Question about Sony Playstation 3 (PS3) Console
Having trouble playing my Ps3 on a non HD tv after already using it on a HD tv
When i first set up my ps3 i was using it on an HD tv. I no longer have this tv and am trying to use it on a normal tv. No video or audio is outputing. Any ideas how i can fix this?
Hey bro try going down to circuit city, best buy and get the HDMI cord that converts to a Component cable on the opposite end. You can do this as long as the back of the non H/D tv has the Component Inputs on the back of the TV. If that does not work get the HDMI cable that converts on the opposite end to a S Video signal and connect that end to the S Video input on the back of your tv. I have seen these cables at circuit city in the playstation section. Again on one end of the cable it has your HDMI input to connect to your ps3 and on the opposite end of the cable it has the S video plug to run to the back of your tv and plug it into the S Video input. Same thing can be said for the HDMI on one end of the cable and the Component cables on the opposite end to run to the back of your tv. This will work if you find those cables. Good Luck.
Posted on Sep 17, 2008
I have a new Sony HDMI LCD tv and a PS3 game system. I am having trouble playing Dead Rising 2 in 1080i mode. It will only play in 720 p mode, even though I changed the setting to 1080i on the...
Some hd tvs do that,,its not u,,try in ps3 settings turn only 1080i setting on,,only,,same on tv also,,if not try with evryone of them selected,,let hdmi cable do it automatic
Nov 04, 2010 | Video Game Consoles & Games
Connect ps3 to a non HD tv and picture only black and white?
Are you connecting it to a new SD tv after having been connected to an HD set? You can force the system to reset the video resolution settings by pressing and holding the On/Off button after the system has already turned on. I believe it is ~5-10sec. You will hear another beep after the initial startup beep. This will reset video setting to default and go through the resolution setup wizard again.
However, it is also possible that you are trying to connect a component cable to a composite tv. They are VERY different signals even though the cables fit interchangeably. If you use the Green component cable for video on a composite tv you will only see a grayscale image of the picture. This is most likely your issue. If this is the case you will need to buy a composite cable for the PS3 (the PS2 one is the exact same as the PS3 one.)
FYI Component cable has Red, Green, & Blue cables. Composite has Yellow (Video), White (Left Audio), Red (Right Audio). Both are normal RCA type plugs and will fit in each others plugs, but the signals are VERY different.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
Doesn't recognize non HD TV
hook your PS3 to the tv with the regular cord, put the tv on the channel you want. with the PS3 off but switch in on press and hold the power button until it beeps twice then release. you can also do this the other way round (SD to HD).
Mar 18, 2010 | Sony Playstation 3 (PS3) Console
We bought a hardly used ps3 for our son for x-mas. We have tried hooking it up but can't get it too play. The tv is not an HD tv, the older style tv, also have a cable box attached to the tv. Plugged the...
or the previous owner of the ps3 had the settings on the system on HD settings and now the Non-HD TV cannot recognize the signal. In order to change the settings you have to find someone with an HD TV and switch the output settings from HD to AVI
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
Was playing my PS3 on an HD Tv but cant get it to work on a non hd tV
go to
settings>display settings>video output settings
and then you change it to
AV MULTI/SCART and it should work :-)
Nov 28, 2009 | Sony Playstation 3 (PS3) Console
My ps3 doest display anything nor makes any sounds please help
Just a gander, but your PS3 may be set for HD output thus not displaying on your non HD television, your best bet in this case is to find an HD television, friend, coworker, etc, connect to it and switch the settings back to regular. Also if I understand correctly leaving the ps3 completely unplugged for 72 hours may also reset all settings. Good luck!
Jul 03, 2009 | Sony Playstation 3 (PS3) Console
PS3 not working on reg tv's after HDMI use on LCD HD tv
Shelley,  the fix for this is simple! Hold down the power button for about 5 seconds and the system will beep. This resets the video setting for your ps3 from HD too whatever the current cables are that you are using too hook up too the tv. This works on my PS3 which I just bought about 3 months ago and should work with the older ones.
Jun 05, 2009 | LG 37LC2D Television
Ps3
You could have the wrong AV channel on your TV to the slot you have you PS3 plugged into your TV with.
Or you colud have set your PS3 to a HDMI setting while using a non-HD TV, I think there's a way to reset this setting on your PS3, check the manual.
Aug 29, 2008 | Sony Playstation 3 (PS3) Console
Trouble getting HD picture
Are you guys setting your PS3 to 1080i or 1080p in the SETTINGS section? Just because you have an HDMI connection doesn't mean it automaticall switches it to max definition
Aug 27, 2008 | Sony Playstation 3 (PS3) Console
PS3 tuning problem
Hello. This is what you need to do.
1. Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
I hope this helps. Good luck to you.
Jul 25, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
133 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
