Question about Zebra Stripe S500 Thermal Label Printer
Printing every other label
I have a Zebra S500 and it was working fine. I tried to calibrate and now it is printing every other label. I could not get it back where it was.
    Champion:
  • Zebra Expert
  • 285 Answers
Download the segull driver(www.seagullscientific.com) reset to factory defultIt is possible that is on continuos labels but you need to be on non-continuos. you can do it with the botons, but is easy with the driver.
Posted on Nov 13, 2010
On the Zebra it was printing 4x13 labels without a problem. However when I tried to print a 4x6 label it still thought there was 4x13 stock in the printer. I played around with the label format size, even...
I think this is more related to the calibration of the label each time you change the new label size. I use ZM400 and your printer should also have the same setting. Under setting, put the When Head Close setting to Calibration. This will let the calibration perform automatically when ever you load a new label size and close the print head. Well 2 label will be lost every time.
Aug 31, 2011 | Zebra 105SL Thermal Label Printer
The Zebra 105sl is not printing fluently. By that I mean it will print two rows of labels, then stop for two rows, then print two rows again. My question is how do I get it to print continuessly without...
1st try to calibrate the machine. It might not like the media (labels) you have in it. Try the basic calibration by going through the menu and print the sensor profile. If that doesn't work, try the media and ribbon calibration option.
Aug 17, 2010 | Zebra 105SL Thermal Label Printer
My Zebra 105SE is printing fine on the left
I think the 105 has an adjustment on the printhead. There are left and right hand adjusters just above the printhead. It sounds as if the right hand one does not have enough pressure on it, try increasing the RH one and see the effect on the print.
Jan 06, 2010 | Zebra 105Se Thermal Printer
The label prniting is not work properly, print two
you can calibrate from printer driver .Go to printing preference select advanced setup and select Calibrate
Or you can calibrate from printer.go to menu in the printer and select media and ribbon calibration it will calibrate ribbon and label
Aug 06, 2009 | Zebra S4M Thermal Label Printer
Printing a 2.25 in label on Zebra LP2824. Prints
Recalibrate the printer and you should be good to go. Do this by turning the printer off, press and hold the button and turn on the power. When the light flases red let go and it will calibrate, at the end it will do a printout. Reboot the printer and your fixed.
Jul 28, 2009 | Zebra Eltron LP 2824 Thermal Printer
Zebra stripe s500 skips 5 labels prints 1 skips 1
He are the steps you need to calibrate your printer
Label Length Calibration
Note: This is typically the only procedure required when first installing the labels.
1. Load the printer with media and ribbon.
2. Press the printer front panel MODE key until the CALIBRATE LED is lit.
3. Press the FEED key and allow the labels to feed.
4. When the labels have stopped press the MODE key once to save the value in memory.
Jul 10, 2009 | Zebra Stripe S500 Thermal Label Printer
Configure to print certain labels?
You could use the windows driver from
www.seagullscientific.com to send the parameters to your printer
Apr 17, 2008 | Zebra Stripe S500 Thermal Label Printer
How to configure the Zebra S500 using a USB to Parallel adapter?
The Zebra Stripe S500 has a RS-232 SERIAL interface using a DB-25 connector . You'll need a USB to SERIAL converter, not parallel. Be sure that the baud rate and data/stop bits are set the same on the printer and interface converter. Generally speaking, use the fastest setting possible (19200 baud) unless you encounter problems.
Oct 30, 2007 | Zebra Stripe S500 Thermal Label Printer
Zebra Stripe S500 Thermal Label Printer Logo
139 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
