Question about Texas Instruments TI-84 Plus Calculator
Everytime i hit graph on my TI 84 plus, it keeps saying "ERR: INVALID DIM". how do i make it graph again?
This probably means you have a statistics variable set to on in your graphing screen. Press . If you see one, or more of the plots at the top highlighted you should turn them off.
everytime i hit graph on - calcyeqx2plot1on.gifTo turn them off use the  until Plot1 is highlighted. Use the  if needed to move to a highlighted plot. Press .
Posted on Sep 18, 2008
Im trying to graph inequalities on my ti 84 plus, and it keeps saying ERR:INVALID DIM. how do i fix it?
Try deactivating the Statistica plots.
Press [2nd][Y=] to enter Stat Plots. Press the PlotsOff menu option.
Sep 21, 2011 | Texas Instruments TI-84 Plus Calculator
When I press graph, it says "ERR: INVALID DIM" how
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Jan 14, 2011 | Texas Instruments TI-84 Plus Calculator
When I try and graph on my TI-84, "ERR: INVALID
Dec 09, 2010 | Texas Instruments TI-84 Plus Calculator
Every time I try to graph on TI 84 it says ERR: INVALID DIM 1:QUIT I have enterered something simple y= x+2 and window is set for -10<x<10 and -10<y<10 the curser in y=...
Go to http://education.ti.com/downloads/guidebooks/graphing/84p/TI84Plus_guidebook_EN.pdf to download the manual. On page 401, you will find the following:
INVALID DIM • The ERR:INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press y , and then select 4:PlotsOff. • You specified a list dimension as something other than an integer between 1 and 999. • You specified a matrix dimension as something other than an integer between 1 and 99. • You attempted to invert a matrix that is not square.
Nov 11, 2010 | Texas Instruments TI-84 Plus Calculator
When I graph, it shows "ERR: INVALID DIM 1:QUIT"
Oct 28, 2010 | Texas Instruments TI-84 Plus Silver...
Everytime i try to graph something it says "err:invalid dim" and only gives the option to quit....how do i fix that?
Sep 24, 2010 | Texas Instruments TI-84 Plus Calculator
Everytime i try to graph i get an error saying invalid dim on my TI-84 plus calculator
May 19, 2010 | Texas Instruments TI-84 Plus Calculator
I keep getting Err: Invalid Dim when I try to
Sir,
Can you provide me brand name and model no. so that i can give a better solution.
Thanks
Good Luck
Aug 17, 2009 | Texas Instruments TI-84 Plus Calculator
My graphing calculator won't graph anything
Go to your stat plot screen, and select option 4 (PlotsOff), Press Enter, and try to plot a normal graph again
Jul 07, 2009 | Texas Instruments TI-84 Plus Calculator
I need help with graphing everytime i try to draw a graph it comes up with this ERR:INVALID DIM what does that mean
It means that your Xmin or Xmax is messed up. it often shows up when you are plotting somethings (histogram for exanple) and you don't have enough X or Y range to fit all the points in it. it also happens when you are multiplying matricies without using the right dimensions. ERR:INVALID DIM just means your dimension is invalid.
Mar 06, 2009 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
188 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
