Question about Lexmark X3480 All-In-One Printer
"cover open" messagge when cover is closed
My lexmark X3480 printer is not responding, power is on , would not switch off, message in display cover open when it is not.
  • 9 more comments
  • ricknew10 Dec 09, 2008
    Same problem. Printer will not respond under any circumstances. Sometimes the message "cover open" and other times nothing. I have to unplug it to get it turned off
  • charlie10 Dec 29, 2008
    My "open cover" is on also. There is a white clip that must have broken off from SOMEWHERE!! Can that white clip be replaced somehow??
    I have the same problem. I found the white clip! can it be put back in? HELP!!!
  • daysies Jan 03, 2009
    Mine says cover open when it's closed and I can't do anything with it. Not sure what people are talking about a white clip? What white clip? everything looks perfectly good. Shall I just take it to the tip and buy another one?
  • jaby1 Jan 08, 2009
    i have the same problem "cover open". this happened when i changed the ink cartridge. where is this white clip located that everyone is mentioning
  • Noah James
    Noah James Jan 08, 2009
    cover open on display. i know about the white clip I don't think that's it.
  • Noah James
    Cover Open message. None of the buttons do anything.
    I have a feeling this was known by Lexmark. That's why it came free with my rebate....the rep at the store told us the printer took up a lot of ink. which was a lie. its accually one of the cheapest cartridges. but i bet he knew about the problems with it...they didn't even offer it to us originally...i learned it was free with our computer on some blog...and brought it up and they gave it to us...
  • Anonymous Jan 18, 2009
    display in window "cover open" even when powered down and turned on again. any suggestions
  • stevie 2 Jan 25, 2009
    i changed the cartredge and when i whent to close the lid the screen just constantly says lid open.....ive tryed every thing to powering down and back up ..ive taken the cover off and and all apears to be fine i cant see any thing thats broken or burnt..this is the first time ive ever changed the ink since i brought it over a year ago so the warrenty has now run very dissapointed in this what seems to be common falt on one of the leading brands printer copyer companys ...terrible...
  • Anonymous Mar 16, 2009
    Same problem as mentioned by others..  Changed ink cartridge and now the printer basically does not work becau the cover open sign does not go away.
  • shireysa May 11, 2010
    Found the piece - don't know how to detach the top part?!?
I cannot find he curved projection.
the cover is alined there is no projection in the when closed.
Posted on Oct 26, 2008
  • 2,035 Answers
This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located
Posted on Oct 07, 2008
Hi Just wonder if you could help me i have a lexmark x3480 it has suddenly decided to display cover open and is not switching off at the control panel. The cover is not open and sits flush what is it...
It could either be due to a stuck cover sensor or the cartridges in your printer. Please follow the steps below to fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Rebrick (pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark X3480 All-In-One Printer
After changing cartridge the message "cover open"
raise the cover and see if u can see a switch of some kind puss it down and see if it will print or restart ur computer and see what happens
Jan 23, 2011 | Lexmark X3480 All-In-One Printer
I changed my ink cartridge, and now it has cover open displayed but the cover is closed
when you open the lid there is a small white piece of plastic witch should be attached to a very small micro switch .this keeps coming off for some reason .you have to find it and reattach it to the switch that is just right of the middle of your printer .hope this helps
Oct 02, 2010 | Lexmark X3480 All-In-One Printer
Message says lid is open when it is closed
Please try out the blow mentioned 2 options. I am sure the problem will be sorted out:
  1. When you lift the cover up along the back end of the gray plastic bottom cover, you'll see a square opening close to the right side hinge.
    There should be a little white plastic piece sticking out of there. If not, it fell into the guts of the printer. You have to remove the gray plastic and find the white lever and replace it onto a micro-switch along the back where the square opening is/was.
    You'll see a PCB (printed circuit board) there and the micro-switch will be located on that...
Hope this helps
2. Remove the screws on the front of the cover when it is open. Once removed At the back of the unit 2/3 rd from the left there is a small switch if this is pushed in ( and held by whatever means sellotape etc it will opperate normally (to change cartridge you may have to re do)
Sep 10, 2009 | Lexmark X3480 All-In-One Printer
X3480 printer message says;cover is open
seems to me a peice of paper is blocking sensor examine all parts of printer thourly!
Feb 26, 2009 | Lexmark X3480 All-In-One Printer
X3480 printer.message is saying;cover is open
the meaning of cover is open means --------the cover means.the thing which you lift to remove or install the cartridges.just keep that cover closed.if that cover is closed still its showing the same error.then the sensor which detects the cover closed is got moved from its orignal reset the sensor just tap all the sides of the printer for couple of minutes.mostly the top side and front side of the printer.and then check out the error must go away.if still the same error then its quite possible that sensor is broked as it very very delicate .so it needs a technician to replace the broken sensor.the cost to replace the sensor must not exceed then $5.
Cover open message
Jul 20, 2008 | Lexmark X3480 All-In-One Printer
Cover open error
There is a latch that preses a small switch when you close the cover (look for this) to indicate that it it close if it is broken you can tweek it using a toothpick or anything that may press the switch temporarily this may alow it to work as long as the switch stays down.
May 28, 2008 | Lexmark X3480 All-In-One Printer
X3480 cover open message
Ajkill is right, although his description isn`t very exact. Take off the complete scanner part: (back hinges first, then the blue arresting lever at the front), disconnect the flat band cable and the power supply for the scanner part and take off the complete scanner part. You´ll see a triangular part that goes in a slot of the dark grey cover which covers the rest. It should press againt a white lever which itself presses a little black switch sitting on the printed circuit board. If this white lever has fallen off the switch is always in "Cover open" position. To get it and reposition it (if it isn`t broken) you have to take off the dark grey cover which covers all the rest: take off the front screws and carefully lever out the sides with a small screw driver. Good luck with the repositioning, it is very fiddely and to see how and where it has to go you best use a magnifying glass!  But I could manage it and my printer is working now again. And good luck with fitting it all together again without breaking anything!
Mar 19, 2008 | Lexmark X3480 All-In-One Printer
LexMark printer X3470 malfunction
A White Clip On The Rear Has Fallen Off...
It Pushes A Micro Switch On The PCB (Printed Circuit Board)...
Poke Your Finger In The Middle Hole At The Rear Of The Grey Tray While You Have The Lid Open...
Feel The Switch And Press It... (Tiny Button)
You Will See I Am Right...
Try To Locate The Piece That Has Fallen Off...
Glue It Back On Or Order Spare Part...
Or Bin The Printer (Lexmark Is Useless) (Buy Epson)
I Hope This Helps!
Lance Smart
(Currently Trying To Resolve The Same Issue)
Nov 29, 2007 | Lexmark Office Equipment & Supplies
Lexmark X3480 All-In-One Printer Logo
154 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
