Question about Hitachi Computers & Internet
I have bought two hitachi 160 GB hard drives and need jumper setting explained please
  • 40 Answers
The usual jumper settings for a hard drive are:
  • Cable Select
  • Primary
  • Secondary
Cable select means that the mainboard will choose whether to make the drive primary or secondary. Most mainboards today support cable select. And, most drives will have their jumpers already set to cable select. You can just have all your drives set to cable select, and the mainboard will take care of the rest.
“Primary” means first and most important. Think of the primary as the one that usually takes control of the cable and gets its way. The secondary is like a little brother who must usually wait.
You usually want your main hard drive set as primary, or set it as cable select and have the mainboard set it as primary
Posted on Sep 16, 2008
I have 2 Hitachi 3 TB External USB Drive External Hard Disks that are not recognized by my Mac OS X 10.6.8. Have I bought the wrong ones?
have you formated your hard drives? are your black or white jumpers hooked to the pins on top of hard drive? if the hard drives are new chances are the jumpers are still in small plastic package.the jumpers are little peaces of plastic with two holes with metal in them. the jumpers go on were it says master if you are using 2 hard drives .the other hard drive the jumper goes were it says slave. if you are using 1 hard drive you put the jumper on cs.
Sep 23, 2013 | Hitachi 200GB External USB Drive 200 GB...
NEED JUMPER SETTINGS FOR MASTER HARD DRIVE
Set The Jumper Setting On Your Hard Disk Drive
The hard disk drive will be detected as 32 GB if the jumper is set to the 32 GB clip pin setting. The common jumper settings for Samsung hard disk drives are listed below. Please check the label on your hard disk drive for the correct jumper setting.
Important: Use the alternate jumper setting listed below under General Pin Setting. After changing the jumper, partition and format your hard disk drive.
Configuring your Hard Disk Drive (Master, Slave, or Cable Select) - Setting the Jumper
If this is the only HDD in your computer, set the pin setting to Master.
If this is the second HDD in your computer, set the pin setting to Slave.
If this is the second HDD in your computer, and the first drive is set to Cable Select, set the pin setting to Cable Select.
If you are replacing the HDD in your computer, set the jumper setting to match that of the drive you are replacing.
Cable Select:
This setting is the default setting for PATA/IDE hard disk drives. With the Cable Select jumper setting, the BIOS determines whether a hard disk drive is Set as Master or Set as Slave by it's position on the UDMA cable.
If the hard disk drive jumper is set to Cable Select and is connected to the black connector on the end of the UDMA cable, it is recognized as Set as Master for that PATA controller.
If the hard disk drive jumper is set to Cable Select and is connected to the grey connector on the middle of the UDMA cable, it is recognized as Set as Slave for that PATA controller.
Note: When using Cable Select, your system must meet the following conditions:
Your systems host controller must support Cable Select.
Your hard drives must support Cable Select.
Your cable must support Cable Select.
Set as Master:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Slave, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
Use this setting if you are installing an additional hard disk drive to a single UDMA cable and the Cable Select setting is not recognized.
Set as Slave:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Master, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
32 GB Clip Pin Setting:
Use this on computers manufactured before November 1998 when either you start up your computer and see the message, "Hard disk drive controller failure", or your system stops responding during the boot process after installing a new drive. This occurs when the hard disk drive is too large for the BIOS to support.
If after performing the troubleshooting procedure listed above, the full capacity of your hard disk drive is not recognized, click here for information about obtaining a system BIOS update. If you are unable to update your BIOS, another option would be to create a second partition with the remaining unallocated disk space.
Aug 18, 2012 | Computers & Internet
I've a Fujitsu MHV2080At like external disk and from some days PC don't recognize Hard disk and this is "dead" , the led's are ok when i connect USB but the head of hard disk don0t...
  1. Serial ATA:  If you have a 3.0 Gbit/sec SATA drive that is not being detected by your 1.5Gb/sec SATA controller, or it causes your system to lock up when connected to a 1.5 Gbit/sec SATA controller, you may need to jumper your 3.0 Gbit/sec SATA drive to the slower speed of 1.5 Gbit/sec for the system to recognize it properly. For further information on changing the jumper setting to slow down your SATA drive's transfer rate, please see Document ID: 193775
    -48-8s.jpg -- (Click to expand) Jumper settings for Seagate SATA drives
    -48-9s.jpg -- (Click to expand) Jumper settings for Maxtor-brand SATA drives
    ATA:  It is recommended that all Seagate ATA hard disks supporting the Cable Select jumper option be configured as Cable Select. If your computer system was built prior to October 1998 and does not support UDMA 66 or greater you will be required to use the Master/Slave jumper settings.
