Question about Optoma EzPro 739 Multimedia Projector
Optomoa EZ739 frequent over heating and auto shut down.
  • Anonymous Sep 28, 2008
    Mine will work for about an hour and then it overheats and shuts down.
The answer is....
Run your lamp in economy mode and it should work fine, also use compressed air to blow out fan and cooling fins from the unit frequently from the openings on the unit. I have always run Eco mode and it never overheats except when turned off a few times! Also the color wheel gets stuck on dust so I have to blow it out frequently.
Posted on Apr 23, 2010
Still need an answer, but not going to pay for one.
Posted on Sep 17, 2008
What are the pros and cons of operating the Quadrafire Mt Vernon AE pellet stove in manual mode?
They probably cannot suggest running it on 'manual' due to liability reasons....leaving home for an extended time and forgetting its on manual...comes to mind.
What may be suggested is to make sure ANY and ALL safety controls still function to shut off fuel (pellet) flow in the manual mode as an extended overtemp condition is the first thing that comes to mind when you think of damage to a heating system or to the structure within which it is installed.
I think its a judgement call on your part once you determine you pretty well KNOW the full and complete operation of the device. The key to that statement is KNOWING WITHOUT A DOUBT the FULL operation of the system.
I also would NEVER recommend to a customer to operate it in the manual position.
Mar 25, 2015 | Heating & Cooling
FREQUENT SHUT DOWN
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Sep 28, 2012 | Computers & Internet
Furnace shuts down before heat temp meets thermostat. Furnace unit starts frequently. Service installed new limit switch and a new circuit board but furnace unit continues to malfunction. Same problems...
has any one checked your thermostat. as soon as the furnace shuts down then turn up the stat and see if it starts right up. i would think the stat function should have been checked also.
Feb 12, 2011 | Heating & Cooling
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
I have a Rowenta Pro. Iron, model DE-86.1A with auto shut-off. It sticks on auto shut-off. I have to move it around for it to heat up, as indicated by the sensor light on the top.
I believe that is how the safety feature works.
Once the iron detects no movement for a certain period of time (the iron assumes you have finished ironing) the iron will shut of the heating element.
One you have moved it around, the timer should prevent it from auto shutting down for a period of time.
Jul 22, 2009 | Rowenta Irons
Engine cuts out when hot
every generator has an auto-shut down system that turns the engine off when over heated..u can dislocate the wire coming out of the engine and into the on/off switch...and then it till never shut off unless u tell it to....
but be carefull!!!!!!!!!!!!!:when u dislocate it...u r turnning off the auto-shut down system...so if the engine over-heats.. it will not shut down...
if u have any further questions email me at sal_kh_sab@yahoo.com
Jul 13, 2009 | Coleman Powermate Powermate 5000W...
Computer shuts down intermittently
Do disk cleanup, it's in Accessories, System tools.
Apr 21, 2009 | Dell Inspiron 2650 Notebook
Premature shutting off
the only thing you can do is change out the motion sensor which is 1n the machine or disable it
Apr 21, 2008 | Irons
Auto shut down of unit
the audio amps may be overheating and shutting down. a lot of electronic devices don't receive heat sink compound when being assembled and the heat doesn't transfer as it should. Try cooling the unit either in a plastic bag in the refrigerator or placing it in a cool airstream directed at the rear of the unit. If it's in a stack of other electronic devices, place something between the units to allow air to circulate. I hot-melt glue tinkertoy wheels to the bottom of the units myself to separate them.
Nov 24, 2007 | Yamaha DVR-S200 DVD Player
Open Questions:
Optoma EzPro 739 Multimedia Projector Logo
184 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
