My brother 3 in 1 printer keeps going into sleep mode how do I reset it?
  • laurieanngou Oct 04, 2008
    my printer says it's in sleep mode and nothing will work to get it out of sleep mode.
  • zozo21 Jan 08, 2009
    i had the same problem and i tried your solution but unfortunatly it didnt work.
    anyone has an idea ?
    thanks
    Problem Solver:
  • 5 Answers
Sleep mode is a normal thing with brother printer, you don't have to worry bout it,it's just the way the printer is saying "hey i'm not doing anything here,might as well get some sleep! once you start to print or scan it'll come back to life.
Posted on Dec 15, 2008
  • Abstruse Feb 28, 2011
    Thats not very useful is it. i use it all day long and have to insert manual feed first page headed paper every 7 or 8 minutes or so. Going into sleep after 5 means im constantly waiting for it to wake up and accept the paper im holding in front of it.. no manual feed tray and it doesnt grip it off you until its woken back up.. I could get another letter typed or email replied to in the time Im messing around with it.
    Extending the sleep mode to 15 minutes would save a lot of messing around and sitting there with my arm out holding bits of paper like an idiot throughout the day.
    Was there ever a resolution for this?
HOW TO STOP SLEEP MODE TO LEAVE PRINTER ONLINE
The are designed to sleep automatically but there might be a download on the Brother support site for a "Remote Printer Console" Are you mixing XP and Win7 documents into the que?
Mar 10, 2015 | Brother MFCL2700DW Wireless Networking...
Hi, my printer Brother MFC-9320CW enters in sleep mode every 30minutes. Any cloues how to clear the timing?
try fixing the SLEEP menu.
Follow the steps I found:
Enter Menu and navigate to General Setup. To enter press OK. Use up or down arrow buttons to go to Ecology and again press OK. Enter Sleep Time menu and enter 0 if you don't want your brother to enter sleep mode. Press OK and exit printers menu.
May 06, 2012 | Brother MFC9320CW All-In-One Printer
HOW DO I TURN OFF THE SLEEP MODE ON MY PRINTER BROTHER MFC 7420
Setting the Sleep Time reduces power consumption by turning off the fuser inside the MFC while it is idle. You can choose how long the MFC is idle (from 00 to 99 minutes) before it goes into sleep mode. The timer is automatically reset when the MFC receives a Fax or PC data or makes a copy. The factory setting is 05 minutes.
To turn Sleep Mode off press Menu/Set, 1, 6, 2. Then use the dial pad to enter the length of time the MFC is idle before it goes into sleep mode, in this case 00 so it wouldn't go to Sleep mode at all. Press Stop/Exit.
Feb 04, 2011 | Brother Office Equipment & Supplies
Brother HL-2170W laser printer goes into sleep mode quickly. How can I turn off the sleep mode.
I found this from Tony Benjamin
I have tested it on two different Brother Lasers and it worked.
To cancel DEEP SLEEP on Brother Printer
  1. Go to General Setup then OK
  2. Ecology then OK
  3. SLEEP TIME then OK
  4. While sleep time is display push Down Arrow and CANCEL at the same time!
  5. DEEP SLEEP on/off toggle by Arrow keys
  6. OK to SAVE Deep Sleep off.
It is a shame they don't have this in the web interface or manual they sent with the printer.
Nov 03, 2010 | Brother HL-2170W Laser Printer
MFC-7840w printer, how do i take it off sleep mode?
  • The control panel features a series of buttons as well as an LED "Status" screen.
  • Press the "MENU" button. Go to INITIAL SETUP, select "FAX" select "RECEIVE MODE" change to F/T
  • If you are using the Brother on a line by itself, set it to "Fax." If you are using the Brother on a line that also shares a telephone, set it to "Fax/Telephone." If you are using the Brother IntelliFax along with ananswering machine, set it to "TAD." Once you set your IntelliFax to the appropriate mode, the unit will leave "Sleep" mode and be ready for use.
  • Select "GENERAL SETUP" go to "ECOLOGY" and #2 is SLEEP TIME = adjust to 60 sec. This keeps the machine from becoming idle/sleep mode for a longer period.
    Sep 25, 2010 | Office Equipment & Supplies
    How do i remove the sleep mode so i can recieve faxes?
    The Brother machines go into sleep mode to save power, in the machine setup you select how long to wait before going to sleep. When all is working, it will wake up as soon as a fax is received, so you really don't need to change it. If you use menu to reports and select the user settings to print, it will tell you where the setting is at.
    Nov 02, 2009 | Brother MFC-8460N All-In-One Printer
    My printer remains off line. I find no where in control panel or printer file where I can check an option to keep it on line.
    Laser printers have a sleep mode they automatically enter to reduce power consumption. Normally they should respond with fairly quickly and awaken to a print job beign sent. ALthough you may not be able to override the sleep mode, you may be able to change how soon it goes into sleep mode in the advanced features. Otherwise, you should contact Brother support and ask the question to them. They will be able to tell you for certain.
    Jul 07, 2009 | Brother MFC 8500 All-In-One Laser Printer
    BROTHER FAX MACHINE 2800
    Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
    1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
    2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
    3. Press the MENU/SET key to confirm your choice.
    4. Press the STOP/EXIT key to exit the menu.
    NOTE: If you frequently print, copy, or fax, set the idle time long
    enough to insure that you will not always have to wait for the Brother machine to warm up.
    Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
    1,268 people viewed this question
    jasbo
    jasbo
