Question about Honeywell Heating & Cooling
Thermostat message battery low. Put in two new batteries and it will not reset or start. Lost Power during storm and cannot get it going again.
  • 706 Answers
Let me see if I understand your question.. your thermostat indicated the batteries needed to be replaced so you changed them with new ones.. With new batteries, you cannot get your thermostat to initialize or program correctly and as a result of that, you cannot get your AC system to start up.. If that is true, please provide the Honeywell Model # and verify the batteries you installed were Ok,...
Will attempt to assist once you've provided this info..
( on an off chance, have you checked the fuse or cuircuit breaker for your AC system to make sure it has power available?) This is especially important after a power outage..
Posted on Sep 17, 2008
TV remote won't work after changing batteries
When battery is changed, all the previous settings will be lost from the remote control. You should once again set it to your device, using codes.
Jan 10, 2013 | DISH Network Televison & Video
I have a Maserati dashboard message that I don't know what it means.
The vehicle computer can sense low voltage, so is warning the driver the care is about to fail. Replace the battery with a new one and you should be good to go. The computer will reset once the power is cut off during the battery switch, and reboots during the new battery power up.;
Sep 10, 2012 | Maserati GranTurismo Cars & Trucks
pknab, I have the same problem. And it comes down a few things: 1) the flashing 1:00 indicates that you've lost power, and the system needs to be reset. 2) Reset means taking out the batteries for longer than 5 minutes. 3) You have to change your filter monthly. There's one in the cold air return and another one in the furnace. If you don't, your FURNACE may be causing number one (my conjecture). 4) We had an electrical storm 2 days ago--nothing else in the house lost its sense of time...but...well...the online operating manual is difficult to find try or (but it doesn't tell us this stuff...I'm still looking for the meaning of the EEE in the display..perhaps I have repowered the thermostat/furnace in the wrong order).
Dec 07, 2010 | Honeywell Programmable Thermostat Heater
Recently, the power went off during a storm and now suddenly my thermostat stopped working. I changed the batteries and it worked, but now I'm changing it every couple of days. The batteries used to be...
You have lost your a/c power to your T stat.
Have a look in your fuse/circut breaker box for a blown breaker and reset it.
You may need to have your heat unit checked for a blown low voltage fuse also.
Nov 08, 2010 | Heating & Cooling
Even after replacing the battery, the programmable Honeywell thermostat still shows "Low Batt."
Turn control to off. Remove the batteries for at least one hour. If the display message still reads "bat lo", leave control off, batteries out, and disconnect the red wire on back and wait another hour. Reconnect red wire, put new batteries in and turn system on. It's like a reboot.
Jan 26, 2010 | Honeywell Programmable Thermostat Heater
Simon 3 "System Low Battery" after 3 years use
I install these panels.  For the low battery message to clear you need to power the system down completely.  To do this you need to unplug the battery and also unplug the transformer plugged into an electrical outlet.  When you power the system back up, you need to first plug in the battery leads.  Then the transformer.
Jun 15, 2008 | GE Security Simon 3 Wireless Home Security...
Low battery message, sent back to canon to repair and still having same problem..can i send back yet again. where to? or can i get a new one.
I had this same problem. I tried this procedure and it seems to have worked so far:
1. run a set of batteries down in the camera so the voltage is so low the camera won't even power up fully.
2. put some cheap (non-alkaline) batteries in and run these down.
3. get some hi-power alkaline batteries (the kind that are marketed as 'photo' batteries or similar, they do cost more) and put these in. Hopefully the 'low battery' indicator has now been reset.
This worked for me.
Nov 15, 2007 | Canon PowerShot A520 Digital Camera
How to correct error message sram error missing E?
Hate to say this but most likely the Print Engine Control Board has failed.
May 09, 2007 | Xerox Phaser 7300DN Laser Printer
"Backup Battery Very Low"
NEC has identified an issue where the system can erroneously generate the "Backup Battery Very Low" message. There are two possible solutions that will eliminate this erroneous low battery warning message (the first method is the preferred solution, the second method can be used if the update file is not available). Solution I. Install a new version of the driver that controls the battery monitoring circuit. 1. Download the Low battery warning fix to your desktop. 2. Using ActiveSync or a compact Flash Card, copy FixBatt_HPC2K.EXE to the MobilePro internal disk. 3. On the MobilePro, double click the FixBatt_HPC2K icon. 4. When the message "Low Backup Battery Issue" is displayed, tap the "Patch it" button 5. When prompted turn unit over and momentarily depress the Reset button using the stylus. Solution II. Change the default power management configuration. Configure your MobilePro 900 to suspend when the LCD lid is closed on battery power and AC power. To ensure that the device suspends whenever the lid is closed, please make the following changes and perform a soft reset: 1. Go to Control Panel. 2. Open MobilePro Settings. 3. Go to the LCD Suspend/Resume tab. 4. Place a check next to "Enable suspend while on External Power." 5. Click the "Advanced" button and place a check next to "Enable suspend while on External power. 6. Click OK to close the Advanced Setting window and click OK to close the MobilePro Settings. 7. Turn unit over and momentarily depress the Reset button using the stylus. NOTE: Both the software update and power management settings are cleared on a hard reset and must be re-applied.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Heating & Cooling Logo
257 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
