Question about Apple iPod touch
Could not find network...but did up until yesterday!
My touch worked brilliantly on my home network until the other day, when it simply decided to stop. Now, not only does it no longer display my network in settings ("Choose a Network" - just says "Other..."), when I type in my SSID it just says "Could not find network". It also does exactly the same thing on other networks I've previously been able to use. (Work, friends, etc).
I've reset the iPod and uploaded iTunes 8 and new iPod software. Am loathe to take it back to the shop I bought it from, as I live in Cornwall and I got it from NYC!
Aaargh!
nicholaschum
  • 55 Answers
SOURCE: iPod touch freezes
Hello! This problem is if you messed around with your iPod Touch a lot like hacking it. I hacked it before so I restored it so now it is very good! It is now version 1.1.2. Okay, if you want to fix this problem, hold the home button and the power button for 20-30 seconds until a yellow exclamation mark shows up to tell you to connect to iTunes, this worked for my friend's screwed up iPod Touch. Try this method okay? After you connected it to iTunes, check for updates right away and there you go!
Hope this works!
Nicholas
Posted on Nov 27, 2007
SOURCE: iPhone can't make calls... "network lost".
Ladies and gentlemen!
Before you restore or update your cracked iPhones or doing anything silly to get you further in a soup allow me to suggest a simple technique that worked for me.
My problem was quite similar to the one you guys have posted above. I could do everything else with the iphone, even receive calls but when it came to making calls, the phone wouldn't let me do the same. It would return a Call Failed message!
If you have the same issue try the following:
Go into the phone settings and turn call forwarding, call waiting, show my caller id, and TTY off and reboot.
If that doesn't work try turning call waiting, show my caller id, and TTY on and reboot and it should work.
I'm not sure why this would work but it did for me and I hope it also does for you. Good Luck
Santosh Kumar
India
Posted on Aug 31, 2008
  • 8 Answers
SOURCE: my ipod touch wifi wont work
go to settings, then wifi, then it'll show any available network
Posted on Mar 23, 2009
  • 6 Answers
SOURCE: Ipod touch will not accept my network
try changing the password again maybe that will work
Posted on Jul 18, 2009
SOURCE: ipod touch cannot find home network on netgear wgr614v9
Yeah .my ipod takes the connection away from my computer when connected to my network. it is ZyXEL_4050inn
How to fix scanner error 6?
herewith 3 suggestions (try searching the HP forum or search engine 'scanner error 6'). Read all of them before you decide to do anything and only then decide which order if any to do them depending on ease vs likely effectiveness.
HP LaserJet 3055 Scanner Error 6
HP Laserjet 3055 Scanner Error 6
6.July.2015
Jul 06, 2015 | HP LaserJet 3052 All-In-One Printer
I can't get my clock set on my GE stove model # JB645DT1BB It said to hold for 3 seconds to change the time but it doesn't change. HELP Please
To Set the Clock
The clock must be set to the correct time
of day for the automatic oven timing functions
to work properly,The time of day cannot be
changed during a delayed cooking or a delayed
self-cleaning cycle,
1. Touch the Clock pad twice.
For models without a Clock pad:
Hold the + and - pads for 3 seconds.
2. Touch the + or - pads.
If the + or - pads are not touched within one
minute after Step 1, the display reverts to the
original setting. If this happens, repeat Step 1
and reenter the time of day.
3. Touch the Start/On pad until the time of
day shows in the display. This enters the
time and starts the clock.
To check the time of day when the display is
showing other information, simply touch the
Clock pad. The time of day shows until another
pad is touched.
http://www.managemylife.com/mmh/owner_manuals/138431/GE-Free-Standing-Electric-1112529L
Sep 19, 2013 | General Electric Stove/Oven/Range Chrome...
Ipod Touch freezes while restoring?
Is it jailbroken ? what iOS version is it on ? What do you mean by restoring screen ?
Nov 17, 2012 | Apple Ipod Touch 4g
1993 Lincoln Town car 3 years ago on a very HOT day my right front brake started violently grabbing, even without touching the brake. The ABS light comes on intermittently, it usually goes off after...
I had a very similar problem in my 93 town car. I ended up changing the Calipers, rotors, and pads. This stopped the grabbing, but still every once and a while the ABS light would come on and grip the brakes on me. I ended up pulling the ABS relay from under the hood.and the problem has stayed away. The only thing is that now i dont ABS brakes. Its a heavy car tho and i havent had an issue yet. Also, if you decide to do this, the relay way mis marked in my car, when i pulled the ABS relay, the Air shocks went out instead. Had to pull one at a time until the anti lock light came on, then i knew i had it.
Jul 13, 2011 | 1993 Lincoln Town Car
One year old Amana ASZ 16 (replaced inside and outside units last year) - works fune until the last two weeks, now home at 5pm, reset the thermostat from 82 degrees to 76 or 77 to cool off house (which...
Sounds like the system is either over charged with freon or under sized. Call the same people back out ask for a supervisor to come out and check out the system any other company will charge you.
Jun 10, 2011 | Amana Heating & Cooling
My itouch is not connecting to my network and i just got it yesterday...PLEASE HELP
there are quite a few things you can do. If you just got it yesterday and you havent loaded it up with your library i would try resetting it by holding home and sleep button for 8 seconds.
if that doesnt work follow the how to set up wifi on the itouch guide on apple by clicking this link http://support.apple.com/kb/ts1398
everything you need should be in that article. If you still cant get it. Let me know and i will be glad to assist you further. If the steps provided please feel free to rate this solution. thanks and have a great day- Midwest-tek
Aug 19, 2010 | Apple iPod touch
I purchased my itrip in march 2009. Has been
try leving it and torn it on hand he shold light up becuse mine did that and he is working now
Aug 25, 2009 | Griffin Technology iTripĀ® FM Transmitter...
HTC Touch -- Drops Connection to cell tower
I find the HTC touch drops many more calls than other phones I've had. Just doesn't seem to be able to hold a weak signal very well. On my way home from work, I had 2 places where I dropped calls. When I got the HTC Touch, I now have about 4 or 5 places where I lose calls. One additional place is sitting at my desk at work. Very frustrating!
Nov 04, 2008 | HTC Touch P3450 Smartphone
Bt fusion home hub
Dear Bern
if ur using windows xp its very easy to solve
1) Just restore your omputer to older days that which work greatly.
Steps
start- program files -- Accessories- system tools- System restore- select the date whih it works greatly. and the give restore. then system will restore after restarting
best of luck
Sep 20, 2008 | Computers & Internet
Apple iPod touch Logo
149 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
