Question about Nike Lance Armstrong Limited Edition Lance 4 Watch
When i changed the battery the watch says error so cannot set time battery lite flash on of recall button seems not to be all the way out out watch is lance 4 thanks
  • pantanistar Sep 19, 2011
    done all that before still showes error
    still waiting for more assistance advice did not work
  • 957 Answers
Try to press and hold the power button of your watch for 30 seconds. Then turn it on again.
Thanks.
Posted on Sep 19, 2011
  • 6,694 Answers
Press and hold 4 buttons on the four corners at the same time for 3 seconds to reset the watch after battrey replacement. check the last page of the manual for the same.
http://www.nike.com/timing/extranet/product/os_alticomp/osac_manual_eng.pdf
If it doesn't help then try another new battrey.
OK
  • Electro Med Services
    Electro Med Services Sep 21, 2011
    hi,
    If the reset is not functioning the you have to you have to contact the authorise service centre for Nike. There is no user serviceable part in side. The watch have some software error.
    OK
Need to set just the time on a timex WR100M mens watch
SETTING
  1. First, find the regular time mode by pressing the MODE button until the time (with the date at the top) shows.
  2. Press & hold the SET button until the word ENTER disappears and is replaced by the word TIME. Release that button. You'll notice that at the top of the display, the words SET T1 or SET - T2. This is where you select between setting the 1st time zone or the 2nd time zone. Select between T1 or T2 by pressing the RECALL button or the STOP/RESET button.
  3. Press either the MODE or the START/SPLIT button. You'll notice that whatever is blinking is what you can change. You can make the changes by pressing either the RECALL or the STOP/RESET button. You can change the Seconds, the Hours, the Minutes, the Month, the Date, the Year, and choose between 12 hour (civilian) or 24 hour (military) time. If you keep MODE or START/SPLIT button, you will go through all the things you can change and start again at the beginning. The START/SPLIT button goes through these things forward, and the MODE goes through the backwards, so if you pass something and want to back up, just switch buttons. In the same way, the RECALL changes things by making them larger, and STOP/RESET changes them by making them smaller, so if you accidentally pass the number you're trying to set it to, just switch to the other button and go back.
EXAMPLE OF SETTING THE WATCH Suppose you want to set the hours and the date in the 2nd Time Zone. (Just as an example, but setting any other time or date settings would be the same.)
  1. Press the lower left button on the side (MODE) until you see the date & time.
  2. Press & hold the lower right button on the side (SET) until the word TIME appears on the display, then release it.
  3. If SET T1 is showing, then press & release the upper right button on the side (RECALL) to change it to T2 (because we're wanting to set the 2nd Time Zone we'd leave this unchanged if we wanted to set the 1st time zone, T1.)
  4. Press & release the lower right button on the face (START/SPLIT) twice, skipping the seconds. You should see the hours flashing.
  5. Press & release the upper right button on the side (RECALL) repeatedly until you have the hours position set to what you want it to be. If you pass the hour you want, go to the lower left button on the face (STOP/RESET) and press & release it to back up.
  6. Press & release the lower right button on the face (START/SPLIT) three times, skipping minutes and months, so that the date begins flashing. Press the RECALL button until you have the date you want. (You can go backwards by pressing the STOP/RESET.)
  7. When you're done, and you've set everything you want to, press & release the SET button once to tell the watch you're through setting and to lock those settings in.
Nov 23, 2015 | Timex Ironman Watches
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
Oct 04, 2014 | Kenneth Cole Unlisted Ana-Digi watch
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    I have an activa lithium water resistant watch #AD632=010. The light works but the digital clock doesn't.
    If there is no time displayed the watch is just dead. You can try a new battery or just get a new watch.
    If you can't seem to set the time: Press and hold Mode until it flashes a time and the letter A . This is how you set the alarm. Press mode again and you can set the time. start stop button moves between seconds, min., hrs, and days. reset changes the value.
    Jan 28, 2010 | Activa Watches
    I need a manual for my casio wave receptor
    For all those who lost their Casio watch manual. Follow this link, fill in the requested details and download manual. http://world.casio.com/wat/download/en/manual/
    Jan 14, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    I have a Starter Brand Watch that did not come with a manual. I can't seem to get the chime to stop chiming on the hour.
