Can I override the color option on my Brother 240C (color empty or low and will not allow printing) so that I may do b&w only printing? I just replaced the black ink cartridge!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Goto File
Print
right click on printer
Properties
printing preferences
choose black
Posted on Sep 17, 2008
I NEED MAGENTA COLOR TO PRINT DOCUMENTS IN BLACK?
No. You need only the black cartridge. However, if your M cartridge is empty, it will not allow you to print. You can fool the printer into believing that your M cartridge is not empty by taking it out from the printer and putting an electrical tape/ black (light-absorbing) tape on the cartridge's 'eye' - which is at the 'back' of the cartridge through which you can actually 'see' the ink.
Dec 27, 2010 | Brother MFC 240C All-In-One InkJet Printer
My brothers mfc 240c printer wont print because one ink is not full but it has black
You need to have ink in all cartridges to print. You can put a small electrical tape over the little window on the cartridge to print with empty inks, but you risk an air bubble in the ink tubes. If you don't care about printing color at some time, just cover the window on empty carts.
Apr 20, 2010 | Brother Multi-Function Center MFC-240C...
Black is not working in my brother mfc-240c printer
did you use genunie brother black ink cartridge?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
Try the forum, there are alot of issues like yours.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brother mfc290c not printing incomeing faxes or copying anything new printer 3 months old paper comeing out blank new cartridges
Did you use Brother Genuine Cartirdges????
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
If you find this information helpful, pls rate me.
Feb 17, 2010 | Brother Multi-Function Center MFC-240C...
Brother 240C= Replacing 1 cartridge only,leaving others empty. Will not print!!! Must I replace all cartridges or can I bypass in system memory Much Thanks
You must replace all cartridges.
Make sure it is Genuine Brother Cartridges.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
This is the only advice I can give you. If you find this helpful, pls rate me.
Feb 05, 2010 | Brother MFC 240C All-In-One InkJet Printer
Have a MFC-240C used INNOJET compatible cartridges. display said magenta empty, opened it up, cartridge had leaked. replaced with new INNOJET. No magenta ink is printing. CLOGGED????? what to do? THNX
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
My brother MFC 240C was set for printing only black and white, since I had only installed a black cartridge. Now I have installed the three color cartrdiges also. How do I change the settings to print...
You have to change the settings in your print driver. In Windows XP or Vista, go into the Control Panel and the Printers & Faxes applet. Right click on the Brother print driver and select Properties. In one of the tabs there should be an option for either Grayscale or Color printing (probably under Color Management) -- change this to Color and then click OK or Apply to save the changes.
By changing it in the print driver settings, the change should take effect for all programs that you print from.
Jan 02, 2010 | Brother Multi-Function Center MFC-240C...
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
Wont copy in black because color cartridges are empty
I'm sure you're using the Blue button to make the copy as it should do B/W copies only.
Double-check that black cartridge is not empty.
If the printer was connected to computer then we could have used diagnostics software.
So we start with a workaround.
Check if its display menu has any option of Ink cartridge level reset or something like that. If it has then do the reset.
If there is no such Menu option, the while the printer is On, open the compartment of printer cartridges and take out the 4 cartridges
and put it back.
Does any option in display Menu comes asking if cartridges are replaced? answer yes if it asks.
Now try to do a copy.
Hope this helps.
If it doesn't work then a question, how many days before the printer was last used?
May 30, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother Multifunction center, receiving documents, but not printing, being told that color inks are low, do not use color ink never had, original from purchase, I only print in black and white, what can I...
If it show low or near empty it still print.
If it show empty it not print.
You can use black tape cover at ink catrige on position of sensor.
Many people do like that it work.
If not work send it to service center. it hardward problem.
Dec 09, 2008 | Brother Multi-Function Center MFC-240C...
116 people viewed this question
jasbo
jasbo
