Question about Mach Speed TRIO Onyx MP3 Player
My onyx wont start up
I will turn it on and hol the play button but nuthing happens
wat should i do
  • raptercat92 Jan 22, 2009
    same problem it turns on when i plug in usb port.. but it wont turn on otherwise and it wont charge for some reason..
How do I turn on an onyx mp3 player
First, make sure that the Mach Speed Trio Onyx MP3 player is fully charged (if you use a rechargeable battery) or insert a new AAA battery. Then press and hold the Play button for 5+ seconds. This will turn off the MP3 player if it is on.
Retrevo has the manual for the Onyx here: http://www.retrevo.com/support/Mach-Onyx-2GB-MP3-Players-manual/id/2831dj281/t/2/ . You will need to enter a code to access the PDF.
I hope this helps.
Oct 14, 2014 | Mach Speed TRIO Onyx MP3 Player
My fisher n paykel draw dishwasher wont start it has three buttons a (on/off )(play/pause)(lock symbol) wat do i press to make it all start,
First press the ON/ OFF button to see if the display lights up. Once you select the program from the panel then press the PLay/ Pause button to start the cycle. Pressing the key button will prevent accidental pressing of the ON/ OFF or the Play./ pause button when the dishwasher is running. It is a child lock button. To turn it off (if you have selected it) press Keylock button again.
Dec 15, 2013 | Fisher and Paykel Dishwashers
My Nikon coolpix s8000 wont turn on
fuse , only need a fuse that it , but I need to open
Oct 06, 2017 | Nikon COOLPIX S8000 Digital Camera
I dropped my HTc and now itz nt working
Hii
what better can u do , just get it done by the service center, Always get it serviced by authorized htc service support.
Regards
Sep 08, 2009 | HTC P3300 Smartphone
The printer has been working well and today it wont start
just unplug the power cable frm back of the printer
:press the power button fr 30 seconds :while u are hol;ding the power button plug the power cable in :it will fix the problem
:still it does not happen press and hold :similarly with # and 3
:and similarly again with # and 6
Jul 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Wat could be wrong
yep ! sounds like a blown diode inside alt. have it tested either on or off car voltmeter should read 12.35 volts or more, any less replace the unit. i would test the new one at the parts store. prior to install
shack
Apr 19, 2009 | Nissan Pulsar Cars & Trucks
Help
Hold the menu button (the m button, in the middle), then it will go to the main menu.
Then click on the music button with the "m" but dont hold it then click the play button and then click the volume button wile the sign next to the bar that tells you how long the song is and how long it takes to get done. check the volume if you have it on pause or stop it will go strait to the record button. try it and if it dont work then srry.
Feb 24, 2008 | Mach Speed TRIO Onyx MP3 Player
My phillips mp3 says {Memory corruption} wat does it mean
Format your mp3 Player then re-upload your music onto it
Jan 10, 2008 | Philips SA5125/37 MP3 Player
Mp4 player plz help
i have a problem!! In the begninng i will pluge it in the computer and it will make a noise, but now nuthing happing, It's not knowing that i have it in the computer wat to do?????
Dec 30, 2007 | Goodmans GPDR40 Digital Media Player
Mach Speed TRIO Onyx MP3 Player Logo
233 people viewed this question
Top Mach Speed Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
