Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Changes modes TV will Change from Cinerama mode to normal by its self will clear up and a few minutes later do it again.
  • RCA Master
  • 5,138 Answers
Your set could have several reasons as to why it is doing this ,poor solder connections bad ribbon or ribbon connector or SSB board ,i would start with soldering deflection board alot of these sets have poor connection on Flyback Transfomer.
Posted on Sep 17, 2008
How do i fix canon copy paper?
Two possibilities come to mind:
1)
Change a setting in the service mode this might help it has cured a few E002s for me go into service mode *28* >copier>option>body>>> adj fix temp to 4 normally set at 0 is adj from 0>7 ..I had changed fusers for this problem b4 but this cured the error for me ..good luck..
Note: to enter service mode press *, then 2 and 8 simultaneously, then 8.
2)
Other possibility is to just clear memory. Again use *28* as above, then press copier, then function, then clear.
Jul 21, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
How do I turn off silent mode
"Silent Mode" is entered by pressing and holding the [ # ] key
on the handset for a few seconds (model D1680 & similar).
The easy way to end "Silent Mode" is to go to the BASE and
press the [ANS ON/OFF] button to turn off the answering
machine system. (push the button, do not unplug the power)
"Silent Mode" will clear a moment later and you can again
turn on the answering machine system as desired.
Feb 27, 2015 | Uniden DECT 6.0 Cordless Telephone...
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
Oct 04, 2014 | Kenneth Cole Unlisted Ana-Digi watch
How to change Nokia N72 mobile from silent mode to wringing mode
To change your phone's silent profile to normal profile, just hold the # key for a few seconds. The mode will change. To re-activate, do the same process again.
Thank You.
Mar 10, 2011 | Nokia Cell Phones
Picture adjusts from bright to dark every few seconds and with scene changes. Very annoying
The TV may be in Dynamic Mode - which would cause the screen to change brightness.
To change this you have to go to the picture settings and change it to Normal mode or cinema mode etc.
Dec 14, 2010 | LG Televison & Video
My tv is RCA 20B500T by pressing wrong buttons in the menu it was set standby mode and now i can't turn on it How can i change the stanby mode to normal mode?
Unplug the TV, wait about 5 minutes, plug it again. This should overwrite the standby mode. Read the manual if you have one.
Nov 02, 2010 | RCA Televison & Video
My flat screen 12 inch sharp Tv has a black sqaure apparening when I change chennel or do anything with remote. It only goes away when pressing the vol. botton the a few minutes later show up again. please...
Your closed captioning mode is set to ON. You need to just turn that off. That setting is available through the on screen menu. Just turn closed captioning off and it will work normally again.
Apr 16, 2010 | Zenith C27A24T 27" TV
Problem with RCA P42WED33 picture
If you have the tv on cinerama mode, it is black. If you use the scroll on picture mode it works
Jul 13, 2007 | RCA P42WHD33 42 in. Plasma HDTV
How to set watch
I just set the time on mine with these instructions 1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours) then you can use the upper right hand button to navigate thru seconds, minutes and hours. Then you can change the time with the lower right hand button you can only change the time forward. I hope this helps !!!
Apr 02, 2007 | Kenneth Cole RK5034 REACTION
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
27 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
