Question about JVC GY-HD200U Camcorder
Is it too late to drop the letterbox?
My client shot with the "Letterbox" option on while shooting a segment and didn't realize it until he got back and was logging shots before the edit. 2 identical cameras were used to shoot the footage. One with letterbox and one without... They are in the same show right next to one another...
Using the JVC GY-HD200 camera to play back the footage is there a way to turn off the "Letterbox" and play the footage without the "Letterbox" on? This is a national show and he would sure like to make them look alike...
I am editing on a Avid Media Composer and I can put a 16x9 mask over the edited footage that doesn't have the mask but that sure causes alot of rendering time.
Any ideas? Please help!!! Thanks guys Bud, Peoria, Illinois
5 Suggested Answers
SOURCE: When I connect the camera with a firewire cable there is no response
have not verified yet, but manual suggests that unit must be plugged into DC power to use the ieee 1394 link
Posted on Jan 06, 2008
  • 3 Answers
SOURCE: I have to keep rendering after every little edit in final cut pro
I found a video online that helps with this problem. It might be due to your render settings. Also, some edits do in fact need rendering, some edits do not. Take a look at this video and I hope it solves your problem:
Posted on May 24, 2009
SOURCE: jvc everio editing software
Pinnacle version 11 treats everio files absolutely normally. Just move them to the PC and "import media from device" in the drop down menu. You can edit (sound and vision) and produce excellent DVDs.
Sony Vegas is also good at MOV files.
Incidentally, I have foud the Everio picture MUCH improved if I set the "shutter speed" to "sports"
Posted on Aug 28, 2009
  • 69 Answers
SOURCE: Software to edit MPEG2 format film
try the software that came with the camera if not then go to Everio and see if they hae some patches to download good luck
Posted on Sep 21, 2009
Using standard on tv remote and normal on cable remote both settings crop the edge of the picture
TVs that use cathode ray tube (CRT) cannot display the correct aspect ratio for movies and modern TV broadcasts unless it is in letterbox form. Unfortunately most of the older CRT TVs do not have a letterbox setting.
Dec 08, 2014 | Televison & Video
My tv is showing in letterbox form. How can I fix it?
There is nothing you can do. The fault is with its main power regulator section circuit inside. Contact any experienced service technician.
Dec 27, 2012 | Orion1934 19" TV
Tv is in letterbox format
If you are using a box for signal it determines if picture is 4x3 (small) or 16x9 (large)
Mar 19, 2012 | RCA Televison & Video
I am having trouble getting the screen size back to full size. We used the zoom but that makes the picture to big. My TV is a Auria EQ5588
Hi, The " Size " of a flat panel tv ( when not in zoom mode ) is actually controlled by your programming, if using an hdmi cable from an Hd/Blu-ray player-then whatever format the disc was recorded in is what you'll see ( widescreen/letterbox ) black bars at top & bottom of scrteen ) or full screen. Local over the air digital H.D. brodcast's from networks varie from full screen to letterbox-satellite and cable that are standard definition will almost always letterbox a screen for you. Using T.V.s tuner may alleviate most of the issues. Good luck and I hope this helped. Prodzilla
Apr 10, 2011 | Televison & Video
I purchased a DVD that states: Widescreen Format (Aspect Ratio 1.85.1) I'm unable to get 'widescreen/letterbox'. The movie shows up full screen or a 'stretched' view. All other movies I've...
On the DVD recorder remote: press function menu button: enter setup screen - scroll down to connection - TV aspect - select either 16:9 / 4:3 Letterbox / 4:3 Pan&scan. If you are using an older TV which is not a widescreen, set the aspect to '4:3 Letterbox'.
You should now be able to view your DVD movies from this machine through a 4:3 standard TV in letterbox format. (some DVDs do not allow pan&scan so letterbox or widescreen is recommended). Very rare that a DVD title is not compatible with 4:3 TVs. I assume your deck is set to output 16:9 aspect by default.
I find this is the cheapest and easiest solution and can save lots of dollars in service call-outs. You can always reset the unit back to shipping condition later if you need to, or in the rare case of digital channels disappearing from your tuner memory.
Jan 09, 2011 | Panasonic DMR-EZ485VK DVD Recorder/VCR
LG 37lH20 LCD Aspect Ratio Problems
Not ur tv it the dvd format,tries it with other dvd.
Nov 23, 2009 | LG 37LH20 37 in. LCD HDTV
I cant get the whole picture to fit the screen. When I watch games the score is cut off.
This is most likely a setting on your TV, like stretch, or fit, or possibly on your cable box, or dish receiver. look at your dish or cable box settings and turn off any screen adjustments. Example under wide screen setting is strech , zoom, letterbox (choose letterbox).
The TV has these settings as well.
Aug 24, 2009 | Samsung LN46B650 46/49.5 in. LCD HDTV
Normal and letterbox
"Normal" looks "streched" because the origin of the video is normal, so it gets streched. If you play a "letterboxed" material (may be a DVD) it comes compressed, (vertically streched) so when you play it in letterbox it streches up to the rigth aspect ratio. Take a look at it in wikipedia.
Jul 14, 2009 | LG 37LH40 37 in. LCD HDTV
Camcorder Widescreen Recording Issue
THERE IS REALLY NOTHING YOU CAN DO as your settings conflict with each unit connected
Nov 13, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
JVC GY-HD200U Camcorder Logo
47 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
