Question about Toshiba Satellite A135-S4527 Notebook
Lap top will not start up
Laptop will not start up after being turned on
  • 36 Answers
First that u need to do is to remove the battery from your toshiba laptop. Plug in the AC adapter alone and power it on. If it works, then u need to check your battery. If the notebook wont power on with the AC adapter alone, then i think its a NO POST issue. The motherboard needs to be checked.
Posted on Sep 17, 2008
During the windows start up my lap top blocked
Have you tried a system restore/recovery?
Nov 25, 2012 | Dell Latitude E6400 Laptop
When plugged in the unit starts to smell hot like an electical burn,
Turn it on turn it over and see if the fan is operating. If not power your lap top off and replace the fan. You may have to not use this computer until the fan is replaced it is advisable not to. The smell you have may be dust smell when it gets hot. Clean throughly and make sure that all the dust is out of your computer. Also recommended a lap fan also which goes underneath the laptop to assist with cooling.
Lap tops are very touchy and need to be kept cool at all times otherwise you will be purchasing a new lap top if you do not take care of the cleaning or the cooling or the fan not working or spinning slowly. Check all this out. Critical if you do not understand what I mean take your computer to a local shop for immediate care. I hope this assisted you. John
Feb 01, 2011 | Toshiba Satellite P205D-S7802 Notebook
My processor is getting hot. What will be the solution.
Turn it off ... it will not get hot.
Typically, normal temperature is over 100 degrees. There have been reports of fires starting as the result of a overheated PC. I am not making the claim, I have not had this experience.
Heat is the enemy of delicate computer parts. They call them Lap Tops but you should never use one on your lap. Always place your lap top on a hard surface to insure the vents are not blocked and the internal fan can try to do its job. If you are concerned about the heat, you can get a 'cool pad' to use under your lap top. A cool pad has a fan which blows onto your lap top to keep it cool. The cool pad gets its power from a USB in your laptop. This cool pad should not be used for long periods of time on battery power for obvious reasons.
Thanks for your question at FixYa.com
Jan 30, 2011 | Computers & Internet
How do I Connect a Dell Latitude E6500 to a Sanyo Television
Check your ports on the lap top see if you have s video or hdmi or dvi or VGA the best is hdmi if you have that get a cable for either one of you connections also match connections from the lap top to what you have for your TV more than likely if they are both fairly new you should have hdmi connections for both get a cable that is long enough. I get my cables at amazon.com their prices are the bomb.
Connect them together both ends to lap top and to tv then make sure that you have a line in jack stereo jack with RCA ends hook that to the back of your tv and your lap top in stereo jack even better to your surround sound system. Set your TV to AVI 1 or 2 or DVI or whichever is your connection start a movie on the lap top and turn your sound on and see if you have a picture on your screen you should have the same thing as what is showing on your monitor on your lap top. Adjust settings and have fun!
Jan 08, 2011 | Dell Latitude E6500 Laptop
My lap top wont turn on i have a blankj screen the
Please try these. After on your pwoer botton wait 2 minites and the press FN+F6.
Let me know what happening.
Thanks.
Jan 30, 2010 | Acer Aspire 6920 Notebook PC
Lap top won't switch on in the AM
The motherboard is going bad in your laptop if it takes all that to get it to turn on. If your laptop is under warranty, I would get a hold of Toshiba or the store you got the laptop from and complain. Regardless, the motherboard is whats bad in that laptop since the voltage goes thru that board. It also controls how the laptop turns on.
Dec 02, 2009 | Toshiba Satellite M60 Notebook
Dropped lap top now wont boot up
press the fn key on laptop hold it down and then press the power key on the laptop. once u see any display on the screen you will get some tests running on the screen. The system will show you the error message which u need to note down. else you can do a Flea Power on your laptop. Remove the adapter and the battery and then press the power button and hold it down for 30 seconds then connect the battery and adapter back and try to turn on the laptop. See if the magic works for you
Jul 16, 2009 | Dell Latitude D600 Notebook
My lap top has this blue error scerrn that comes up
you need to start in safe mode and do a system restore.
either that or put your restore disc in the drive and recover your system
Jan 16, 2009 | Dell Inspiron 2200 Notebook
Toshiba M55-S135
check your battery on some other's laptop, i think the battery life is over, you have to replace the battery
Oct 29, 2008 | Toshiba Satellite M55-S135 Notebook
Laptop crashed
Try this:
  1. Turn on the laptop
  2. Wait for the first page to go blank.
  3. Start to press the F8 key repeadly
  4. You should get a Windows Start" page pop up that gives options on how you want to start Windows.
  5. If you see the Windows Logo (the screen you normally see when Windows starts) screen then just restart the laptop again.
  6. Choose "Last known Good Configuration" and press Enter.
If that fails then please post back and we can try some other things.
Apr 11, 2008 | Fujitsu LifeBookS6120 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
77 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
