Question about Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420N network connection failed
My 7420 was working fine until I got the famous "rear door open" error message after a paper jam. I fixed the jam. But now the router will not communicate with the printer.
I unplugged the network cable from the printer and plugged it my laptop and the router connection LED immediately lights up confirming a good connection.  I reconnected the network cable to the printer and the LED goes off on the routher and stays off.  A cable diagnostic test using the builtin feature of the router reports that the network cable is not plugged into anything.
I unplugged the cable from the printer and inspected the inside of the network port for bent pins.  Nothing there and if I plug the cable back into my laptop the router reports the cable as fine.
This just seems wierd after a paper jam.
Any suggestions where I can go from here.  Thanks.
  • puddleboots Jan 15, 2009
    The solution to this problem was that the network cable was in fact defective.  One of the 8 crimps within the RJ45 connector became open when I disturbed it to fix the "open door" error.  For some reason when plugging the defective cable into a laptop there was no connection problem and I suspect it was not using the defective connection where the printer was.  The defect was found using a cable tester and the connector was replaced.  Everything fine now.
    Sniper:
  • 56 Answers
Open the back door.
Pull down the black rear chute the exposes the fuser (opens just like the door)
In the middle you will see a black piece of plastic that is a paper sensor. In the middle of the rod that that piece is on there is a flag that sticks down through a slot. This piece is off and out of position, snap it back in so the flag is through the slot and the rod and pieces rotate freely.
That will FIXYA!
Posted on Jan 15, 2009
  • John Tuminaro
    John Tuminaro Jan 15, 2009
    Great! You should keep the instructions i sent you becuase it is a common issue with this model.
Back cover open how do you fix this?
If you turn the printer off and then back on with a paper jam in it you will get this error message instead of a paper jam message. To clear the paper jam from the back of the printer read the instructions from here: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=mfc7420_all&Cat=11
Feb 07, 2011 | Brother MFC 7420 All-In-One Laser Printer
How to fix -saying ,close back cover ,and there is no open cover it does not work at all
If you turn the Brother printer off and then back on with a paper jam in it you will get this error message instead of a paper jam message. To clear the paper jam from the back of the printer read the instructions from here: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=mfc7420_all&Cat=11
Feb 06, 2011 | Brother MFC 7420 All-In-One Laser Printer
PAPER JAM MESSAGE APPEARS WHEN THERE IS NO PAPER JAM
Please follow the directions below to clear the paper jam error orincase there is one somewhere.
Turn off the Printer. Remove the drum and toner from the front cover. Remove the toner from the drum. Look inside machine incase of possible paper jam. Open back cover and paper tray incase of jam. Close all doors and put toner and drum back in machine. Turn on the printer, and see if the error message is gone.
Apr 04, 2010 | Brother MFC 7420 All-In-One Laser Printer
My MFC-7420 jams paper after each copy what is the problem.
First you need to clean up the drum and inside the printer.
after that if still jamming paper.
you better check all the rollers and check the drum unit.
if possible, please chang the drum and that should be working fine.
May 14, 2009 | Brother MFC 7420 All-In-One Laser Printer
MFC-7420 "Change Drum Soon" I have had this message for a while. I purchased a new drum. In the meantime the printer continues to print fine, except we have paper feed problems. Is the drum related to...
the only time i've seen the drum affect paper feeding is if paper jams in the drum unit. i would use your current drum until print quality decreases to an unacceptable level. it will not shut down, and you will not see a "change drum message." if your paper feed problem is centered around the cassette/paper pickup area, you can try cleaning your rollers with water and a soft rag, and also make sure your rear paper stopper in cassette isn't pressing too tightly against the rear of paper stack. best to leave 1/8" gap, otherwise paper will not lift properly to the rollers.
hth,
razors
Apr 14, 2009 | Brother MFC 7420 All-In-One Laser Printer
MFC 7420 front paper jam
First you need to clean up your printer with duster and after thatn, check the toner and drum to see any paper jam or anything wrong,
Normally after you clean up the machine, should working fine,
if still not working, please replace the rubber roll.
Apr 06, 2009 | Brother MFC-7420 Printer
Message on brother MFC7420 "back door open" when it's not
Actually, you need to double check the back cover and front cover, open them all to check all paper jam.
Besure to check the back cover, normally all paper jam is from the back.
be sure to close the front cover at the last cover to close.
Apr 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
Back cover open error message MFC 7820N
Reseat inner rear paper guide to allow sensor to home correctly
Mar 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
''Back door open, please close back door'' - back door is closed
This Error Is Reoccurring On All These Units Open Close Back Door Then Unplug For 30 Seconds And Then Plug It Back In. Check For Error.
The Brother Website Says To Check The Paper But Almost All Of These People Have Checked For Paper Problems And For Jams With No Result.
Jan 14, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
637 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