    -48-10s.jpg -- (Click to expand) Jumper settings for Seagate ATA drives
    -48-11s.jpg -- (Click to expand) Jumper settings for Maxtor-brand ATA drives
    When using Cable Select jumper settings on your ATA drive, all devices connected to the UDMA cable must also use the Cable Select setting. The cable decides master/slave device detection when the cable select jumper settings are used. Please consult Document ID: 196299 for further instructions.
  2. Faulty Hard Drive
    If you have completed the above checks and procedures and the drive is still not properly detected, please attempt to use Seatools for DOS (see the tutorial here) to test the drive.  If SeaTools does not detect the drive after the steps followed above, or an error code that signifies drive failure displays, please proceed to the our Warranty Services page to begin a warranty replacement order.
Sep 19, 2011 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
I have a extra hitachi hdd 30 gb ..i want it to be a external hard drive.. i reformat it already and the hitachi hdd 30gb is now in the external enclosure.. the problem now is that my computer didnt...
1. Decide which hard drive will be the startup (master) drive. If this drive was the startup drive previously, or if it's a new hard drive, then the master drive designation will already be set.
2. To change the designation of a new drive to be a slave drive, skip to step 4.
3. To change the designation of an existing drive to be a slave drive: Turn off the computer, unplug the power cord, remove the drive from its drive bay, and disconnect the drive from its power cord and ribbon cable.
4. Check the hard drive documentation or the label on the drive itself for master/slave jumper settings.
5. Find the jumpers on the circuit board of the drive. Jumpers are plastic plugs with metal sleeves that form a circuit between a pair of pins. Jumper locations are labeled on the board with a J followed by a number (such as J20).
6. Use tweezers or very small pliers to remove or reposition the jumpers to the configuration shown in the documentation or on the disk label.
Say "Thanks" by clicking the thumb icon in the post that helped you. Please click "YES" in solution that solves your problem as "was this helpful?"
Apr 18, 2011 | Hitachi TravelStar DK23EA Series DK23EA-30...
Is there a jumper setting to run my hitachi 250 gb sata laptop hdd as a slave ?
There should be, look on the rear of the drive, close to the SATA and power connectors, you should see the jumper connections as well.
It varies from drive to drive, but the jumper setting could be engraved near the connector, look of SL for a slave setting.
If no, look on the label on the top of the drive, there should be the jumper settings listed there.
Some may be ambiguous, my last one offered the option of Master on / off. (Jumper in position 1 for on, no jumper for off) The off in this case was of course slave.
The result being, no jumpers - Slave.
Mar 26, 2011 | Hitachi 250GB Hitachi 2.5" SATA Hard Disk...
Put it in my computer as extra space for music and my computer isnt reading it for me to open to put anything in it
Have you checked the jumper settings of your hard drive. If you are running it on the same IDE cable as your master drive then you need to set up your Hitachi's jumpers as a 'slave' drive.
More often than not there are diagrams on the hard drive sticker to explain this configuration.
If these settings are as they should be and your system is still not detecting the drive make sure the hard drive is spinning by listening for a sound coming from it. If this is fine then chances are good that your drive has blown and not worth repairing.
Let me know if you need any further assistance.
Best wishes,
Graemevm
Jan 16, 2011 | Hitachi 80GB IDE Hitechi DeskStar 7K160...
I bought a 320 G hard drive but my computer only see about 160 g hard drive?
please check the jumper of the hard drive is it on the "master",.... if yes try to change the jumper to " cable select ",.... if it doesnt work to. check the "RAM" on hard drive ( rehot first ). good luck
Apr 26, 2010 | Western Digital (WD3200JS) 320 GB Hard...
Slave jumper settings for a 2.5 Hitachi DK23DA-20F hard drive
Most hard drives I've come across have tiny little letters on the PCB next to the jumpers that say MA SL CS which are for master, slave, and cable select. If that doesn't work, go to Hitachi's website and search their support section. There is a diagram of the jumpers for that drive out there somewhere. Good luck!
Nov 07, 2009 | Hitachi (DK23DA-20F) 20 GB Hard Drive
How to transfer files from one harddrive to another harddrive?
install the new harddrive where you want to transfer your files and set tis jumper to slave and set the jumper of the other harddrive from where your files are located to master. when you open your pc you will two drives C: and D: open c: and locate your files and you can use the 'copy' or the 'move' command and select the drive where you want to put your files
Oct 15, 2008 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
Computers & Internet Logo
73 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
