Blotted screen in my hp laptop - Computers & Internet
    Novelist:
  • 78 Answers
1.Locate the problem pixel. Display a true black image on your HP's monitor. You can do this by playing a DVD on your HP laptop, and pausing it on the black screen just before the movie starts. Once you bring up a black image on screen, the stuck or dead pixel should be visible.
2.Try applying direct pressure to the problematic pixel. After you've located it, turn off your laptop. Place a soft cloth or rag over the pixel to avoid damaging your screen. A soft chamois works well. Using the tip of a pen, apply gentle pressure to the pixel. You don't need to press hard, as too much pressure can crack or scratch your screen. While applying pressure, boot up your laptop. This should force the pixel to begin working properly.
3.Tap the pixel. With your Toshiba booted up and an image on the screen, gently tap the pixel with the rounded end of a pen cap. Tap hard just hard enough to see a small white flash on the screen. Tap your HP's screen until the pixel begins working properly.
4.Download a stuck pixel program. Several programs, including JScreenFix, UDPix and Pixel Protector, are available for download and can help fix a malfunctioning pixel. These programs display rapidly changing colors and images on your screen. The flashing colors and images can force the pixel to begin functioning properly.
5.Contact HP. If none of the above methods work, your screen may have a pixel that is truly dead. If that's the case, the only option is to replace the display completely. Contact HP customer support at www.hp.com to find an authorized repair service near you.
Posted on Sep 19, 2011
SOURCE:
I have a slightly cracked screen in the top right hand corner of my laptop screen, can it be fixed and how much for roughly?
No, it can't be fixed, the lcd screen must be replaced. Including the labor it will cost you more than the netbook is worth so either try to find a sh screen and replace it yourself (just a screwdriver is needed) or just junk it and buy a new one.
Jun 23, 2010 | Acer Aspire One Netbook 8.9" Notebook
Black blob on bottom rh of screen,vertical & horizontal lines
The blob is a phisically damaged part of the LCD screen. Unfixable, the screen must be replaced and it will be expensive.
May 04, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
Hp 3310 photosmart - ink system failure 0xc19a0013
Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
If this doesn't work let me know.
Dec 20, 2009 | HP Photosmart 3210 Printer
Screen cracked
It has to be replaced, it's not repairable.
Dec 09, 2009 | Acer Aspire 3690-2196 Notebook
Every other line prints terrible. Does anyone know how to solve this problem?
Remove your ink cartridges and blot on a damp paper towel, then blot on a dry part of the towel, if you don't see a solid line on the dry one blot some more on the wet one. You just need to clean the cartridge surface.
Nov 17, 2009 | HP DeskJet 940c InkJet Printer
Message on my printer says (press entre to align
You need to blot the cartridges on a paper towel and make sure all the colors are showing, It won't complete the alignment until it can see all the colors on the alignment sheet. Sometimes you need to blot on a damp paper towel to get them flowing.
Oct 30, 2009 | HP PSC 950 All-In-One InkJet Printer
Ink blots deposit onto feed rollers which in turn transfers to all new prints
Most likely you have a leaking print cartridge (toner cartridge). Does it have the same problem if you use the Manual Bypass tray?
It could also be a worn fuser sleeve that is causing the print defect...the fuser would need replaced in that case.
Sep 30, 2008 | HP LaserJet P2015n Printer
Screen Readout
yes screen readout is bad... u need a new screen
May 01, 2008 | SanDisk Sansa E280 MP3 Player
Possible Crack/Spillage in LCD Screen
I'm afraid you need to replace he LCD screen of your laptop. Replacing LCD screens is a bit complicated, that I suggest you send it to the Manufacturer's Service Center if it is still under warranty to avid voiding your units other warraty.
Hope this helps.
If it does, please vote. Thanks.
Apr 29, 2008 | Lenovo 3000 Y410 Notebook
Open Questions:
Computers & Internet Logo
229 people viewed this question
Ekse
Alun Cox
