Question about NorStar M7324 Telephone
Norstar M7324 problem
Hi I have a problem with my phone M7324 I can't call out on line 1 and I can't answer on line 1 do you thing you can help me
    Problem Solver:
  • 7 Answers
Do you have dial tone?
Posted on Oct 23, 2008
One of my incoming calls gets a fax tone. i answer calls for a bunch of different companies and it is just this one line that does it.
1. The line may be wired to a security system or fax. or
2. The IRAD (internal remote answer device) on the system may be answering that line.
Sep 05, 2014 | NorStar M7324 Telephone
Norstar M7324 not showing lines in use and unable to retrieve calls on hold
That might mean that the line(s) is(are) not programmed for that telephone. If you press feature * 0 then one of the line buttons, does it list as a line or blank?
Apr 22, 2014 | NorStar M7324 Telephone
When I pick up my nortel norstar phone m7324 line 6 lights up can I change this to line 1?
In tech programming (Config) you need to got to the Line data and remove lines 2, 3, 4, 5 and 6 from the pool it is in, make it none.
Note if line 1 is in use then you cannot call out.
Note sure why you would want line 1 as your outbound, systems are to use the bottom lines out and work their way up and inbound starts at the top and works their way down.
If you dont know how to program or the password call your local vendor in for a 1 hour charge.
If there is some strange reason then state what the setup or issue is and we can see if there is a work around.
Nov 08, 2012 | Nortel Norstar M7324 Receptionist Phone,...
Norstar phone m7324 1. What is the difference between the name of the "line" and the name of the "set"? 2. Is there a way to reset the lines other than unplugging the phone system? Four lines are showing...
1. You can name the lines, for example (Line 1, Line 2) - or - (5551234, 5551235). You can also name the sets (phones), so when Joe calls Mary, Joe's phone will display "Calling Mary", and Mary's phone will display "Joe calling".
2. Press the line button for the line in use and the display will show which extension is using that line. There could be a stck button on a phone that is tying up the lines. When you figure out which extension is causing the problem, try unplugging it to see if that clears the problem (it should). Then get the trouoble phone repaired. Good Luck!
Mar 15, 2010 | NorStar M7324 Telephone
M7324 nortel phone line 1 can't answer on handsfree, how do I fix this?
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change to handsfree.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
Press the show key (top right arrow) .
The display say foward no answer.
press the next key 3 times (bottom right arrow)..
The display should say handsfree. Press the show key.(top right arrow) change from none to auto
Press the release key when finished
Sep 16, 2009 | NorStar M7324 Telephone
Norstar m7324 - forward to outside line
The solution for someone using the administrator phone (receptionist phone) is after discovering you have a fax call, depress the <link> button. Dial the fax number, wait for it to answer, then depress <link> again. This places call 1 with an outside number.
Apparently this is also available if you have a feature button by depressing <feature> <7> <1> instead of <link>. I haven't tried this so don't take my word for it.
This can also be used to forward a caller to an outside line, such as a cell phone. In the manufacturing business, our shop manager is never in the office. I may ask him if this is a viable solution.
Mar 23, 2009 | NorStar M7324 Telephone
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
Line in Use
Try pressing Intercom then 9. Should redirect you to the next open line.
great when all lines look like they are tied up!
Dec 18, 2008 | NorStar M7324 Telephone
PungaA
press feature * 0 on your set . this initiates a button inqury. Then press line 1 . What does it say in the window? Also do you have dial tone?
Sep 16, 2008 | NorStar M7324 Telephone
MERIDIAN M7324
Do you know how to program the system?
You will need to log into system programming. Got to lines/trunks and enter your extension. You will see the line appearances to appear only. You need to change those to appear and ring.
If you do not know how to get into programming. Call a professional.
Jan 07, 2008 | NorStar M7324 Telephone
NorStar M7324 Telephone Logo
256 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Shehu Pro
Shehu Pro
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
