Question about iLO 3200 32 in. LCD Television
Ilo tv is stuck on one (1) channel
Receiving good signal. But the TV is stuck on one (1) channel. Can not change to other channels or the volume from either the controller or buttons on the TV. Is there a solution ???
  • Anonymous Sep 18, 2008
    pdp4210ea
    Problem Solver:
  • 7 Answers
Call 909-974-2859, they have the parts and tech support for this TV.
Posted on Sep 28, 2008
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
My insignia tv shows a NO DATA BASE error on screen. How do i fix this.
Try these tips:
Connecting your Cable box through Coaxial to the TV.
1- Turn on the TV and the Cable Box, secure all the coaxial connectors.
2- Press the "TV" button to be sure you are in the TV mode.
3- You need to set the TV in a specific channel for receiving the signal from the Cable Box, usually they are channel 3 or 4. Please press in the TV's remote those channels numbers and check if you are receiving signal about the Cable Box in any of them.
4- If you do, afterwards remember to continue using the Cable Box remote to change the channels instead of the TV one.
Connecting your Cable Box through RCA to the TV
1- Turn on the TV and the Cable Box, secure all the RCA wires.
3- Press the "Input" button to go to AV1 or AV2 depending where the Cable box is connected.
4- You should be receiving signal instantaneously after you have changed the Input and keep using the Cable Box remote for changing the channels.
Jun 21, 2010 | Insignia LCDTV26 26 in. Television
Ilo tv shows no tv signal, I believe that the channels are deleted but don't know how to add the channels back
Here is how to try and get them back if they are available.
On the original TV remote do the following-
1. Press the MENU button
2. Use the channel down button to select channel set
3. Select channel add/delete
4. Press volume up
5. Select channel you want to add by using the channel up/down buttons on remote.
6. When you get to the channel you want use the Volume up button and the color of the channel number should become either blue or green if it is added and it will be red if it is deleted.
7. Repeat until you have added all the channels you feel you are missing.
8. Press MENU button to exit.
If the channels are still available this should get them to return. If not contact you cable provider to see if they have moved some of their channels recently or check their web site for the current channel line up.
Good Luck and please rate this solution....
Jan 08, 2010 | iLO IWT3206 TV
Digital Visio 42" LCD TV stopped receiving digital TV
Check all your connections in the back, if they're all good replace the main board in the tv.
Aug 22, 2009 | Televison & Video
TV stuck on one channel
Remove batteries from remote, and test again the touch buttons on TV with remote batteries out. This to exclude the possibility that remote has a stuck button.
If the problem persists , then it is probably a faulty IR board on TV (the one that gets IR signal from remote), or a faulty touch button switch.
May 16, 2009 | iLO 3200 32 in. LCD Television
Cant change channel
The up/down ch buttons will only go to channels that are set up in the tv....go to the menu....settings....and set up the channels you wish to view, once the channels are set up, the buttons will work
clarkco
Feb 27, 2009 | iLO 3200 32 in. LCD Television
How to program ilo TV w/universal remote to play DVD
I Believe You Can Go To Channel 2 And Right Below Those Channels Are The 3 Video Channels Turn On Your Dvd Player And Go Through Them. If That Doesn't Work Try Looking At The Buttons On Your Tv For A Tv Video. Make Sure You Dont Have A Tv Video Button On Your Remote If You Do Then Just Click It Till You Find The Appropriate Video Channel.
Jan 05, 2009 | iLO 3200 32 in. LCD Television
My tv is stuck at one channel. Which controller board has to be replaced? The Key controller,LCD controller, or what?
I got the same problem, TV stuck on one channel, what I did was, I remove the cable (fron the back) for a minute and then reconnect, work perfect, well, better than try to return the bloody thing.
Good look with your.
D.
May 01, 2008 | iLO 3200 32 in. LCD Television
Remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Oct 02, 2007 | Toshiba 20AF44 20" TV
Volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Dec 01, 2006 | iLO 2600 Television
iLO 3200 32 in. LCD Television Logo
247 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
