Question about Tricity Bendix TM310W Electric Dryer
TUMBLE DRYER NO HEAT
TRICITY BENDIX TM310W ALL WORKING BUT NO HEAT
  • jd14 Nov 14, 2008
    ditto (except it says it is the tm320w model)
  • oldbird1960 Jan 04, 2009
    my tumble drier turns and only blows cold air? how much does it cost to repair the heating elememt or fuse? Is it oworth repairing or cheaper these days to buy a new one?
  • 734 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
How to fit belt on a tricity bendix tm310w tumble dryer
round the pulley then around the tensioner then around the drum.
Jun 08, 2014 | Tricity Bendix TM310W Electric Dryer
My tumble dryer is still unning but there is no heat.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 05, 2010 | Tricity Bendix TM310W Electric Dryer
Tumble dryer running but not heating up its a tricity bendix tm 545
either element or thermostats have blown, is their a red button at the back of the dryer, if so push in and reset, if not need engineer to check out the above.
Nov 09, 2009 | Tricity Bendix TM310W Electric Dryer
Tumble drier tumbles but no heat its an Indesit...is it the thermostat
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Nov 02, 2009 | Tricity Bendix TM310W Electric Dryer
Tumble dryer spins, but doesn't heat up
You need an ohm meter to do needed checks. Unplug dryer from power,,, then look for sensors and locate the heat coils. Using the ohm meter, check each device by connecting meter to the posts ( your looking for an open curcuit) Note that when you touch the leads of the ohm meter together, the gage will move? This is closed condition, and if the needle did not move, this is called "open". When you find a sensor or heat coil that reads open, that part is bad.
Now make sure there is not a tripped breaker in the fuse panel of the house,,, because even though the dryer is 220 volt,,, 110 volt runs the tumble motor while the other 110 volt curcuit runs the heat side ( so one will work without the other)
Oct 10, 2009 | Tricity Bendix TM310W Electric Dryer
Tumble dryer blowing cold
hi,
This is due to falty thermstat or heating element.
Mar 24, 2009 | Tricity Bendix TM310W Electric Dryer
Dryers
I think the pump is full of lint, and is not able to pumpe the water from the bottom container to the container in the panel. Check that;)
Jan 03, 2008 | Tricity Bendix TM310W Electric Dryer
Tricity Bendix TM310W Electric Dryer Logo
1,707 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
