RICOH 5510L How can i repair a service call 0544
  • homepros Nov 04, 2008
    it says Call Service 0544H
    i get the same error code 0544H
jaylex
  • 417 Answers
SOURCE: Service error 0544 on a Ricoh Fax 5510L
Hi there the error you have is that the fuser unit is lower than 130 degrees for 1 minute. Suggestion replace fuser unit turn power off the on. If problem still persists replace control board or power board.
Thanks Jason
Posted on Aug 17, 2008
My system is mifi jetpack 5510l with 10 gb with android tablet teame to use less data
Spend less time playing online chess outside your house where you have to connect the MiFi Jetpack to your laptop and use your data plan and more time playing at home over your home network where you do not have to use the jetpack and your data plan.
Jan 01, 2015 | Novatel MiFi 5510L Jetpack 4G LTE Mobile...
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Clear ricoh 5510L error code 0544. I can get to SP mode by user tools, #, 1-0-7 then start but what do I do from there?
try executing sp 5810
if there is no 5810 just turn machine off while in sp mode using the red on/off switch
This should clear the code
however if there is a problem with your fuser the code will come back.
Caution dont reset multiple times in a row or you will do damage to the machine or fuser from it getting too hot
Apr 06, 2010 | Ricoh FAX5000L Plain Paper Laser
Ricoh 5510L Network Setup
Go to user tools-key op tools-network-tcp ip- ip address put the appropiate info in.(including gateway address.) then type the ip address into the top portion of a web browser an you should be in web image monitor. you configure the printer there. User name is admin no password. -Carl
Jul 07, 2009 | Ricoh FAX5000L Plain Paper Laser
Service Call SC548
fuser problem . danger . call tech
Dec 18, 2008 | Ricoh Aficio SP C811DN-DL Printer
Thanks Jason
Jun 26, 2008 | Ricoh FAX5000L Plain Paper Laser
182 people viewed this question
k24674
