Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips 60PP9202/17f I just got the tv and it not working. when i plug it in and hit the power button on the tv it starts to turn on and is vary light blue and a 3 inch blue line on the botom of the screen. this will last for about 30 sec and then it shuts off and the power buton blinks i think its 6 times every 10 sec untill i unplug the tv from the wall. please some one help me on this.
  • 4,234 Answers
This is a CRT based TV that seems to be having a problem with vertical deflection. If you have no experience with TVs, I'd suggest that at a minimum, you get a detailed repair estimate. Post the results of that here and we can help you to decide whether or not to fix the set. Also, we may be able to walk you through the actual repair. Unfortunately, this type of problem is not easily diagnosed remotely. Additional visual inspection as well as measurement is required to determine the exact problem.
Please keep us updated and we'll try to assist where we can.
Dan
Posted on Sep 16, 2008
    Scholar:
  • 148 Answers
IT IS A BACK LIGHT PROBLEM. BETTER TO IMMEDIATELY CHECK THE UNIT FOR REPAIR.
  • Zander Rovic Ocampo
    Zander Rovic Ocampo Sep 16, 2008
    The
    Monitor
    So first off you will need your monitor. Most LCD
    monitors are constructed the same way, with a cold
    cathode bulb as the back light source. A plastic
    sheet acts as a lens that refracts the light from
    the edge to the front of the screen and through
    the LCD panel. A small 12V inverter provides power
    to the bulb. As the bulbs get old they can have
    a hard time starting, lighting at all, flickering,
    or even putting out a strong pink colored light
    The
    Replacemt Backlight
    Cold cathode bulbs can be hard to come by new and
    unused, and they can cost allot ordered from resale
    vendors. So we looked to case lighting for the source
    of our bulbs. Xoxide
    has an excellent selection of them with the inverter
    for about $9.00 and a couple bucks for shipping,
    and so does lcdparts.com.
    A good 15" kit will provide a bulb for a 15" monitor
    just fine! I have been able to find 17" kits as
    well as 19" kits. But most likely you wont have
    to replace your inverter, and that will save you
    a couple bucks.
    Tools
    that we used
    ( I.E. you may want to use as well )
    One note on power tools: use them at your own risk. Be sure to read and
    understand any and all documentation on the tools you use. No amount of
    documentation can make up for experience, but there are many people with
    serious eye injuries at the school of hard knocks. If you don't know what you
    are doing, don't do it and find some one that can help.
    Screwdrivers
    Pliers
    Soldering iron
    Wire cutters
    if your not familiar or have experienced to do thi
Philips 52pfl5704 no screen image
Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 28, 2014 | Philips 42PFL3704D LCD TV
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
http://www.retrevo.com/support/Philips-60PL9200D-TVs-manual/id/633ag423/t/2/
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
Aug 14, 2011 | Philips 60PL9200D Projection Televisions
I do not have a manual and need to know how to set it up and the code for a vizio tv.
On your remote you will find a setup botton and what i want you to do is hit set up then hit the tv botton and hit channal up and do that untell it turns off your tv are the channal if that works it tv botton again and your remote will work other wise in the back of your remote it well tell you a code number and go on line to philips and they will give your your codes for you.
Dec 09, 2009 | Philips Magnavox Learning Universal Remote
My Philips 60P8341 TV would not turn off. Turned off power strip and tv would not turn on. Waited an hour and tv turned back on, then tv turned off and power button blinks and then theres a click the...
Your convergence board is faulty. Common problem for this model. Pull the back cover off and look to the north and look for a jumper jack [1516 i beleive] and pull this off. [TV unplugged of course] Now plug in the tv and power up...If the picture is distorted you have bad convergence ICs. If picture is good...you may a bad audio IC. You can do this, just be dang careful and good luck to you!
Nov 25, 2009 | Philips 60P8341 60" Rear Projection...
50" philips won't power on. get the 4x red blink led light
i have fixed 3 of this tv, with that exact problem in the last 2 weeks, needs a power supply, you can try to unplug it again, plug it in, hit the power button, as soon as it turns green, unplug it again, after 15 seconds , plug it back in, if power doesnt turn on by itself, turn it on, if it turns red again, emediatily hit power again, may have to hit power a few times in a row, but most of the time you can get it to come on this way, once it is on, it should run ok, until you turn it back off, but not a fix, needs power board
Jan 10, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Philips 42PF9956/37 Plasma TV - Looking for y sustain board
it isnt the Y-SUS board, it is the Power supply, iv fixed this exact problem twice in the last month, try turning the tv on, and when it turns green, unplug it real fast, while light is still green, after 15 seconds plug it back in, then hit the power button, if it dont come on, hit the power button again, this time, as soon as it turns off, hit the power button again to turn back on, sometimes you can trick the tv and it will turn on, at least i was able to do it, and once it comes on, it should work fine, untill you turn it off again.
Jan 10, 2009 | Philips 42PF9431D/37 TV
It takes 5 to 7 minutes to turn on my Magnavox HD TV
IFyou feel confident and can locate switch mode power supply with back removed.
Try warming switchmode power supply before turning TV on.
If TV turns on normaly then there are some small capcitors that are a common cause of this fault.
Otherwise look for DRY or CRACKED solder jointson PCB
BUT DON'T do any of the above if your are not confident send it to a TV repaiman.
Sep 11, 2008 | Philips Magnavox MS2530C 25" TV
Power problems with philips magnavox 25TR19C1
aparece codigos en la pantalla MSD luego 55 sy
Dec 18, 2007 | Philips Magnavox 27MS343S 27" TV
Need codes!!!
1. Go to http://www.urc.philips.com/ 2. choose US URC modles 3. choose US2 4. choose US2-P63S. Really dumb but the owners manual states PH601S but in Philips web site its called US2-P63S -
Sep 07, 2007 | Televison & Video
No picture on my Philips HDTV
call a tech let them check your tv if no power it will be the power supply or related circuits.if you have sound then it could be video circuit module.as you said that it dont have pictures you did not mention anything about sound.good luck
Apr 23, 2007 | Philips 42PF9830A 42 in. LCD Television
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
52 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
