Question about Acer Aspire™ T180 PC Desktop
Lost several drivers
I lost several drivers and i dont know what to do to restore them. i have no sound,my usb ports wont work and there are some other drivers that dont work but im not sure what they control.please help!!!
    Sniper:
  • 62 Answers
You can download Astra32 from http://www.astra32.com/download.htm .
It would tell you that which drivers do you require for your system.You can download drivers accordingly and install it.
Posted on Sep 17, 2008
How can i solve the problem with my Hp usb ports, it stop working
make sure you have not lost the drivers for them.
or try doing a restore to when thay last worked.
Jun 22, 2014 | HP Computers & Internet
Not working with usb adapter
to me it sound like you are not getting enough power out of your usb port what is this CS2000?
Oct 25, 2013 | Symbol CS 2000 (CS2000-I100-010101)...
My usb port wont work.i dont know why?
Install the correct drivers and make sure the ports are correctly connected to the mainboard.
May 04, 2013 | Computers & Internet
Ok, this has never happened to me before and im quite computer savvy but this has me vexed beyond a doubt. I was playing a online game, minimized the screen so it showed the desktop, i had headphones in at...
Well, before anything else, try scanning with a different antivirus app; like Malware Bytes or SuperAntiSpyware. Other than that, the sudden loss of both of those systems sounds to me like a MoBo problem. If you have a system restore point, try using that to rule any software installation out. If in fact is is the mobo, and you have to recover your data; you still have options. You can upload all of your important files to an online storage system; some of which, like Windows Live Skydrive are free, and others, like Mozy backup, are paid. You could also remove the harddrive, and use it in a hard-drive dock, attached to another computer, to browse the drives contents, and recover the important data before you restore the OS; the last ditch effort before replacing the mobo.
Mar 06, 2011 | Toshiba Satellite L505DGS6000 Notebook
Hello, I am having trouble with my usb ports. It does not recognize anything that I plug into the usb ports. I did a system restore and it still does not recognize the usb ports. It only recognizes it if I...
reinstall your usb controllers and handlers off the factory system disk that came with your system..something corrupted the files somewhere ...system restore wont replace deleted system files only restore user settings when you put the disk in it will have a section to restore drivers...select usb and reinstall then restart the system
Sep 28, 2009 | SimpleTech 500GB SimpleDrive Pro External...
"Lost" all USB ports on win xp laptop after plugging ipod shuffle
go into the system restore and choose a date when the usb ports were working then let it go thru its process of restoring. It will restart and then test the usb ports then, if you still can't get them to work then that means the motherboard is bad.
Jun 30, 2009 | ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI...
T30 wont reformat
Sounds like you have a faulty hard drive. Can you see or detect the hard drive in the BIOS? To test the hard drive, remove it from the laptop and connect it to a USB hard drive adapter and plug it into a working computer's USB port. If this computer sees it as an external hard drive and you can open the various folders and files, then it os OK and the fault is in the laptop. If the hard drive is faulty, then you need to replace the hard drive in the laptop and install Windows to get the laptop working again.
Jun 03, 2009 | IBM ThinkPad T30 2366 Notebook
Pc has no sound. Volume control says no mixer device installed.
This sound like a operating system corruption. You will have to install the windows disc and try to do a repair of the system. If the repair fails and you cannot get the sound to work. You will have to reinstall windows. These corruptions happen due to downloading programs that do not work well with the operating system. You can try removing all the new programs, you installed before the problem appeared.See if that returns the sound operation to normal. If not you can also try a restore windows to a earlier set-up with the windows restore point. If Have done a back-up of your system.This may also restore the sound to normal operation. If all this fails you probably have a bad motherboard that has lost the functional operation of the sound circuits. You may need a new motherboard. If this is the problem. You can go on the motherboard maker website and look into the frequently asked questions and troubleshooting sections and see if this is a known problem with you motherboard model. See if they have a solution. I hope this information helps you with your problem.
May 23, 2009 | Intel Computers & Internet
Fine pix s6500 fd camera
first thing i would do would be to make sure you plug the cable first into the usb port with the camera off then turn on the camera, see if it is recognized by the computer. If not the next step is to check your usb driver to make sure it is working. Try some other usb device. If it is recognized then i would make sure you have seated the memory card properly in the camera as well as the cable. I know that sounds dumb but that little usb cable to the camera has to be well seated. You may have to update your driver for the usb port.
May 15, 2008 | Fuji FinePix S6500 Digital Camera
Acer Aspire™ T180 PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
