Question about Epson CX8400 All-In-One InkJet Printer
Replace ink cartridge
I replaced ink cartridges cx8400 but getting message to replace them
  • 4 more comments
  • Anonymous Sep 16, 2008
    Printer wont recognize 2 of the 4 just replaced cartridges. Will not work is new.
  • Anonymous Oct 28, 2008
    I guess I should have bought HP.
  • Anonymous Oct 29, 2008
    replaced cartridges still won't recognize them. Scanner and printer now worthless.
  • bmcleod00 Nov 05, 2008
    Yep--same thing happening to me. The computer SAYS that the ink is now full, but my pages are coming out blank.
  • kmacrod Dec 18, 2008
    I replaced the black ink and keep getting an "error" message that tells me to replace the ink.
  • ByDBay Apr 08, 2009
    Be warned that this is NOT a printer that you want. CX 8400 is a piece of junk!!! I called the company, including the president (John Lang), a PR person fielded my call, and this company should be put out of business. You will not find any answers here.
    They do not work nor work well with 3rd party ink! They do not work unless all cartridges are full or near full. You do the math. You don't save a thing by buying Epson. Buy from some other company.
    ByDBay
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
Took printer back- power up and take all carts out in sequence that would not register, then put them back in sequence- works fine now! At one time you could not do this with Epsons but it seems you can do so now. Printer happy- me happy- £50 worse off as bought another set of ink carts so I won't get caught out again with no ink. However given one black cart for my trouble so happy again.
Posted on Dec 06, 2008
How do I remove the black ink cartridge to put in a new one?
1 Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. 1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you're replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner. 3. Open the cartridge cover. 4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.) 6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge. 7. Remove the yellow tape from the bottom of the cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. 8. Insert the new cartridge into the holder and push it down until it clicks into place. 9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place. 10. Close the scanner. 11. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. Caution:
Never turn off the Epson Stylus CX8400 Series while ink is charging or you'll waste ink.
If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
Nov 24, 2010 | Epson CX8400 All-In-One InkJet Printer
I have an epson cx8400 and i replaced the black ink cartridge but theres an error message saying that i need to replace other ink coartridges. I just want to print in black, how do i bypass the error...
hello
i have this link below that gives you allinformation about your Epson printer. specifically the manual , required for review to address the issue with the ink cartridge error.
Run a Printer Check A printer check will help you determine if the Epson Stylus CX8400 Series is operating properly. 1. Turn off the Epson Stylus CX8400 Series and your computer, if connected. 2. Disconnect any connected USB cables. 3. Load plain paper in the sheet feeder. 4. Press Setup. 5. Select Maintenance and press OK. 6. Select Nozzle Check and press OK. 7. Press cx7400_cx8400_ug.1.109.1.jpg Start. 8. The Epson Stylus CX8400 Series begins printing the nozzle check pattern. • If the page prints, your Epson Stylus CX8400 Series is operating. Your problem may be caused by your computer, cable, software, or setting selections. Check for additional solutions or re-install your software. If the pattern on the page has gaps, clean or align the print head. • If the page does not print, the Epson Stylus CX8400 Series may have a problem. Check for additional solutions. If they don't work, contact Epson.
general= http://www.epson.ca/cgi-bin/ceStore/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342
manual = http://files.support.epson.com/htmldocs/cx84__/cx84__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Nov 13, 2010 | Epson CX8400 All-In-One InkJet Printer
I have an Epson CX8400 and have replaced the Epson ink cartridges with non-Epson ink cartridges. This has worked in other Epson printers I have owned, but this printer keeps coming up with error messages...
It sounds like the cartridge chips are incompatible so you've probably been sold/sent the wrong cartridges.
It's possible that the printer you have is a later version with an updated firmware which has been programmed to refuse cartridge chips that were compatible with the first printers produced of this model but as the CX8400 is a relatively old printer I'd be a bit surprised if that were the case.
It's also possible that the cartridge chips are badly aligned, soiled (ie: dirty), or that the contact wires in the printhead (the thin/delicate wires that make contact with the chip when the cartridge is installed) are damaged.
Easiest way to tell if the cartridge chips are the problem though is to get a completely different cartridge, preferably some originals and see if they are accepted or not.
Hope that helps.
Martin
May 21, 2010 | Epson CX8400 All-In-One InkJet Printer
Ok I have a cx8400 all-in-one Epson printer. I was out of black ink so I started using composite black. Also ran out of color ink so I bought the black cartridge and installed it. Now the printer says i...
If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement. You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expendedI have come across this issue many times and unforunately you have to replace the colour carts in order to continue to use the printer.
Sep 12, 2009 | Epson CX8400 All-In-One InkJet Printer
How do I change the ink cartridges
1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you’re replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner.
Warning:
Never turn off the Epson Stylus CX8400 Series while ink is charging or you’ll waste ink.
If you remove an ink cartridge for later use, protect the ink supply area from dirt and dust and store it in the same environment as the Epson Stylus CX8400 Series with the label facing upward. Note that there is a valve in the ink supply port, making covers or plugs unnecessary, but care is needed to prevent the ink from staining items that the cartridge touches. Do not touch the ink cartridge ink supply port or surrounding area, and do not store the cartridge upside down.
If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
got this from the Epson Site
Jul 29, 2009 | Epson Stylus CX4800 All-In-One InkJet...
I have an Epson CX8400 printer and I just installed new ink cartridges (genuine Epson)all four and I get the error message "cannot recognize ink cartridges".
Try the following:
1. double check the part numbers of the cartridges and also their expiration date.
2. reseat the cartridges
3. after you place the cartridges back, close the scanner part and press and release the stop button.
4. If same issue, either an issue with the cartridge(s) involved or the printer itself
Hope this help
Feb 25, 2009 | Epson CX8400 All-In-One InkJet Printer
No B/W print while black cartridge is full.
Your printer and its software will let you know when an ink cartridge is low or expended.
If an ink cartridge is low or expended, you see a message on the Epson Stylus CX8400 LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement.
NOTE:
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the steps below to replace one or more ink cartridges that are low on ink, expended, or too old:
1. Turn on the printer.
If you're replacing a cartridge before you see a message on the LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
CAUTION:
CAUTION:
Never turn off the printer while ink is charging or you'll waste ink. If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
Feb 02, 2009 | Epson CX8400 All-In-One InkJet Printer
Ink
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. 1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you’re replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner. 3. Open the cartridge cover. 4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning:
Nov 10, 2008 | Epson CX8400 All-In-One InkJet Printer
Epson printer CX8400
Let me know if you find it--my computer and the printer show that my ink cartridges are full, but blank paper comes out when I try to print.
Jul 23, 2008 | Epson CX8400 All-In-One InkJet Printer
Expson CX8400 All-in-one printer
I had a problem with one of my Epson ink cartriges and called the company and they replaced it for free. Also many companies that sell knock off ink cartridges now have fixed the problem and now they are recognized by the printer.
Jul 11, 2008 | Epson CX8400 All-In-One InkJet Printer
Epson CX8400 All-In-One InkJet Printer Logo
166 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
