Question about Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis electric dryer 2008 WTV model (type WDT50)
This new dryer seems to barely heat in the regular cotton modes. In permanent press 40 minute setting it does fairly well. All the vents were just cleaned. Venting length appears fine. You can put the dryer on "very dry" and it stops when it only registers "damp dry." Very frustrating.
  • 1462 Answers
SOURCE: Bosch Dryer venting
i think you will find that one of these caps should be off and preferably connected to a vent hose to go outside the house. the reason they are blowing off is that the air has nowhere to go
Posted on Jun 27, 2007
micromaster
  • 3614 Answers
SOURCE: bosch axxis 3510 dryer
well first check the Thermal area inside the unit, if you have an idea doing this, it could possibly easily for you to do the work.. on the thermal area check for any burn fuse or any faulty parts relating or was connected on the thermal area.
Posted on Jun 26, 2008
johnychel
  • 796 Answers
SOURCE: bosch axxis 3510 dryer doesn't dry clothes
click here
this might help you trouble shoot
  • 10 Answers
SOURCE: I have an axxis not drying and code F:03 comes up
Most likely your wall vent is restricted. Unhook dryer from wall vent and pull away from wall. If you don't get code your wall vent needs to be cleaned.
If unit still gives code sensor is either bad or theres a restrictions inside machine, likely in the blower wheel hosing. Air flow when running should be strong coming out of vent. many times strength of a blow dryer.
Posted on Jul 18, 2009
SOURCE: Bosch Axxis Condensation dryer not working
Try to vacuum clean inside the door contact breaker (female part). If you can remove the dust it should start working again.
Posted on Aug 01, 2009
I want to know how hot my dryer gets. I do not have temp. controls on my model
Good Morning Tabitha,
I see that you are looking to see how hot your Frigidaire dryer, model# FER311FS, actually gets, due to you not having temperature controls on your particular model. Being that you have just the timed dry cycle, it provides up to 100 minutes of drying time at high heat for regular and permanent press items. When drying permanent press items, turn the cycle selector to 40-50 minutes. This is the average time needed to dry most loads of permanent press items. The load tumbles without heat during the last 10 minutes of the Timed Dry cycle. Use this setting to refresh clothing, pillows or blankets or to dust draperies. Heat-sensitive items such as plastics, foam rubber or similarly textured rubber-like materials or items containing feathers or down should be dried only with this setting. Hope this is helpful.
-Best Regards-
Mar 17, 2014 | Frigidaire FER311FS Electric Dryer
The dryer wont stay on the heating mode
how long does it run before quit heating . unhook dryer vent hose and try with vent discounected
Nov 29, 2013 | Haier GDZ5-1 Electric Dryer
How do i use the dryer
my dear
Clean the lint filter or screen before each load.
Inspect washed items before placing them in the dryer. The dryer's heat will set in stains that have not been removed.
Shake each garment before transferring it from the washer to the dryer.
Choose a dryer cycle. Opt for the regular cycle if most of the load is all-cotton fabrics, or set it on permanent-press cycle if the load consists mostly of synthetic or permanent-press fabrics (a cool-down period prevents wrinkling).
Add a fabric softener sheet,
Remove the clothes once they're dry and hang them immediately...
you can still watct this video for some tutorials..
http://youtu.be/HJqvvL2G9WY
Nov 22, 2011 | Dryers
How long is the burner heat cycle supposed to be for a 2007 kenmore dryer
"How long is the burner heat cycle supposed to be for a 2007 Kenmore dryer?"
That would depend on which dryer setting (permanent press, cottons, delicate, etc) you had it set on and the amount of time you had it set to dry. The time setting is really what determines how long the cycle will be. The other setting determines the amount of heat that will be needed for that selection..
Hope this helps ....
Mar 25, 2011 | Heating & Cooling
Bosch Nexxt 500 gas dryer takes a long time to dry
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Fuse blowing
Your exhaust vent is blocked.
Timed dry is High heat.
Permanent press is a medium heat and intermittent.
The dryer does not get as hot as often in Permanent press mode. Therefore the fuse does not reach critacal and blow.
Remove the vent at the rear of the dryer and run a timed load.
If it dries correctly, repair your vent blockage.
If not, repost and I will lead you to the next step.
Feb 19, 2009 | Kenmore Dryers
Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Jan 25, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Not geting hot enough
The most common thing to cause this is a blocked vent. Start the dryer and go out to where the vent comes out of the house and see how hard it blows. If you feel little air out the vent, you will need to unhook the dryer from the vent and see how hard it blows there. If it is blowing good there you need to have the vent pipe cleaned. If dryer isn't blowing hard out the back, please reply back with the model number so I can give more detailed directions on checking the blower wheel and ducts.
Oct 11, 2007 | Kenmore 74602 Gas Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
225 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
