Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Carnero when i turn it on everything go's on but the comp.there is no voltage going to the comp.
    Problem Solver:
  • 25 Answers
Verify that the contactor rely is closing. if not possible low or high pressure switch has tripped. some are push button resetable some not. does the outdoor fan run?
Posted on Nov 22, 2008
Muz series led flashes twice
58 volts is not enough to run a compressor either your meter / reading is wrong and there should be no voltage on compressor terminals when disconnected .
Nov 22, 2014 | Heating & Cooling
Low voltage at compressor!
My parts lookup too has no images available for you refrig but i believe it to be a GE Profile with a fresh food fan (and air duct down the center of the fresh food side). All fan motors are 12vdc and run off the Lowvoltage side of motherboard. i assume you are checking voltage to comp from motherboard? How did you check relay?? Have you axcessed motherboard?? On the top of (I say top-- i belive its mounted horiz on yours but all the small wires are on the right) is all the low voltage fan motor, damper, control wiring On the bottom (or the left) side of the motherboard is the larger line voltage wiring. The connector with 3 wires is labeled def -- comp---line it should be blue. Try jumping L1 to comp. ((Just so ya know Def will energize the def heater regardless of compartment temp it does have a bimetal but it only a safety set at 100deg in case relay on board welds shut---it monitor evap compartment, frz, fresh food, (two seperate in FF) in your model))
Oct 11, 2007 | GE PSI23MGN Side by Side Refrigerator
Rudd air conditioner outside fan won't start
I just had the same problem. I replaced the motor with no luck. It turned out to be a bad capacitor. If it is a dual capacitor, three prongs on top, it also starts the compressor. It is recommended to replace the capacitor anytime you replace a motor. I would try replacing the capacitor first. It is a lot cheaper that a new motor. If that does not fix the problem then you can get a motor. No harm, no foul. The slow start of the motor is a common symptom of a bad capacitor. The motor is not getting enough voltage. The capacitor increases the voltage like a transformer. It will boost it to almost 400 volts, depending on your unit.
Jun 21, 2012 | Heating & Cooling
Hello, no cold air The fan out side is not turning on... inside the unit is a brown connection box all the wires go in... on top is a contact switch... when I manually make the contact buy pushing do to...
You have an issue on your low voltage side. More then likely its an open safety switch or comp delay on circut board if your curcut board has one. Could also be a bad stat or blown transformer. You need to verify you have 24v power on your low voltage side first things first. If you have 24v your transformer is ok, if not start there.
May 16, 2011 | Weather King 10AJA6001AH Air Conditioner
The unit turns on, but the mode light (cool and fan) blinks and the compressor does not seem to turn on The fan works normally as does the sweep function.
possible bad capicitor/compressor-comp. start relay. placing a voltage sniffer at wires going to comp. will verify if compressor is getting power.
Jan 16, 2010 | Heating & Cooling
Kenmore 54701 (70 pt) dehumidifier is not prerforming properly
could be a bad humidistat or a bad PTC relay on the compressor, check for voltage going to compressor, and check neutral continuity, if there is both then you have a bad compressor, check warranty on comp replacement, if no voltage then the humidistat is probably bad
Jun 13, 2009 | Kenmore 54701 Dehumidifier
SAMSUNG LCD TV (broken high voltage inverter?)
Sometimes a TV screen will illuminate for a moment when first turned on and then go black. Sound will be OK. Check electrolytic capacitors in low voltage power supply. There will be 2 to 4 around 1000 to 2200ufd. Inspect for caps that look like the tops are swollen or are near sources of heat. What happens is the inverters that illuminate the screen draw a lot of current when the TV is first turned on. Power supply cannot supply the amount of current needed with defective caps. Inverters will then shutdown and not try to restart until TS is turned off then back on. Checking output voltages will look normal when measured with this symptom. Caps are cheap and easy to replace.
Sep 14, 2017 | Samsung Televison & Video
EMACHINE T6534 COMP. WANT BOOT . TRYING TO CHANGE V-CARDS
This could be a few things though if you have already checked the memory and HD. The next thing I would tell you is that you should check the cpu. Also make sure that everything in the BIOS is set to the default settings when you start it.
Feb 04, 2009 | eMachines T6534 PC Desktop
Comp not reading montor
It sounds like the on board video has failed. I would try installing a video card on the motherboard. Then in the bios at start up, disable the on board video, so it will use the video card instead.
I hope this helps and thanks for using FixYa,
Eric
Jan 25, 2009 | eMachines T6534 PC Desktop
Comp won't power on
Hi KlubeT,
I would suggest replacing the PSU (Power Supply Unit).
Gerry
Jan 31, 2008 | Dell OptiPlex GX270 PC Desktop
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
46 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
