Question about Panasonic Palmcorder PV-L452 Camcorder
Fuzzy or hazzy displayon view finde and screen
When you look through viewfinder or flip out screen it is gray and hazzy. If you adjust contrast ,you can see image but still hazzy and gray. Shows no color whatso ever.And it records the same way. The picture seem to focus but is hard to see. Thank you for any help.
  • Panasonic Master
  • 19,396 Answers
If it is not a setting problems, and if the black and white is only on LCD and not on picture, then it is a problem with the LCD. Probably just the ribbon cable not well inserted into the connector.
Camera must be taken apart to fix this problem. Better to have the job done by a technician at a camera repair shop.
Posted on Sep 16, 2008
The image in my viewfinder has gone fuzzy
Complete information is lacking.
By viewfinder, are you talking about the LCD or the view finder on the camera?
Something is out of focus in the internal adjustments.
You can try to go to the menus and set all to factory defaults.
Then try it.
If this continues, the camera needs repair.
Here is a link for Canon Repair call the 800 number and ask for the repair dept.
Also Canon has a trade-in program for re-furbished cameras for a reasonable price when you trade in your broken camera.
Oct 05, 2009 | Canon EOS Rebel XSi Digital Camera
Pictures fuzzy when you look through the viewer.
The viewfinder and the picture lens are totally separate. If it looks fuzzy, and then comes out fuzzy, the capture screen inside needs cleaned. The main lens and viewfinder lenses should be cleaned too.
Get estimates before you say yes to the work. It might be cheaper to buy another camera, unless you can do the work yourself.
Aug 06, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
Viewfinder of Sony DSC-H2 does not work anymore
Viewfinder has focus lever at bottom, please adjust viewfinder internal focus as per your eye sight looking on-screen display. Every thing will be fine after that.
Feb 04, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
VA721/Windows 2000 - contrast/brightness settings grayed out
The monitor is probably set to sRGB under "color adjust".
Change it to 6500K, which is default, and you should be able to adjust brightness and contrast.
Jan 01, 2009 | ViewSonic VA721 17" LCD Monitor
Fuzzzy display
Sep 16, 2008 | Panasonic Palmcorder PV-L452 Camcorder
Gray picture
This sounds like you have the contrast setting too high, go to your menu and find the contrast settings, and adjust to your requirement. As for the words being blurry, this could be because your tv is HD ready, and unless you view a High Definition channel then the picture will be a liitle blurred.
Hope this is of some help?
Sep 16, 2008 | Samsung DynaFlat TX-P3064W 30" TV
Diopter adjustment and viewfinder problem
Hi
I would not attempt to open the camera for any sort of fix. It has weather seals in place and would recommend sending it in to Canon. If you have any warranties left it would void these. Lastly this is a high proformance bit of kit and you want to get is seen to by an Authourised Canon Dealer.
As for the diopter adustment. To be able to see through the view finder and see your subject clearly, take of the lens cap aim the camera and turn the little dial until the screen inside the viewfinder is clear it should not be fuzzy. You are only looking at the screen/gring and not the image beyond. This does not affect your image but does effect how clearly you see your subject through the viewfinder.
Hope this helps
Regards
Jun 03, 2008 | Canon EOS-1Ds Mark II Digital Camera
Conair CID400 Poor Caller ID Display
hi this problem points to 1 main thing: your line voltage is low how many phones are connected on the line? if there are more then 3-4 its too much! you got only 1-2 ? call the phone company and tell them u got a low tone... good luck
Feb 20, 2006 | Conairphone CID 400 (CID400)
Panasonic Palmcorder PV-L452 Camcorder Logo
93 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
