Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
Posted on Sep 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Graph and trace buttons don't work
At first, they just messed up and show a screen from a tetris program I installed. I deleted all the files that came with the tetris program and now pressing either button goes to a blank screen. I can enter values to be graphed, but the graph won't display anything except a cursor when I hold down an arrow key. I enter an equation on the graph such as x^4-3x^3+6x-1=0 into Y1 and Y2 and I get an "ERR; INVALID DIM" but no graph.
Please help I have TI-84 Plus even when i have all of the coordinates in, my graph doesn't work, it just says 'invalid dim"
Anonymous
Level 2:
  • Expert 32 Answers
  • Posted on Sep 22, 2008
Anonymous
Expert
Level 2:
Answers
32
Questions
0
Helped
32275
Points
348
This is probably because you have the stat plot on. You would need to go to y= and then go to the top where it says stat plot 1 and un highlight it if it is highligted. That should fix your problem.
I am tryign to uninstall fix it, get error 5006
Installation or uninstallation of an application or game fails and gives the following error code:
This issue is due to a previous installation not finishing properly
Solution 1. Rename the Installshield folder
Make sure you've enabled Show hidden files and folders.
Find and rename the Installshield folder:
Windows 32-bit: C:\Program Files\Common Files\Installshield
Windows 64-bit: C:\Program Files (x86)\Common Files\Installshield
If there is an Installshield file in the Common Files folder, rename that one also (e.g. to Installshield_OLD).
Solution 2. Remove all traces of previous uninstall
If renaming the Installshield folder had no effect, find and delete any traces of uninstalled applications.
Applications that can assist you are: Revo Uninstaller, Windows Installer Cleanup Utility , CCleaner.
Alternatively, do a manual clean-up:
Close all running programs. Then clear the Temp folder (found via input of %temp% in Start > Search or Start > Run).
Use the Windows registry editor to delete registry entries related to the program.
Restart the computer.
hope this helps
Stop incredimail
Uninstall IncrediMail 1
  • Click on the "Start" icon and select "Control Panel"
  • 2 Click on the "Add/Remove Programs" or "Programs and Features" icon.
  • 3 Allow the program list to fully load; this may take several minutes if you have a lot of programs installed on the computer.
  • 4 Click on the icon for "IncrediMail" and click on the button "Uninstall."
  • 5 Confirm in the pop-up window that you wish to remove IncrediMail and all of its components from your computer.
  • 6 Wait for the uninstall process to complete, a success message will appear on the screen.
  • 7 Restart the computer.
  • Removing IncrediMail Components
  • 1 Click on the "Start" icon and choose "All Programs."
  • 2 Scroll down the list until you see a folder for "IncrediMail."
  • 3 Right click on the "IncrediMail" folder and select "Delete."
  • 4 Confirm you wish to delete IncrediMail, a window will pop-up showing the transfer of files to your trash bin.
  • Performing Disk Cleanup
  • 2 Click on "Accessories," "System Tools," and click on the "Disk Cleanup" icon.
  • 3 Select "Scan Local Drive (C:)" and allow the process to find all removable files.
  • 4 Place a check mark next to "Downloaded Program Files," "Temporary Internet Files" and "Temporary Files."
  • 5 Click on "OK" to confirm the deletion of the folders, files and any leftover traces of IncrediMail. The process will complete and a window screen will show a successful cleanup message. Restart the computer.
  • Cleaning Registry Files
  • 1 Click on the "Start" icon.
  • 2 Click on "Run" or click on the start search field at the bottom of the screen. Type in "regedit" and double click on the icon that pops up.
  • 3 Double click on "HKEY_CLASSES_ROOT" and then double-click on the "Applications" folder.
  • 4 Right click on on "Incredimail" and choose "Delete." Right-click on "Impcontent.exe" and select "Delete."
  • 5 Close out the registry window. Restart the computer.
  • 0helpful
    Casio cfx-9850gb plus calculators's graph messed up
    Press the RESET button on the back of the calculator. Use a starightened paper clip.
    1helpful
    Madame, Sir, I subscribed for CorelWindvd9 after a month trial. I payd 29 ? for it, but I cann't open the programm. An additionnal key is asked after de seriesnumber is submitted. I deleted all of the...
