Question about Sony Xplod XM-554ZR Car Audio Amplifier
Cant get amp to work
I have a sony xplod power amplifier model number xm-554zr. i cant get the subwoofer to work..does any one have any hints or tips that might help me
  • 3 Answers
There are two nobs on the back of the amp they have to be turned inorder to ajust the woffer vol. make sher its not in power safe mode that will be a red light insted of a green one
Posted on Oct 21, 2008
Is the sony xplod cdx-gt71w able to support a subwoofer without another amp
Sure is.
The sony is bridgable as follows:
  • 100W x 4 @ 4 Ohm
  • 100W x 2 + 250W x 1 @ at 4 Ohm
  • This will allow 2 channels to run 100 watts each @ 4ohms with an additional single channel with 250 watts @ 4 ohms.
    The single sub channel is created by bridging channels 3 & 4
    Dec 22, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
    My 600w power amp XM-554ZR wont turn on.Its an Xplod 4/3 channel, and it was working fine...until yesterday that i checked it. the green light was off.
    open it n there is a red wire look at the end of it n u would see a black celinder with a with a white strip on it change that part if it is burn
    Jul 14, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
    I have a Xplod XM-554ZR Car Amp and the green light is blinking it worked just befor and now i have no sound
    The amp is in protection. Disconnect any speaker from it, then turn it back on, if it's not flashing, check your speakers with a meter and check speaker wires for shorts. If it's still flashing, you've blown the protection circuit and it needs to be replaced or repaired. Hope this helps
    Jun 11, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
    Hi i have a 600 watt sony xplod amp model xm-554zr and it recently stopped working. when i turn my car on the amp turns on but only for a sec then the protection light comes on, on the amp and it wont...
    sounds like maybe a speaker short, try unhooking your speakers and then powering up your amp, if it then powers up with the speakers unhooked try hooking up each speaker one by one untill the amp goes back into protection and then you have your bad speaker.
    Mar 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
    Bridge a two channel amp
    i the search bar type in....subwoofer wiring diagram....then go to crutchfield and it shows you your options.......
    Jan 28, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
    Sony xplod xm-554zr amp
    try disconecting ur battary for 2 min and try it again
    Jan 18, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
    Car amps
    important is to hav correct wires and groud cable...
    Dec 29, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
    My amp works on tuner but switches off when i change it to cd
    The remote turn-on wire from your amplifier is connected to a blue wire behind the head unit. That's a power antenna activation wire, so the amp only turns on when the tuner is on. Switch it to a blue/white wire from the head unit instead; that should be the amp remote turn-on output.
    Jun 16, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
    Sony Xplod XM-554ZR Car Audio Amplifier Logo
    169 people viewed this question
    Top Sony Car Audio & Video Experts
    xxxxxx xxx
    Larry Stiles
    Larry Stiles
    Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
