Question about HSM 125.2hs Shredder
HSM 125.2hs Begins feeding then stops
This is an HSM 125.2hs shredder. When paper is fed into the unit it begins moving forward, stops, and then reverses. The top red led will go on and stay on until I turn it off and on again. The unit is oiled and I have opened it and cleaned it out. There is nothing that appears to be caught in unit but it acts as if it is jammed. It will reverse without a problem.
  • 35 Answers
There are three things that cause this problem.
1. a gear is broken which will cause only one cylinder to rotate.
2. on the non-driven side (opposite side of the gears) there is a electromagnetic sensor that rotates with the shaft. It detects rotation and overload. If this is out of place or damaged it will cause this symptom.
Posted on Feb 24, 2009
  • Shred Pro Jun 28, 2011
    I had the same problem and the circuit board above the electromagnet was the problem. The small black capacitor was bent and had to be lined back up with the magnet on the shaft. It took a bit of tweeking, but works like new now.
Have a NOVITECH paper shredder- PS-026/B2. When slide switch is moved to ON it starts shredding and won't stop automatically until switch is returned to OFF
LOOK INTO WHERE THE PAPER IS FED... THERE IS A TINY SWITCH THAT THE PAPER TRIPS WHEN THE PAPER IS FED INTO THE SHREDDER. THIS SWITCH IS SHORTED OUT OR STUCK INTERNALLY FOR SOME UNKNOWN REASON.
Nov 20, 2014 | Shredder Office Equipment & Supplies
How do you fix the Shredstar PS817c that is stuck in reverse?
If you want to try to resolve the problem yourself I suggest you use their Customer Service to help answer your question: Online Service Portal HSM of America
http://www.hsm.us/service/online-service-portal/
Jul 11, 2014 | HSM 1030 shredstar PS817C Medium-Duty...
Shredder is jammed and I've removed as much paper as I can. It won't go forward, or in reverse.
check and mak sure the eye is not blocked this will happen more if you use a paper that has a sticky back
Oct 24, 2013 | HSM ShredStar X5 Shredder
How can I clear a paper jam on a hsm securio b32 shredder when the reverse function does not clear it
On most shredders ideal unjamming would be by trying the reverse, if that fails there's 2 options: 1 - opening the unit by removing screws (usually 5) and using small narrow flat screwdriver carefully clearing out all the stuck paper/cardboard from in between two rollers, but be carefull and make sure the power cord is NOT plugged into wall socket. 2 - without dissassembling the unit spray some WD-40 into the shredders feed opening and let that cardboard soak for a while. WD-40 will soak into cardboard and any stuck paper and will loosen it, you might need to spray couple of times allowing to soak in between sprays, but this definitely does the trick. Once sprayed 2-3 times allowing to soak for at least 10 minutes between sprays simply swich the shredder on and use reverse and all stuck paper should come out. Be advised after unit was cleared you must use some spray oil to protect the blades. Once oiled allow unit to run in reverse for at least 2 minutes, the swich it off. 15-20 minutes later your shredder will be good as new!! Hope this helps ;)
Oct 16, 2013 | HSM SECURIO B32 Shredder
My paper shredder wont turn off
Shredders have sensors that tell it to turn on. Usually the there is a spring loaded button/sensor in the middle of the slot that you feed the paper in. Once the sensor button is pushed down, it thinks a piece of paper is being fed in and begins to turn the blades.
If your shredder won't stop running, I think the sensor button is stuck in the down position.
1) try pushing the reverse button for a while to see if it clears the problem.
2) if not, then unplug the shredder. Find the button/sensor near the middle of the shredder slot and with a tweezer, try removing any clogged scraps of paper near the sensor button to get it to pop up fully.
3) I've never seen a shredder with more than one sensor in the middle but if yours has more, make sure they are all in the popped up position when there is no paper in the shredder.
4) Plug the shredder back into the AC outlet and try it again. Good luck
Aug 08, 2010 | Office Equipment & Supplies
HSM AMA 125HS-6 Starts to shreed and abuptly stops. Red light comes on next to a circl symbol.
Thickness of papers is too much. Feed only 1-2 pages at a time.
To clear, pull paper back out. Run reverse, then forward, then feed 1 page at a time using a clean edge.
Sep 13, 2009 | Office Equipment & Supplies
Hsm 225.2 jerks in & out 2-3cm and wont eat paper!
try oiling the cutters...this helps out with the shredding of paper...also make sure properly mounted on bin, try resetting the shreddar, unplugging it and then plugging back in...check to make sure no paper or anything stuck in shreddar and make sure no broken gears..if this doesn't work and your shreddar is under warranty it would be a good time to call the warranty company
Apr 13, 2009 | HSM 225.2hs Shredder
Only runs in reverse
This is an issue with the paper feed sensor usually located in the center of the paper feed slot. If it is mechanical you need to jiggle switch in and out to free possible interference behind switch (piece of paper or debris) if it is an electronic sensor you more than likely have a bad sensor or pc board. You will need to contact manufacturer for any further assistance.
Mar 16, 2008 | Tech Solution TS-4500 Shredder
HSM 125.2hs Shredder Logo
441 people viewed this question
Top HSM Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
ray gallant
Tom Chichester
Are you a HSM Office Equipment and Supply Expert? Answer questions, earn points and help others
