Question about Canon imageRUNNER 1370F All-In-One Laser Printer
Canon IR 1370F, it does not switch to legal paper when receiving legal size fax, I have legal paper in the bypass tray and letter in the paper tray. I tried to reverse the order but still it does not switch paper size to pickup from bypass tray. Copy is fine, it picksup the correct size. Can someone help to setup. Thanks. ashraf@marvellazer.com
SOURCE: Canon iR 3570
Open your top paper tray drawer and there should be a dial on the on the tray drawer (light blue). On there is different paper sizes. Turn it until you get "Ltr" and the paper is going up & down. This should fix the problem. We just had that same problem today and that's what the tech person told us. (Also, this dial only turns in one direction to the left). MMc
Posted on Nov 29, 2007
yalmer
  • 552 Answers
SOURCE: Scale from legal to letter
Legal size is 11x17 inches and you cannot get a legal length document when selected for landscape.
Landscape means that it is 11 inches high and 17 inches wide.
You need to set it to letter and select 11x17 inches.
Posted on Jun 23, 2008
  • 385 Answers
SOURCE: Canon ImageRunner 1370F - error on receiving faxes
The sensor arm might be too short and its not reading the paper correctly!Try replacing it!It sits under neath the drum\cartridge unit.
Posted on Mar 31, 2010
muntejaya
  • 10421 Answers
SOURCE: Canon ImageClass D680 "Incorrect Paper Size" error message
Hi, please get new driver here: www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay kbxlz
Posted on Feb 12, 2011
SOURCE: We bought a canon pixma
Some info from Canon's site in the specs:
Max. Document SizeFlatbed:8.5" x 11.7"
ADF: 8.5" x 14"
This machine can only copy legal documents if you put them in the sheet feeder, not on the flatbed.
As for the paper supply, the cassette is indeed too small for legal paper. The automatic sheet feeder, however, will handle legal paper. That's the tray in the rear that you use for specialty paper; see page 17 of the Getting Started manual.
If you use the ADF and the rear tray, you can copy legal documents. That may not be as convenient a solution as you were hoping for, but it is better than no solution at all.
Posted on Feb 28, 2011
Set legal tray
go to in service mode.
Add. function 2,8, additional function.
go to printer
CST
U2 - enter value 36
press ok.
restart machine.
Now put paper CST setting on U2 put legal paper
now. you can get copy of legal
Nov 30, 2013 | Canon iR 2022 Printer
My IR 6570 feeder only detect A4 paper and not F4/Legal paper and some times misread the paper
check the legal size on the glass and measure it with ur paper.this is common problem as these machines are designed for specific country papers and most times the legal paper of different countries differ .no solution dear .try using the bypass tray
Sep 16, 2011 | Canon IMAGERUNNER 6570 Copier
Have a canon b95 faxphone machine. When receiving legal size documents, it receives and prints on 2 separate sheets. How do I correct so incoming only prints on 1 legal size paper
Use the settings to select LGL as the paper size. (But note that you have to have legal size paper in the machine)
1. Press the Function key (left side, lower right button)
2. Press the Start/Copy key (right side, lower center button). The display will show USER SETTINGS.
3. Press the Left or Right arrows (right side, upper row) until you see PRINTER SETTINGS in the LCD.
4. Press the Start/Copy key
5. Press the Left or Right arrows until you see PAPER SIZE in the LCD.
6. Press the Start/Copy key
7. Press the Left or Right arrows until you see LGL
8. Press the Start/Copy key
9. Press the Stop key (right side, lower right button).
May 18, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
How to change paper size from letter to legal
I dont have info on your PC-920 but almost all canon copiers use the additional function button to gain access to settings. Try selecting the additional function button on the operation panel, then use the - or + buttons to scroll thru your options. When you see Reg Paper Size press ok then use the - or + button to select 8 1/2 x 14 Legal paper then press ok. This is the steps to take on small canon copiers like the ir 1019 and 1023. Your copier is just about the same so this might work. If you have a user hand book that info should be in there. Good Luck.
May 14, 2010 | Canon PC-920 Black and White Copier
Canon LASER SHOT LBP-1210 Printer how to set legal page
For printing the Legal Size (8.5′x14′) in cannon LBP-1210, follow the instruction:
Step 1- Go to start
Step 2-printer and faxs
Step 3-select printer(Canon LASER SHOT LBP-1210)
Step 4-go to file
Step 5-select Server properties
Step 6-select creat new form (for legal page)
Step 7-give form name legal 1
Step 8-give paper size width 8.50in, hight 14.00
Step 9-give paper margin top 0.30in, left 0.30in, right 0.30in, bottom 0.30in
Step 10-select save form Step 11-then select advanced
Step 12-select informational notifications for local printers
Step 13-select apply
Step 14-then close
Step 15-select Canon Laser Shot LBP-1210
Step 16-select printer
Step 17-select properties
Step 18-select-select forms
Step 19-select change forms
Step 20-select legal 1
Step 21-select OK
Step 22-select apply
Step 23-select OK
Remember: 1 U need to set paper size (8.5′ x 14′) manually in the word documents and befor printing you need to set in printer properties "Legal 1′ for printing. Print preview may not show the whole page but the printer will print the whole page.
All the best.
Apr 24, 2010 | Canon LASER SHOT LBP-3000 Printer
Can't send or receive faxes after fixing error code problem
your printer CHANGE PAPER TO
A4/LTR/LGL PLAIN
The paper size setting is set to a size other than
A4, letter or legal in fax receive mode.
The paper type setting is set to a type other than
PLAIN in fax receive mode.
Set the paper size setting to A4, letter or
legal and load paper of the same size.
Set the paper type setting to PLAIN.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Print legal size paper problem
when you give print command that time chage the paper size from a4 to legal in print proeprties and choose paper size legal.
Sep 08, 2009 | Canon LASER SHOT LBP-3000 Printer
Canon LaserClass 7000 - Receiving problem
Make sure the rear guide is pushed up tight against the paper.
Remove all legal size paper and make a copy.
Dec 13, 2007 | Canon LaserClass 7000 Plain Paper Fax
Canon imageRUNNER 1370F All-In-One Laser Printer Logo
126 people viewed this question
old marine
old marine
