Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
Keeps Disconnecting Everytime I turn my blue tooth on it shows on my phone screen that its connected. Then as I'm dialing the phone number it shows on the screen that's its either disconnecting or transferring to phone. It's worked great all along except now. Is this a phone thing?
Try and re-pair your device with your phone. Here is a quick run down if you don't know.
First, remove the device from your phone's bluetooth list.
Second, and this works for Explorer Series: 220,320, 330, 340, 350 Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue. This will place your device back in discovery mode.
Third, use your phone to search for new devices and add it back to the list.
FYI- ALL listed models passkeys are 0000. (4 zeros)
If this doesn't help the only advice I have for you is 1. submit a help request to Plantronics web site or 2. Get a new device.
Posted on Oct 04, 2008
Set up for Blue Tooth
Please specify your phone make or model
Jan 17, 2014 | 2013 Toyota Venza
Hp dv1000 bluetooth is not working and i dont have drivers
Hi, Ithink you should can if you follow my instruction. If you want to use cell phone ,follow the step.
1. Just enter your Blue-tooth in your pc. 2. when the icon show your task menu bar just 3. double click on icon 4. add>check on my device >next(ensure phone Turn BTon ) 5. You can see from bellow link, step by step.
http://www.acroname.com/garcia/tutorials/bluetooth/connection/connection.html Or you can download PDF file for details http://www.sena.com/support/downloads/#sd
You can see, Blue-tooth on ,in the phone model.
Just select the device >choice any ask code >I will advice you, pleaseselect, let me choice> type any 8 digit >next >now type the samenumber, in your mobile >finish
For dial up go r click on my network>properties>create a newconnection> connect to internet>next >set up manually>connect using dial-up>select your mobile modem>next >type any name >type the exactname and number eg: for Air-tel(India)=*99#>next >no user name andpassword just next >check on add short cut>and finish.
Just double click on the icon, it will connect soon.
Or you can install PC suit and set it through the following there step. Setting> Setting >participate tic on yes .Doubleclick on phone icon >next>tic on Blue-tooth connection >next >selectyes the phone mobile>next
Remember always accept from the mobile for built up connection . Hope it willhelp you.
Feb 23, 2011 | HP Pavilion dv1000 Notebook
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
I go to the bluetooth menu and turn it on. it says "Bluetooth turned on" But the icon fails to appear and file transfer fails.
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Aug 16, 2010 | Sony Ericsson K550i Cellular Phone
How to connect sony ericsion w395 via blue tooth
Take care.
Jul 07, 2010 | Sony Ericsson W395i GSM Quadband Phone ...
Blue tooth connectivity, camera, writing T9
simple you just let it repaired by acellphone technician
Aug 10, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Motorola V557 Black Screen
Hello! The blank screen issue with your V557, could be the LCD Module itself or even the connectivity of the cables inside. Usually the interference is the cables within the handset. It garbles the screen to either a black or white color and can sometimes distort the entire display. This can be a definite sign of hardware problems.
Now without a screen to see, how would you able to even use the handset? Your device is indeed an older model and the features that it offers are not vast. It has no expandable memory to store any pics or movies or music and it barely supports blue-tooth.
In my opinion, with the hardware issues u are facing are great enough to prohibit you from using blue-tooth to transfer your media.
Thanks.
Apr 20, 2009 | Motorola Mobility V557 Cellular Phone
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
366 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
