Question about Sharp AL-1655CS Laser Printer
Don't know how to input an error correction code
I have a problem with a Sharp AL1655CS copier in that the auto document feeder won't work yet everything else does. I found an error correction code on this site that I want to try, but I do not know how to input it on the copier panel. Anyone know how to do that?
  • ctlaw Oct 02, 2008
    Thanks, Joed911. I appreciate the help.
  • Sharp Master
  • 4,338 Answers
Here is the manual for your unit.:
http://www.sharpusa.com/files/cop_man_soho_AL1642CS.pdf
Please remember to rate all users who assist you for free :)
Posted on Oct 02, 2008
I had a similar problem. I called the Sharp tech support number and they have a wonderful repair system where the person on the other end of the line took me through numerous steps, with codes, etc., and the document feeder repaired itself. I hope it works for you!
Posted on Nov 09, 2008
C0410 km1650 kyocera
A C-0410 error is a communications error between the document feeder and the machine. The manufacture did an update to the circuit board of the document feeder that sometimes corrects the error.
When I have had this problem it has been ether a bad harness or loose connection between the document feeder and copier or a bad circuit board on the document feeder.
Jun 09, 2011 | Kyocera Copier
Tip
Sharp AL Series Copier L1 L-1 Error Code Cause and Solution
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
This works in the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Mar 20, 2010 | Office Equipment & Supplies
Tip
Sharp AL Series Copier L3 L 3 code meaning and solution
Good Luck and thank you for using Fixya
on Mar 16, 2010 | Office Equipment & Supplies
Sharp AR-507 "Close the document feeder" error even it is already close...any suggestions and solutions please...
The document feeder has some kind of plastic nose that goes in to the sensor hole. Locate it and check for damadges.
Jul 05, 2010 | Sharp AR-507 Copier
Sharp copier AL1655CS will not let us copy until a new drum is installed. There is a code to get it going anyway. It limits you to a set number of copies even if it is working fine.
c photo c photo then prss 24 machine copy quantity key up and down arrow key then press print key press 7 press print key then solve your problem no show any code print fine thanks
Apr 13, 2009 | Sharp SHP AL1655CS Printer, Scanner,...
E1-00 code on Sharp al1655cs
TRY THE CODE 80-21 IT COULD HELP
Jul 24, 2008 | Sharp AL 1631 Copier
Sharp AR-5132 has a U5 error code
Check and clean all the Sensor on the ADF!
Jul 07, 2008 | Sharp AR-5316 Advanced Digital Imager...
Cant get rid of blinking error message, nothing works
H4-00 is a fuser related service code. you need to get into the simulation programs and run sim 14 to reset the code. Make sure there is no paper jammed in the fuser. (The hot part on the right side inside the door)
Dec 02, 2007 | Sharp AL-1655CS Copier
Auto feeder not copying the entire page
does the same occur when the manual paper feed path is used? has this problem has just "popped up" without notice or was it a gradual event?
Apr 02, 2007 | Sharp AL-1641CS Laser Digital Copier
Auto feeder misalignment
Are you sure you don't have a static problem locking the paper to the glass.
Mar 29, 2007 | Sharp AL 1631 Copier
Sharp AL-1655CS Laser Printer Logo
118 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
