Question about Sony WEGA KE-32TS2 32 in. HD-Ready Plasma Television
Sony KE-32TS2U 32
I have a Sony KE-32TS2U that will not come on. When you press the power button it acts like its going to come on, you hear clicking and then the red light flashes three to four times. It will continue to do this until you press the power button again and turn it completely off. Get no picture or sound. Can you tell me what this indicates. It acts like it's a protection circuit or something cutting in and out.... are there fuses I should check? The unit was manufactured in 2002.
Thanks
  • rogermorgan Sep 17, 2008
    I have a Sony WEGA KDE 42XS955 with the same problem, only mine blinks 7 times. A repair technician says he thinks its the keyboard, a $390 item, plus service call which will cost $600 total. Then he adds the TV was only meant to last 5 years, and I have had it for four.
    Do I keep it, or junk it?
    Roger Morgan
    rogermorgan339@sbcglobal.net
5 Suggested Answers
Orbixx
  • 133 Answers
SOURCE: No power
It sounds like the backlight or an inverter board on the television may have failed. Check your warranty status on the television to see if you can get it repaired by the manufacturer for free.
Posted on Sep 06, 2007
davebies
  • 43 Answers
SOURCE: Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Posted on Jan 06, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Posted on Mar 14, 2009
  • 10 Answers
SOURCE: KE 32TS2U shuts down
Hi there , did find some basic info on a sim model on eservice info , was 2 part rar file of fault finding .
Posted on Jun 19, 2009
SOURCE: sony ke-42ts2u. When you hit the power button,
i have same problem did u find the fault
Posted on Sep 23, 2009
Sony KE-42TS2U. Nothing happens when the TV is
Seems some thing wrong with power input plug or may be with power board in side the tv. first confirm with different power socket.
Oct 07, 2013 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
No sound or picture on a sony ke p42m1 tv
press power button, press menu button. do you get a menu? if so, might be loose connections or faulty ground lead connections. with power off, reseat (unplug one, plug back in, repeat on all connectors) connectors on all the boards (including speaker cables).
Then carefully, with the unit on, check all the ground cables to ensure they are all screwed in tightly.
If the television has a menu, there could be a problem with the input board itself. Might not be grounded, might be bad altogether. If it looks fried and smells fried, its probably fried.
Mar 23, 2013 | Sony KE-P42M1 42 in. Plasma Television
I have a Sony FD Trinitron Wega (KV-32HS510). When I attempt to turn the tv on by pressing the power button on the remote or on the tv, the standby light comes on and I hear two clicks but tv don't...
The primary power supply is good,maybe the horizontal output transistor is deffective thats why there is no high voltage supply in the picture tube because theflyback have no supply voltage and oscilation.So check the harizontal output transistor and replace if deffective.
Sep 12, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a sony 32'' I think. model # KV-32FS10, serial #8047927, made Jan 2000. During a move, the tv was dropped and now when you press the power, your hear the click, the red click light flashes...
It sounds like that in the drop you may have cracked the main PCB. The PCB's usually crack around the heaviest part of the PCB. Probably around the flyback transformer.
Oct 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
respected sir please ignore the specalification of the product of lcd contrast ratio in the web page thanking you from feroz babu.A {c.s.a.}in next show room from chittoor {A.P}
Jun 08, 2008 | Sony WEGA KE-32TS2 32 in. HD-Ready Plasma...
Apple TV and Sony KE32TS2 Plasma TV
That's weird... I just looked at the back of my set Sony KE-32TS2U and it has a DVI port.
Nov 18, 2007 | Sony WEGA KE-32TS2 32 in. HD-Ready Plasma...
Tv wont turn on
How many times does the light flash, as there is a code that can give an indication as to what circuit is bad.
Jul 15, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony WEGA KE-32TS2 32 in. HD-Ready Plasma Television Logo
76 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
