Question about LG RU-44SZ51D 44" Rear Projection HDTV-Ready Television
Re44sz21rd My LG re44sz21rd is now 4 years old, I replaced the bulb last year, until now it has run fine. It now runs for 30-60 mins then it switches to stand by. If you leave it for a while you can start it up again but it will do the same thing again
HI,
All I can suggest is to replace the bulb. I experienced a similar problem after about 2 years viewing when the recommend lamp life was approx 8000 hours (I got to approx 3000 hours). There is a service menu you can access where you can reset the lamp hours time. I have read that if this is reached you must replace your lamp, but you can extended this by reseting the hours.
I have since learnt that a lamp bulb can go at anytime, so it is worth having a spare. Also I have noticed that switching the TV off at the switch (not leaving it in standby helps).
Try this to access the service menu. Holding down the menu button on the remote and the one on the TV for a few seconds. I think the TV needs to be off.
From memory, I think it is option 4 and option 5, then reset the lamp hours to zero
Posted on Oct 06, 2008
I have a LG LCD TV 42LB1DR-UA for 4 years and I am going on my second power supply. Last one was replaced less than 1 year ago. LG says there has been no recall but I can not see paying $200 per year to...
I had mine for 2 years and the main board went out. Cost 650 dollars to fix. Its been less than a yr and a half and it went out again. Selling it on ebay for parts...
Aug 03, 2010 | LG 42LB1DRA 42 in. LCD Television
Shuts off...restarts, then runs for a few mins
If the modem is 10 years old then its time to replace it even if it was working fine if not very good to be abreast with the latest technology. The ISP must have tested the lines which must be fine because they keep on upgrading so you need to replace the modem to a latest model.
Jun 19, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
LG DLP TV Won't Start Up
After the bulb replacement, the lamp hour should be retested. If you replace the bulb, and after the lamp hour reset to new bulb; and after that you replace it with old bulb, it won't work. In most cases, the lamp ballast too have to be replaced with a new bulb, and it is a good practice too. If the TV refuses to start up, there are many reasons for that. It will be best to contact any experienced service technician; I suggest. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 05, 2017 | LG Televison & Video
Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
May 22, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Lg with a mind of its own
My REsz21rd is doing the same thing, switching off after a short time and then struggling to re-start. The LG repairers say it's the projection engine and have quoted £2000 for a new one. What a joke!
Apr 02, 2008 | LG Televison & Video
Sony Wega kdf-55wf655 rear projection set keeps turning on and off
If picture quality is poor, be sure you aligned the bulb in the correct manner and be sure the cover for the bulb is not loose. Also, you might want to re check you picture setting as it might have gotten reset when you pulled the plug (I hope you pulled the plug when replacing the bulb).
Heres another solution (maybe temporary) to the problem of no picture and no sound for 30 seconds. I had my tv's power saving setting on "standard" before. After I switched it to "reduced", the problem was fixed. It has been almost two weeks without the problem. I think its a good fix until the new bulb comes in the mail.
Jan 18, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
DE73 A04 Error code
you may have a bad heating element..or temperature sensor the water temperture is not getting hot enough to let the dishwasher run. you my reset it and try running the water in the sink until it reaches hot ... then try stating the dishwasher...let me know if this helps
Aug 28, 2007 | Indesit 24 in. DE73 Evolution...
Open Questions:
LG RU-44SZ51D 44" Rear Projection HDTV-Ready Television Logo
220 people viewed this question
Computer Repairing
Computer Repairing
