My canon mp220 printer is not feeding paper through and there is no paper jams
  • 9 more comments
  • blue_allycat Nov 11, 2008
    my canon mp220 wont feed paper properly....it repeatedly jams, pulls paper to the right and crumples it or starts printing without pulling the paper all the way in....
  • Anonymous Nov 17, 2008
    paper 2 the side.
    its only like a week old///
    what did you do 2 fix?
  • Anonymous Nov 22, 2008
    Mine does the same thing, either wont feed at all, or pulls it to the right, crumples & jams...mine too is only a few weeks old :(
  • maxwheels Nov 23, 2008
    the printer will load the paper in so i can print in load to the right and crumbles up please can some one help to fix this
  • JJ_julian Dec 01, 2008
    the printer persistently displays a paper jam and does not operate while there is no such paper jam
  • mizwhite28 Dec 14, 2008
    AAAHHH! I have the same problem with the MP220. Really starting to get under my skin as of course I have important things to do with my print outs. Has anyone found a solution?
    Thanks
  • x0crabtree0x Jan 19, 2009
    Yeah i have the same problem with my canon printer, and i have tried everything - turning it upside down - using thicker paper etc
  • angelicdevil Jan 27, 2009
    I have the same issue, and so did my friend with the MP220. The rollers dont work, im taking it back to argos and shouting. This is annoying. Its only 3months old!This is what I expect from a 1year old printer!!!! GRR!
  • epapas86 Jan 29, 2009
    mine keeps saying its got a paper jam too and theres nothing in it! mine is less than a year old, and I am do not want to have to spend on a new one already!
  • Anonymous Apr 24, 2009
    tried turning it upside down,nothing happened, tried switching to quiet mode and still nothing. :[
  • Anonymous May 03, 2009
    I have the same problem and it's damned annoying.
    Tried turning upside down nothing in there.
Try turning your printers upside down as it may have something stuck inside it!!! i had a crayon inside mine which caused the same problems as you.
Posted on Jan 16, 2009
  • melcat71 Oct 18, 2010
    Omgosh! I turned it and shook it and a little toy sword dropped out and now I can print!!! PTL! Thanks!
I tried turning my printer upside down but nothing fell out. Then I pushed an A4 size piece of thin cardboard through and dislodged a drawing pin which had obviously fallen in at some stage. Solved the problem, prints perfectly and no more trouble with paper feed.
Posted on Jun 24, 2010
The same problem with MP220.
But the solution was for me:
try turning your printers upside down as it may have something stuck inside it!!! i had a crayon inside mine which caused the same problems as you.
THANKS FRANCESRUDD
At first I thought, that I am not an idion... to gave smthing inside, but in the end I tryed and find my SD card from camera. Printer works perfect!!!!
Posted on Feb 25, 2009
Also thought turning it upside down was a stupid idea,
until it fixed my printer and found my green pen also :-)
Posted on Apr 19, 2009
    New Friend:
Yes! Didn't see anything fall out but turning it upside down and shaking it has FIXED THE PROBLEM!
Posted on May 06, 2013
4 Suggested Answers
plettdoctor
  • 121 Answers
SOURCE: my printer keeps saying it has a paper jam
If ALL is cleared and no paper jam is seen then your printer's motherboard has packed up. a common CANON problem.
Posted on Jul 06, 2009
pineworks
  • 4041 Answers
SOURCE: paper won't feed through canon printer. no paper jam apparent -
Hello there gave it a go this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 16, 2010
SOURCE: Paper wont feed into printer no paper jam
In the comments section Blumm suggests pushing a piece of cardboard (like the back of a legal pad) through the feeder as far as you can. Turn the printer off and then on again with it in there. Pull the cardboard out and check for any foreign objects that have been pushed through.
It worked for many people including myself - I got a piece of plastic and it works wonderfully again!
Posted on Jul 31, 2010
Canon mp220 pulling paper to the right and jamming
This is caused either by a small piece of paper left in the printer after a paper jam where the majority of a sheet of paper has been pulled out but with a corner torn off and still left in the printer or it can be from a foreign object dropped into the paper feed tray. Sometimes turning the printer upside down and shaking it can dislodge the object, if it doesn't, you will need to take the printer apart to look for the problem. A few philips head screws around the printer will need to be removed first then carefully 'pop' the plastic clips apart using a small flat screwdriver.
Sep 11, 2011 | Office Equipment & Supplies
There's nothing stuck in my canon mp220 printer but it still has a paper jam error when there's nothing in it? help
the paper jam errror is due to the sensor falsely detecting a block. So if there is no sign of any paper jam, you have to remove the motor assembly in the carriage drive.
Now the rollers can be manually turned so as to check if there is any bits struck within. You will have to see if the sensor is clogged with dirt or paper bits.These sensors are optocouplers and reflect the IR.
So it can be faulty or detached. check or replace.
Oct 09, 2010 | Canon Office Equipment & Supplies
Canon mp220 manual
There are multiple manuals under section guides and manuals. I had to use MP210 since it is same as MP220. Just follow the link. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15402
Jan 11, 2010 | Computers & Internet
My printer keeps saying it has a paper jam. It is a Canon Pixma Mp220
Jul 06, 2009 | Office Equipment & Supplies
Paper Jam, yet no paper in printer. The last sheet came out whole.
I have a canon mp210 and it's saying paper jam..there is no jam. Paper is going towards the right when trying to feed but does not feed.
May 17, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MP220 printer. when i load the paper it starts to go to one side, a rustling sound then paper just gets stuck
I had same problem. Lift up Scanner section and check along white paper feed rollers with torch. I could see something between rollers and bottom roller bar. Lifted up that section of white roller with two small flat bladed screwdrivers. This revealed a " Sweet Rapper" jammed under rollers.Removed printer now ok.
Apr 06, 2009 | Canon Office Equipment & Supplies
Canon pixma mp220 takes in the paper all right
i'm 99 percent sure that you need new rollers. you can get these on canon's website or go onto ebay. there are quite a few kits there. the best stuff i've found is at http://www.precisionroller.com so check them out first.
Mar 11, 2009 | Canon Office Equipment & Supplies
Feed problems cannon pixma MP220
I would remove and reinstall the driver to see if that will correct the single copy problem.
On paper: low cost paper generally has a high wood fiber content making the surface rougher than that of better paper stock and more likely to 'stick' together. With any kind of paper, it is useful to fan the stack before placing it into the feed tray or cassette. Sometimes the edges are not sheered cleanly which can also cause them to tend to stay together. Fanning helps overcome this too.
Jan 17, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
3,311 people viewed this question
jasbo
jasbo
