I have a hp officejet 4215 all-in-one printer, fax, scanner, copier problem. If im not mistaken, I think I have the right disk, to setup the printer, to work with the computer. The disk I have is an "hp officejet 4200". Is that the right disk for setting up the printer??
  • 234 Answers
Yes it is the right disk, Because 4200 is the series of printers which HP has (i.e 4210, 4210V, 4210XI) all comes under the same 4200 series, so do not worry it is the same printer driver.
Except make sure it is for the right operating system like Windows2000, WindowsXP or WindowsVista
Good Luck
Posted on Sep 16, 2008
I have Vonage phone line. I cannot fax to anyone on my HP 4215 officejet. My officjet is connected to the wall jack and set to "slow" settings as advised in one of the HP solution forum. that did...
Press the setup button on teh front panel and go to fax set up
Under fax setup look for
ECM - Error correction mode
By default its ON turn it off and try to send the fax
But let me thing clear the telephone line which you have has definitely some disturbence
Apr 16, 2011 | HP OfficeJet 4215 All-In-One InkJet...
I have a hp officejet 4215. It has a scanner, but
For some reason the scan button on allot of HP printers doesn't seem to work.You can go thru "printers and faxes" on your "start" menu.After opening Printers look in the left column for "scanners and cameras",click it.Then your printer will come up,highlight it.Left column again,click "get pictures" and it will walk you thru the scanning process.
Jan 11, 2010 | HP OfficeJet 4215 All-In-One InkJet...
HP officejet 4215 to print instead of fax
if you are using windows then go to control panel and go to printers(windows vista) or printers and faxes (windows xp) and then select the correct printer icon out of the two icons.. there will be two icons (for eg . officejet 4215 and officejet 4215 fax.. ) choose the one which doesnt says fax .
Oct 20, 2009 | HP OfficeJet 4215 All-In-One InkJet...
I lost the disk for my HP4215 printer fax machine
Put the model number in to the HP website and you can download the full install suite
Oct 05, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Hp officejet 4215 all in one -how do I turn off the ringer
Taken from page 61 of here:
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
adjust the ring volume
The HP Officejet provides four levels for adjusting how loud it will ring when there
is an incoming fax or phone call. You can select Off, Low, Medium, or High. The
default setting is Medium.
1 Press Setup.
2 Press 3, then press 6.
This selects Basic Fax Setup and then selects the Ring Volume.
3 Press ! to select an option, and then press OK.
May 12, 2009 | HP OfficeJet 4215 All-In-One InkJet...
I can not install my hp officejet 4215
have u gone on the HP web site and checked for updated software? I have 2 HP printers and both had issues, downloaded the newest software at HP site support and cured the problem.
Jan 16, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Scan using the HP OfficeJet 4215 Printer
The problem is with Windows Vista...it does not recognize the scan button when you touch it on the scanner. There are two ways around this:
Go to Programs / Windows Fax & Scan / Click new scan / click file and then click scan
OR
Go to Accessories / Paint / Cick File /click from scanner or camera / click scan
Sep 22, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Faxing
LEXMARK Z612 NOT PRINTING THE PAPER(PAGES) COMES OUT WITHOUT ANYTHING
Jul 06, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Hp officejet 4215 all-in-one fax function
no need any steps for fax setup view all setting on your
printer control panel just start it and select option you have want
Feb 24, 2008 | HP Officejet 4215v All-in-One Printer
153 people viewed this question
jasbo
jasbo
