Question about JVC Audio Players & Recorders
Rx-dp20vbk repairman says it has cracked dolby board. can i still buy this and where
UNABLE TO POWER UP
Check for a bad fuse inside the receiver.
Jun 20, 2015 | Yamaha AVENTAGE RX-A1030 3D A/V Receiver -...
Speakers not playing
The problem can be the cable or speakers or RX-V463 or settings. Need to check one by one.
Set the RX-V on DTS or Dolby Digital
1) Check Cables - connect the 2 (surround) cables from RXV's Centre Out to Centre speaker. If the Centre speaker works, then cables are ok.
2) Check speakers - Connect each Surround speaker to RXV's Centre out. If it works Speakers are ok.
3) Check RXV - Set it on DTS or Dolby Digital
Connect RXV's surround out (one at a time) L and R to the Centre speaker. If there is no sound, the problem could be RXV's settings (I need to read the manual).
Hope this helps.
Nov 20, 2013 | Yamaha RX-V463 Receiver
Cracking sound from the speakers in Dolby Mode
hello just buy a new one is the best thing to do for you
Dec 17, 2012 | Denon AVR-1908
Can i plug in my i-pod and listen to it?
All you need is either a dock, which will keep the I-Pod powered up, or a 3.5mm plug to two RCA phono leads, which will also be needed for the dock, this plugs into your headphone socket of your I-Pod and the two RCA's into an aux socket on the JVC. You can then listen to it in Dolby Pro-Logic. You won't be able to listen in Dolby Digital, unless the I-Pod has Dolby Digital output, which will require a different lead.
Of course the sound source (music) would have to be recorded with Dolby Surround, to get the full benefit, but many are, they just don't say in the imformation given.
Mar 09, 2010 | JVC RX-6008V Receiver
I have a PS3 hooked up via HDMI to my Yamaha RX-V465.When I play a blueray disc the signal info shows PCM.Shouldn't it show Dolby Digital or True HD?
Your PS3 probably has a setting for what digital bitstream it produces. Check it out. Dolby Digital is probably what you want.
Dec 27, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Right now my reciever will only play with two speakers (L and R). How do I get the 5.1 DTS back?
Are you using single digital coaxial or optical digital or the stereo RCA cable.
You might have that buttons on the remote for surround,2channel,3channel or 5.1 channel. orGo to the DVD's setup menu and click on "Audio Setup" or on "Languages" if there is no Audio Setup option and choose "Dolby Digital 5.1." (If you have a5.1, 6.1 or 7.1 system select "Dolby Digital EX" if it is an available option.) Depending on the age of the disc, the "Audio Setup" on the DVD menu may give you several choices: "5.1 Channel Surround Sound" or "Stereo Playback." If it's an old DVD, it might even say Dolby AC-3 (the professional designation for Dolby Digital 5.1). New DVDs may offer "Dolby Digital 5.1" and "Dolby Digital 2.0," the latter being stereo. Some of the disc menus offer only "Surround Sound" or "Stereo" options.
Aug 14, 2009 | Yamaha RX-V463 Receiver
DENON 1508 - If i switch on DOLBY PLII I here cracking sound
The Dolby processing IC has failed. The noise you are hearing is digital noise. There is nothing you can do with this other than sending it in for warranty repair. They will change the surround processing board and return the unit to you. Since it is cheaper for them to replace the board, the individual "parts" that failed will never be known. I have changed these in the field before. As a warranty service center we are required to change the IC first. Sending it in to the factory, they will just swap out the board.
Dan
Mar 02, 2009 | Denon AVR-1403 Receiver
Samsung DVD-R155 will not play in Dolby Digital surround sound
You need to buy a digital coax cable Just 1 run out of player and into amp!
Dec 06, 2008 | Samsung DVD-R155
Reply
Hi again BJanke,
Yes it is. The part description "TUNER/DOLBY PCB" indicates function such as RF tuning and Dolby processor. Your tech is also correct in calling it an "RF board" since it is a generic name. Additionally, you can perhaps inquire from www.gvibes.com to provide yo with an image so as to compare with what you have.
A question pls, if you think that my solution has provided you with appropriate information, why was the solution of somebody else given the "FixYa" rating?
May 25, 2008 | Audio Players & Recorders
Jvc rx-5020v dolby digital problem
Also...If your BluRay player only has a optical output for audio you will need to swap the inputs on the JVC rx-5020v. Press the "settings" button repeatedly until "digital in" appears on the display. Now use the "adjust" up and down buttons until DVD is selected as option 2. It will look like something like: 1CD2DVD Note: this may bugger any other previous setup you have.
Feb 02, 2008 | JVC RX-5020VBK Receiver
83 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
