Question about LG KG800 Cellular Phone
Insert Sim Card
Hi
My phone has suddenly stopped working. The message on the screen says 'Insert Sim Card' i have taken sim out and put back several times but still get the same message.
  • tones_master Sep 21, 2008
    i hav the same problem
  • Anonymous Apr 10, 2009
    it says inert sim
    Problem Solver:
  • 5 Answers
WWATER GO INSIDE TE PHONE REMOVE BATTERY BLOW IT
Posted on Sep 16, 2008
Hello my nokia 5230 has a problemes when i put in the sim card i get sim card not valid could you help me please
Hi I'm a mobile phone Tech.
If your mobile phone is on a contract with a service provider, most of the times it will be locked in with them for the duration of the contract,
So if you try to insert a sim card from a different service provider, it may say "sim card not valid'
Try to insert your original sim card and see if that works.
Otherwise if this IS your original sim card and all of a sudden this message "sim card not valid" has appeared, then the sim card has gone faulty and you need to get a new sim card from your service provider eg... Vodafone.
Hope this is helpful
MobileJB
Jul 13, 2011 | Car Audio & Video
Most time it say insert sim
hi,try put that sim in another phone..try see if you will still get the same message...if you get the same message, it means the sim card is bad...but if you do not get the same message you could look for a clean matterial to clean the place you normally place your sim on the phone..if this does not work also, the you will have to go see an expert to help you handle it.
cheers.
Jul 17, 2010 | Sony Ericsson K750i Cellular Phone
Keeps saying 'please insert sim'
Your SIM card is not being read anymore due to a number of reasons.
Try rubbing the SIM card with a clean smooth dry cloth and then insert it again.
If that doesnt work, your SIM might be damaged, take it to your network provider and they will replace it, hopefully with your same phone number.
Nov 15, 2009 | Samsung SGH-J750 Cell Phone
Phone not reading sim card
dont worry there is some prblm in ur sim pls contact ur customer care there is no prblm in ur phone
Oct 11, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Cect P168 not dectecting My sim Card
The "insert sim" error is a common error. Usually it is caused from putting the sim in incorrectly.
Try this. If this is the one with the sim card ports that are on top of eachother than put the sim card in the port closest to the phone with the gold side pointing up.
Insert battery, turn on phone.
On the phone, go to the main menu. Tap phone settings. Tap dual sim settings. Tap to open sim 2. Go back to the main screen.
If that does not resolve go back to phone settings, tap dual sim settings, tap to open sim 1, go back to the main screen.
If this is the type of phone with the sim card ports seperate, insert sim with gold side down in either port. Go to phone settings, tap dual sim settings, tap open dual sims. Go back to main screen.
If this problem persists than either the phone or the sim is defective. Test the sim by putting it in a phone that belongs to the carrier the sim came from. If it works in that phone it is not the sim.
Sep 09, 2008 | Dual Electronics CECT P168 Cellular Phone
Motorola v3 razr
Try making sure the connection points for the sim are clean. After taking the sim out, gently but firmly blow into the area to dislodge any dust. Put the sim back in and cross your fingers.
Jun 12, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Sony ericsson S500i
Hey i'm having the same problem with mine, u prob got it sorted by now but i found that it is because my sim card is so old, tested it with my friends brand new sim card and works fine,
did you solve the problem?
Jan 15, 2008 | Lands Phones
Samsung e-250 i need unlock code
Please follow the instructions carefully! Following are the 12-point instructions to unlock your Samsung E250 phone:
1. First do a CUSTOM RESET by tying in:
*2767*2878#
(Phone may display foreign language – don't worry! The last digits after the * will appear as - - - -; this is normal)
2. Turn off your phone
3. Take the battery and SIM out of the phone
4. Take a wrong network SIM (a SIM the phone does not currently accept) and insert it ONLY HALF way in, so when you turn on the phone it won't detect the SIM. Very important so the phone won't ask for network password and will show "Insert SIM" message.
The process of inserting only half of the SIM. I advice you to take care and do it with a soft approach as you might not have done this before.
5. 2. Now put the battery in carfully behind the protruding SIM card and switch the phone on. The phone must show "Insert SIM" message.
6. 3. Without turning off the phone, now push the SIM card all the way in, at this stage the phone must continue to display the "Insert SIM" message with the WRONG SIM inside.
7. Now make a FULL RESET by typing: *2767*3855#
9. Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
8. The phone should reboot working with "wrong" SIM inside. (Do not turn off the phone)
10. Disable network lock by typing: #7465625*638*00000000#
12. Check this is done with *#7465625#
If your phone is not unlocked please retry the above ensuring all steps are followed to the letter, 9 out of 10 people who have problems have made a simple error and find that when they repeat all the steps it works.
Jan 08, 2008 | Nokia 1600 Cellular Phone
SIM card registration failed
You might have filled up the memory to the brim and the phone doesn't have enough to switch on.
Try reformat to original settings. anything you stored on the phone will be lost.
How to reformat your phone, first turn it OFF. Press * 3 send at the same time and keep them pressed while you turn the phone on.
Give it time to work.
Remember, do not let go the 3 keys until you see the formatting screen.
After a few minutes when the process is over, your Nokia N70 will be back to the original delivered system.
Jan 03, 2008 | Nokia N70 Cellular Phone
Insert sim card message
i got problem with my phone n-gage,after i turned my n-gage on..itssays "insert sim car"..i already put my sim card inside of it
Mar 01, 2007 | Nokia N-Gage QD Console
LG KG800 Cellular Phone Logo
193 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
