Question about Maytag Dryers
Dryer is gas model dg212 flame come on but will not stay on long enough to dry clothes
    Genius:
  • 1,028 Answers
If burner lights but fails to relight after several shut offs suspect burners solenoids change both they come in a kit ..once the solenoids get hot they will sometimes open electrically and fail to reenergize after cool down they will open gas valve and alow burner to reignite..also be sure vent to outside to clean and vent behind dryer is not flattened or kinked has know flame to not be properly burning due to exhaust problems and flame sensor would shut burner down
Posted on Sep 16, 2008
My kenmore gas dryer works for 5 minutes then control panel flashs and won't heat th cloths
GOD IS GOOD !!!!
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Sep 21, 2014 | Kenmore Sears Kenmore Clothes Dryer Flame...
Maytag gas dryer not drying cloths
Here's an idea, is your machine in a well ventilated area? Gas powered devices have oxygen sensors that detect when the oxygen level drops to a dangerous level, this shuts off the gas, but not the machine. Put a fan in the room, open the window or door and try again.
Dec 29, 2013 | Computers & Internet
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
Dryer is not heating enough to dry the clothes. It is 9 years old, is it better to just invest in a new dryer?
After 9 years you are going to need to replace some parts. If the ignitor works and the flame sensor is shutting down the gas but the flame stops after a while or not at all then them cols need to be replaced. themobilian_2331.jpgthemobilian_2332.jpgthemobilian_2333.jpg
Amana Dryer Service Manual Gas and electric models (printable)
May 09, 2011 | Amana ALG230RAW Gas Dryer
My Maytag DG212 gas dryer is not drying well, the hose and vent are clear. What I see is the flame will only last 10 to 15 sec. and then go out.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 02, 2010 | Dryers
My Maytag MDG7600AW gas dryer doesn't dry clothes any more. It take over 3 hours to dry at first. but now it won't dry any more. After reading the posts here, I open up the front panel and clean up all the...
The problem is the dryer coils are failing. They tend to fail as they heat up.There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Apr 23, 2010 | Maytag MDG7600AW Gas Dryer
Dryer does not dry clothes. Flame does not stay on
run dryer for 10 minutes then remove vent hose see if start working mean flame on for while, if it is then you need to clean your vent system.
May 01, 2017 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer takes to long to dry clothes
your vent is probably clogged somewhere
Mar 13, 2009 | Dryers
Dryers Logo
273 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
