I have no idea where.
Aug 26, 2014 | Coleman Powermate Powermate 5000W...
Can I install a avr (automatic voltage regulator) on my coleman 6250 (5000 watt continuous) gen set with a subaru engine. I know that some of the models come with the avr and some do not. mine did not have...
This is really not something you can do. There is a fair bit of engineering that would have to be done and then there is wiring and mounting, etc.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 10, 2009 | Coleman Powermate Powermate 5000W...
Looking for manual for generator...won't start
I had the exact same problem. There a few things you need to do first.
1) Make sure the fuel line knob is turned to the Open position; this knob is located under the gas tank.
2) Turn the power switch to on : it is a little red switch located near the pull-handle on the front of the generator. It needs to be on 'I' not on 'O'
3) Turn the choke lever on: it is a little steel lever with an arrow at the tip. Move the lever in the direction the arrow is pointing.
4) Make sure you have gas left in the tank: it may have evaporated or gummed up if you did mix in a fuel stabilizer before putting it away for storage.
If none of these things work , then you carburator may be full of water and gas lines gummed up.
These Gens need to be started up at least once a month to make sure they keep working properly.
Fred
Sep 28, 2008 | Coleman Powermate Powermate 5000W...
Coleman powermate 5000 gen.
I assume it is a hand start genset. The most common problem if it has been sat for a while is rust on the ignition timing flywheel. If you take the pullcord housing off (recoil) then you will see a big flywheel with what can only be described as a big forked prong with a couple of wires on it. This flywheel should be stainless steel and rusts when sat around for a while without use. Its job is to complete the circuit to the spark plug every time the flywheel passes the forked prong at a given spot on the flywheel, the faster the wheel turns the faster the spark hence the engine runs quicker. Clen the rust off with a releasing agent (wd 40) hey presto!!!!!!!!!!!
Sep 17, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
540 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