    Just bought a STARTER Sport Watch Model# STW14 @Walmart
    TO CHANGE TIME:
    1. Press and release MODE button quickly 3X in a row(top middle no.(Seconds will flash)& change Seconds by pressing START button 2. Press & release RESET button 1X quickly(Minutes will flash) & you change Minutes by pressing START button 3.Press & release RESET button 1X quickly(Hour will flash) & you change Hour by pressing START button. 4.Press & release RESET button 1X quickly(Date will flash) & you change Date by pressing START button.5.Press & release RESET button 1X quickly(Month will flash) & you change Month by pressing START button 6. Press & release RESET button 1X quickly(Day of week will flash) & you change Day by pressing START button 7. Press & release MODE button 1X quickly to return to Normal use
    TO SET ALARM: 1. Press and release MODE button quickly 2X in a row(Hour will flash)& you change Hour by pressing START button 2.Press and release RESET button quickly 1X (Minutes will flash)& you change Minute by pressing START button 3. Press & release MODE button 1X quickly to return to Normal use
    TO VIEW MONTH & DAY: 1. Press & Hold START button 2.Just Release START button to return to normal use.
    TO USE STOP WATCH: 1. Press and Release MODE button quickly 1X 2. To START stop watch: Press START 1X quickly 3. To STOP Stop watch: Press Reset button 1X quickly 4. To RESET Stop watch: Press & Hold START button and press RESET button quickly @ the same time, 2X in a row 5.Press & Release MODE button 1X quickly to return to Normal use
    Sep 12, 2009 | Bulova Watch
    Cannot change from 24 hour to 12 hour also did not change to daylight savings time
    To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
    Mar 08, 2009 | Timex T5G341 Sports Radio Control Watch
    Armitron Watches
    From the time telling mode press the set button the seconds will flash.
    Press the mode button the hours will flash
    Press the adjust button to change the hours
    Press the mode button the minutes will flash
    Press the adjust button to change the minutes
    Press the mode button the month will flash
    Press the adjust button to change the month
    Press the mode button the date flashes
    Press the adjust button to change the date
    Press the mode button the day flashes
    Press the adjust button to change the day
    Press the set button when done.
    Mar 11, 2008 | Watches
    Acqua Indiglo Digital Watch
    My watch has 4 buttons (2 on the left, 2 on the right) plus the "Indiglo" button. Use the "Mode" button (lower left) to move between the time and the stopwatch. When seeing the stopwatch, hold the "Mode" button. This will get you to the alarm setting mode. Press the "Mode" button again to switch to the time setting mode. Use the "Start/Stop" button (upper right) to move from seconds > minutes > hour > date > day of week. Use the "Spl/Reset" button (lower right) to change the numbers.
    -AP
    Dec 04, 2007 | Watches
    How do I change time on timex watch?
    These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
    These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
    TIME AND DATE
    1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
    2. Press ADJUST to set SECONDS to zero.
    3. Press START/STOP to select MINUTES.
    4. Press ADJUST to change.
    5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
    6. Press MODE when done.
    7. To display DATE from Time display , press START/STOP.
    8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
    9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
    ALARM AND HOURLY CHIME
    1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
    2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
    4. Press ADJUST to change.. Press MODE when done.
    5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
    CHRONOGRAPH
    1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
    2. With time displayed, press MODE to select Chrono Mode.
    3. Press START/STOP to start.
    4. Press ADJUST to view lap time. Press again to sesume lap timing.
    5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
    6. Repeat for successive laps.
    Have fun! - Not a bad watch for the money! - - Silver Bullet
    Mar 16, 2007 | Timex 5B841 Wristwatch
    Nike Lance Armstrong Limited Edition Lance 4 Watch Logo
    228 people viewed this question
    Top Nike Watches Experts
    Ansel Alberto
    Ansel Alberto
    TIME TRACK SERVICES
    TIME TRACK SERVICES
    Are you a Nike Watch Expert? Answer questions, earn points and help others
