Question about Hoover Vacuums
High squell - Hoover Vacuums
  • tmyorke Sep 16, 2008
    Hoover Windtunnell. The noise will stop for several seconds by hitting the front of the vacuum into something solid. The squell is ear piercing.
  • 943 Answers
Hi thanks for the question you probably sucked in some foreign object and it got stuck and its caught in the fan blade dismantle and clean thanks the appliance doc
Posted on Sep 16, 2008
Will not maintained power in high setting. Runs fine in low power setting.
I would recommend thoroughly cleaning all filters, most likely the high setting is overheating the motor and the thermal protection circuit is tripping. In other words, the motor isn't "breathing" well.
Mar 15, 2016 | Electrolux 2-in-1 Stick Handheld Vacuum,...
Rainbow e2 won't run on low speed runs poorly on high
Your model has a modulator that may be defective. Take it to a repair facility
Jan 03, 2014 | Vacuums
Bush roller squelling on dirt devil 130005 upright bagless cyclonic vacum
My dirt devil has 3 screws underneath- these are the same ones you use to change the belt--sounds like something is caught in roller-- mone was full of hair!
Jan 02, 2014 | Dirt Devil M130000 ''i'' Dual Cyclonic...
Miele 5281 vacuum cleaner permanently on high speed
Most likely the speed control board has failed. The solution for this is to replace the electronic unit unless you know of someone who can diagnose and repair circuit boards. The part is common and easily replaced for around $60. Miele's website can point you in the right direction for a service center, or tell me your zip code and I'll look it up for you.
Nov 09, 2013 | Miele Vacuums
My upright model 36933503 is making a horrible squeal. I've cleaned out everything that I can find to clean out. It seems to be worse when I turn on the Inteliclean mode. Any suggestions? It still...
A squell usually means a belt slippage, versus a broken belt. You might want to check for rubber fragments around the beater bar. But it could also mean that the rollers on the end of the beater bar are froze up.
Jul 27, 2011 | Kenmore Vacuums
Oster microwave model OM1Z01E0VG is not heating. The light comes on and the plate rotates and it sounds like it is working, but it does not cook/heat.
If your unit is under warranty, you should return it to the store or on to the authorized service center. but if not try to follow this simple steps.. (1). unplug the unit from the wall socket. (2) remove the protective cover. (3) check the high voltage fuse if blown or open... its located near the high voltage transformer.. (4) check the high voltage capacitor.. make sure you discharged it first to avoid injury... (5) if the high voltage fuse blown or and the high voltage capacitor is leaky, open, or shorted. you should replace it w/ the same exact value. (6) in rare circumtances a blown high voltage fuse opten cause by a shorted magnetron tube and a shorted or open high voltage diode could be the problem... just replace it w/ the same exact value to avoid injury... Ty
Jun 17, 2011 | Vacuums
I have a white B&D toaster oven. Something burned in the oven and the smoke came out the door and scorched the white part above the door. What's a good way to get rid of the stain.
you need to sand that stain down with sandpaper and then re-paint the area with a high temperature paint......hardware stores should sell it....it's trade name is called...."mr. touch up"......it is speciffically made for microwave ovens but is also very good for your oven.....the paint must be high temperature type since your oven is high temperature.....good luck
Dec 04, 2010 | Black & Decker Vacuums
Dyson motor making high pitched noise. Is this
Most likely, there's something in the dirt tube. Ic could be something like a piece of paper or cellophane, vibrating from the air going over it. without hearing it, a high pitch noise could be different things.
Jun 13, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
High pitched noise
High pitched noise usally happens when the suction pancake fan fins become loose on the shaft.Usallythere is two or more sandwiched on the motorshaft .. Matter of taking the tin split casing apart and check and tighten :^/
May 11, 2009 | Bissell 3750 Lift Off Bagless Upright...
Vacuums Logo
51 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