    Hello and welcome to FixYa . In order to re-install WinDVD 9, remove all traces of WinDVD manually only delete the folders if they exist, and if allowed.If you cannot delete a folder, try renaming the folder by adding .old to the name of the folder. You will need to show hidden files and folders on the computer on XP go to Start, All Programs, Windows Explorer,tools, Folder Options, View, Hidden files and folders, Show hidden files and folders. Using windows Vista Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, Control Panel, Appearance, Personalization, Folder Options, View, advanced settings, Show hidden files and folders, OK. The following folders will need to be erased.
    Go to My Computer Use Start button, or on the Desktop. On Vista, Computer. Double click on C: drive, Documents and Settings and the folder named after your username.
    When you reach the "InterVideo" folder, there will be a DVD9 folder, which is the one you are looking to erase. Note -This folder may be named Corel\DVD9 instead of InterVideo\DVD9 Erase the following folders Go to C:\Program Files\InterVideo or Corel delete the folder DVD9 Go to C:\Program Files\InterVideo\Common delete the folder Bin Go to C:\Program Files\InstallShield Installation Information delete the folder {E3993D46-AE3F-402E-9F9D-EEBDFBEC3564} Go to C:\Program Files\Common Files delete the folder InterVideo Go to C:\Program Files\InterVideo\Common\ delete the folder Bin The second place to remove WinDVD 9 settings is in the registry.
    Go to Start, Run type in regedit click ok. left hand column will be a list of items double click on HKEY_CURRENT_USER double click Software and InterVideo At the very end, when you reach the InterVideo folder,erase the DVD9 folder, by right clicking on it, and hitting Delete. Erase the following HKEY_CURRENT_USER\Software\InterVideo delete DVD9 HKEY_LOCAL_MACHINE\Software\InterVideo\ and DVD9 HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall and {E3993D46-AE3F-402E-9F9D-EEBDFBEC3564} Restart the computer. Go to Start Run type in "%temp%" and hit Ok. Erase as many files as possible .In the "Edit" menu, click Select All, go to the File menu click delete.Say yes to delete Reinstall your software and it will accept your key. Hope this gets you going. Please Rate Me. And you can always Ask Me.aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
    64helpful
    TI 84 Calculator has unwanted tabs at bottom of Y= screen.......?
    ok, your calculator is running the program Inequalz
    what you have to do is
    go into APPS, go to the program Inequalz, and it will give you options. choose the one that says 'Quit Inequal'
    that should work
    1helpful
    Dim Mismatch
    Hit 2nd then the Y= button and you'll get to the stat plots. make sure they are all turned off, sometimes random programs (ie. games) will turn on stat plots and screw up your other programs and graphs.
    If either error occurs when trying to graph a function (not a STAT PLOT), the error can be corrected by turning off the STAT PLOTS. The following steps will turn the STAT PLOTS off, allowing the graph of the function to be displayed.• Press [2nd] [Y=] to access the STAT PLOTS menu.
    • Select 4: PlotsOff.
    • Press [ENTER].
    • Try graphing a function like y = x^4-3x^3+6x-1
    No space, but memory stick is empty
    If your talking about your sd card lets say 4gb now says something like 92kb free, like all your memory just disappeared, then try this program it worked for me.
    SD Formatter
    Procedure to Install of SD Formatter
    1. Install the software after finishing the download
    2. Close all running programs on your computer
    3. Run or Execute the installer file
    4. Follow the instructions in the installation window
    SD Formatter Manual
    2answers
    Mikomi Webcam Error message
    The first thing I would do is delete everything (going into my computer > C: > program files > and uninstall it, just completely delete any trace of the unit) and reinstall it - if you still have problems look for updated drivers on the manufacturers site - you often find that a slightly later models software is also compatable with yours
    103helpful
    7answers
    How do I delete network magic from my hard drive. can not find this program in the remove/add software on the control panel
    1) Go to C:\Documents and Settings\All Users\Application Data\Pure Networks\Setup
    2) click on NmAppSetupInstaller_0.msi to run removal routine
    Top Texas Instruments Office Equipment & Supplies Experts
    k24674
    Jerry Naidoo
    Paul Bade
    Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
