Question about True T-49 Side by Side Refrigerator Commercial
T-49 side by side ref commercial
My ref just died down.....lights turned off and the fans are not working...what's wrong?
  • 943 Answers
Hi thanks for the question if the lights turned off as well as fan check for a blown fuse replace fuse and try again thanks the appliance doc
Posted on Sep 16, 2008
How to adjust doors on Model T-49
How is the door out of alignment...wont close, wont open, twisted from top to bottom?
Tell us what is wrong specifically.
Oct 27, 2013 | True T-49 Side by Side Refrigerator...
Oil leaking from fan...True TS-49. Fan stopped...got fan going by spinning it. but frig is not sealing.
It sounds like you need a new fan motor. Is it the fan inside the refrigerator compartment or the very bottom of the unit? And what do you mean by not sealing? Let me know. I can order the parts for you.
Nov 25, 2010 | True T-49 Side by Side Refrigerator...
Evap fans not running after power loss and restart
It sounds like you could be stuck on a defrost cycle? The system is in a pump down cycle, check solenoid valve is off but compressor is not cutting on pressure switch.
Mar 04, 2009 | True T-49 Side by Side Refrigerator...
True t-49 compresser not running at all
Is the compressor fan motor running?
If so, replace the capacitor on the compressor.
If no.
Replace the thermostat.
Feb 24, 2009 | True T-49 Side by Side Refrigerator...
Top fan on True T19 noisy
no all the fans have to be working for the unit to work correctly
Feb 22, 2009 | True T-49 Side by Side Refrigerator...
We'd like to stop the True T-49 fans from running all the time
You would have to have your fans power supply wired in series with the thermostat.
Jan 06, 2009 | True T-49 Side by Side Refrigerator...
Extreme condensation, pooling in the floor of T-49
Please check your drain. These units have a drain pan for the condensation. After these units have been running the drain may develope a build up of debris.
Sep 26, 2008 | True T-49 Side by Side Refrigerator...
T-49 delivery - set-up
Make sure that the service valves are open. After you have checked that, hook up your refrigeration gauges and verify that you have not lost all of your refrigerant. Please do this and let me know if you need any further guidance.
Aug 04, 2008 | True T-49 Side by Side Refrigerator...
Kitchenaid refrigerator not working
it would not be likely to stuck in defrost mode but my guess would be the compressor is not running. overheated or the condenser is full of dirt. as you said , you can hear fan running, is it inside the ref or outside?..or both?..if that is the case, then it is on freezing mode because the fans would not run on defrost mode..i hope i was able to help..
Jul 05, 2008 | True T-49 Side by Side Refrigerator...
Inside fans not running
verify wiring probably lose wire(s) in movement
Apr 21, 2008 | True T-49 Side by Side Refrigerator...
True T-49 Side by Side Refrigerator Commercial Logo
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
