Question about Maytag Dryers
Maytag epic z gas dryer (converted to propane) heater does not stay on long enough. Dryer does not seem to get hot enough. Venting is clear. 2 hrs to dry a load.
  • 943 Answers
Hi thanks for the question. i thhink your problem is with the gas valve coils located on the valve replace those cheap parts thanks the appliance doc
Posted on Sep 16, 2008
Maytag neptune gas dryer Model # P MD64000AWW converting to propane and would like to convert back to natural gas
NEED TO CHANGE GAS ORIFICE. THEY ARE DIFF. BETWEEN NATURAL GAS AND PROPAIN THATS ALL YOU HAVE TO DO.
Oct 06, 2013 | Maytag Neptune MCG8000AW Gas Dryer
How to remove the front panel of a maytag epic z dryer
If your unit is not drying well or slow dry it is being caused by poor external venting rather than internally. first make sure you are not crushing the vent hose behind unit then next clean venting in wall and make sure outside flaps are opening and closing properly before opening up dryer. Easy way to tell if it the machine or venting is to take vent hose off and connect a pair of sheer pantyhose to exhaust port on back of dryer and run a few loads if all works well your issue is in the wall not the machine
Apr 16, 2012 | Maytag Dryers
Need to convert electrical Maytag Performa Dryer (Model:PYET244AYW) to propane gas system. It can be converted?
No that can not be done fairly inexpensivly...it could be converted but would actually cost more to purchase all needed parts that it would be to buy a brand new gas dryer
Oct 16, 2011 | Maytag PYE2300AY Electric Dryer
Dryer is not getting as hot as it should. Items that would normally take 45 min to dry are still damp after 130 min! Also, there seems to be a faint trace of natural gas odur left in the damp clothes. ...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'';
Aug 15, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MGD9700A The heater was getting warm but not drying hot. I replaced the coils (servos) first. This did not solve the issue. Then I replaced the Thermistor, the thermostat and a second...
remove venting from back of dryer and run a test load with clothes if it dryes clothes with venting off then its a venting problem.....remove from back of dryer
Jan 31, 2011 | Dryers
I have a Maytag Neptune gas dryer that is approx 8 yrs old and has worked great as far as drying time. The gas will now light and stay on for 15 seconds and then shut off, in 2 or 3 minutes it will light...
to me it sounds like your venting going out side,if it doesn;t get a clear flow it will come on and off the thermastate inside sencing to much heat.try unpluging the vent then try it if it stays on then you know your answer
Sep 12, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Does the maytag model number mde9700ayw have the
Yes it can be a gas dryer. If you have a electric dryer now though you can not convert to gas. If the dryer is set for propane the it can be converted to gas buy a licensed plumber or appliance repair man.
Good Luck
Apr 27, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas Dryer Problem
Be sure vent is clear, if vent is clear you may need a new set of solenoids for the valve.
Jan 15, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Dryer is warm but not hot
Is the model number listed here or can you find the complete model number? May need cycling thermostat or gas valve solenoids. Let me know if I can help, Sea Breeze
Mar 22, 2009 | Maytag MDG16PD Gas Commercial Dryer
Natural GAs to Propane
Call Maytag or whirlpool!
Whirlpool makes Maytag now same company
They make a conversion kit!
ngafm at your service.
Please rate me before you sign out!
Sep 01, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
125 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
