Question about Canon Office Equipment & Supplies
Getting system error E805 - Canon Office Equipment & Supplies
    Scholar:
  • 97 Answers
E805 (The fan rotation is faulty.)
If no detail code is indicated, suspect the feeder fan (FM1) or the reversing guide cooling fan (FM9). Is the connection of these fans normal? Is the drive signal of the fan identified in the previous step about 22 VDC while the fan is rotating or about 12 VDC otherwise?
Secondly, if the fans are found right, then for sure you need to change the DC Controller.
Posted on Sep 17, 2008
Error e805 ir 400
my cannon ir400 xerox machine is on but no working power supply is full but not run machine
Dec 21, 2013 | Canon imageRUNNER 400S Copier
Canon gp 335 erorr code e805 what is the problem
Canon GP 405 error E805 E805 (The fan rotation is faulty.)
suspect is feeder fan (FM1) or reversing guide cooling fan (FM9).
try Check
Mar 25, 2012 | Office Equipment & Supplies
Error E805
E805 ERROR . cooling fan failure, mostly heater cooling fan ...
Jul 06, 2011 | Canon imageRUNNER 400S Copier
Canon ir400 E0805-0014
Hi
this is not the same sub code but it's a start.
getfile.asp?rid=1258 September 27, 2002 getfile.asp?rid=3215 Product : imageRUNNER 330 / 400 Title : E805-0002 Error Code Error :
E805 with a 0002 Sub Code
Workaround :
This may be caused by a pinched wire that goes to connector J108 B-18 on the DC Controller. The wire was pinched to the frame near the riser to the DADF-A1 exit side hinge. Inspect the harness indicated by the arrow in the picture. getfile.asp?rid=4772 Canon USA, Inc. Systems & Technical Support Division
Dec 28, 2010 | Canon imageRUNNER 5570 Copier
My canon copier IR2016 has functional error E805
there could be a problem with the main fan and or the dc controller could be bad.
May 19, 2010 | Canon imageRUNNER 2000 Copier
ImageRUNNER 400S Copier: what is e805 error & how to clear...
Its a fan related error, basicaly you should check all the fans in copier, clean the filters, reconect the connectors, try to find a bad fan,... When you find the bad fan you can also replace it with new matching PC fan
Pls. rate
May 03, 2010 | Canon Office Equipment & Supplies
System Error E805 in Canon iR2018
E805 is Fan failure
The fan is faulty. - Check the fan connector.
- Replace the fan.
Jan 08, 2010 | Office Equipment & Supplies
I have a Canon laser class 700 and it has a E805 error message. Can anyone help me?
E805 error code refers to a fan failure. Either the fan is locked up or unplugged.
Sep 02, 2009 | Canon Office Equipment & Supplies
Error code e805
The fan wiring is faulty (short circuit, open circuit). The heat dischargefan is fautly.
check wiring of heatdischarge fan
The machine is equipped with a single fan for discharge of heat from inside it.
Mar 04, 2009 | Canon imageRUNNER 2000 Copier
E805
J'ai un problème e805 photocopie canon gp 405
Quelle est la solution de détails, s'il vous plaît
Aug 24, 2008 | Canon imageRUNNER 400S Copier
336 people viewed this question
old marine
old marine
