Question about Sony VAIO VGN-CR115E/P Laptop
ACPI\SNY5001 - Sony VAIO VGN-CR115E/P Laptop
    Top Expert:
  • Sony Master
  • 29,841 Answers
What is the question?
Posted on Jan 16, 2016
SOURCE:
Why ACPI not supported by upgrade to windows 7
acpi is supporrted by win 7 just make sure ist on in the bios and download acpi driver from the motherboard factory
Microsoft ACPI Driver Windows 7 Service batcmd com
Sep 05, 2014 | Computers & Internet
WHO MAKES BIOS FOR TECRA?
ACPI Flash BIOS version 3.20 for Tecra A8 (PTA82) Posted Date: 2016-09-19 ' Version: 3.20 ' Size: 3.82M ACPI Flash BIOS version 3.30 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 3.30 ' Size: 3.82M ACPI Flash BIOS version 1.40 for Tecra A8 (PTA82U) Posted Date: 2016-08-24 ' Version: 1.40 ' Size: 3.54M ACPI Flash BIOS version 1.60 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 1.60 ' Size: 3.52M ACPI Flash BIOS version 1.50 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 1.50 ' Size: 3.54M ACPI Flash BIOS version 1.30 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 1.30 ' Size: 3.54M
Apr 02, 2014 | Toshiba Tecra A8-EZ8311 Notebook
Missing acpi/sny5001 for windows7 32bit
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
they will automatically search for and find the correct driver
also at cnet
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
you might have to try a few times to get it right
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivers
http://www.downloadcollection.com/device_doctor.htm
Device Doctor is a freeware Windows application that scans your computer hardware and checks to see if there are new driver updates available for your devices. It also locates drivers for Unidentified Devices in the Windows Device Manager. This tool was designed to be very simple and easy to use
http://www.innovative-sol.com/drivermax/
free program, paid update available
hope this helps
Aug 20, 2012 | Sony Vaio VGN SZ4XWN Laptop Universal AC...
Acp sny5001 problem for sony vaio
if its the driver you are referring to
also at cnet
hope this helps
I have a vgn-ns140e 32 bytes sony vaio notebook but it mark me and DRIVER error OF THE CPI/SNY5001WHERE I CAN DOWNLOAD THE DRIVER?
Hi, do you mean the ACPI/SNY5001 device?And do you have Vista or XP installed?
1)This is the Vista driver you need:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNS140E&upd_id=3786&os_id=28
2)For XP this is the driver:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNS140E&upd_id=3936&os_id=7
You might need to install it via Device Manager
Right click on the ACPI\SNY5001 device->Update driver... and point it to your files where you downloaded the driver – it will find the INF and install sucessfully.
Regards,
Purito
Oct 16, 2009 | Sony VAIO VGN-CR115E/P Laptop
ACPI is not a compliant
Enter you bios & disable ACPI. Restart the system. Than update your windows. There should be an update for ACPI through Microsoft update service. Once installed restart your system & enter into your bios. Now enable ACPI. Save & exit the bios.
If this does not help you can try the work around found on Microsoft's web site. See the link provided;
http://support.microsoft.com/kb/314830
Cheers
Mike
Jun 01, 2009 | MSI Computers & Internet
I need to disable tha acpi on an acer travelmate 529tx but i don't know how to do it. i am trying to install xp after a failure. i get bsod and says to press f7 when i install storage drivers but i need a...
I have seen on many forums that ACPI makes a lot of troubles to a lot of users under Windows. I will try to explain several things about ACPI and I hope that you will be able to solve your problems after you read this article. I cover only most encountered issues, but always there is a choice even if it's called ACPI disable.:)
The computer ACPI support is detected in the setup stage, but there are less frequent cases when ACPI is not detected and the Standard PC HAL is installed. If you want to force the installation of the ACPI HAL:
1. At the blue screen of the Windows XP setup when it prompts you to press F6 for additional mass storage devices press F5 and you will have a list of options.
2. Choose the proper HAL for your machine remembering that there are also different HALs for multiprocessor machines.
3. Complete the setup, go to Setup / Control Panel / System / Hardware / Device Manager / Computer. If you have listed the Advanced configuration and Power Management (ACPI) the process was completed successfully.
Warning: You can do the same thing if you don't want to install ACPI and your BIOS doesn't support ACPI disable setting. Just choose the Standard Computer HAL from the list of options.
Another method to disable ACPI is:
  • wait for the text-phase of XP setup to complete
  • before XP Setup Wizard to load, boot into DOS and change ACPIEnable = 0 from ACPIEnable = 1 in file c:\txtsetup.sif
The reason why ACPI is not installed on a computer with known ACPI compatibility may be a Microsoft known subtle incompatibility which can lead to hardware instability. In the installation step Windows XP checks the BIOS compatibility with ACPI and the BIOS presence on a known bad list. If the BIOS is there ACPI is not installed. Of course than errors can occur so you can force the ACPI installation (not recommended).
Try disabling it in the BIOS first, this can not be done on a computer with the operating system already installed as it will cause the machine to stop. MUST be done when you initially install the OPERATING SYSTEM.
Regards.
Nov 16, 2008 | Acer Computers & Internet
Wireless card not functioning/disabled after loading XP in a Compaq Presario C700T CTO Notebook PC
The wireless is not going to turn on and off via the switch properly until we get the drivers loaded to make it work. There are 3 possible types of wireless card it could be, so we have to find out the exact model number of your system. On the bottom there should be a label that has a P/N or part number listed. what are those numbers. Here's an example of the label:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00033108&lc=en&cc=us&lang=en&os=2093&product=3632144&dlc=en
or
http://tinyurl.com/35dt4h
we need the info listed for #1, #2 and #3. Then we should be able to determine which adapter you have, and then we can (hopefully) find some Windows XP drivers for you.
Feb 26, 2008 | Compaq Presario 700 470024-192 Notebook
Sony VAIO VGN-CR115E/P Laptop Logo
1,765 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
